5 Replies Latest reply on May 22, 2015 12:36 AM by Devendra Kumar
    Edge Animate CC Stops responding. Help!
    rcatalani
      Edge Animate stops responding and doesn't let me do anything. Every time I try to do anything I get the OS spinning wheel and the app stops responding, forcing me to "force quit" it. Starting to get pretty annoyed :/
      Tried to uninstall and clean install again but didn't work.
      I'm running it on Mac Os Yosemite 10.10.3.
      Can someone give me a light and help me solve this? !
        • 1. Re: Edge Animate CC Stops responding. Help!
          Devendra Kumar Adobe Employee
          Thank you for writing your concern.
          Please try following suggestions.
          1. Please install Adobe Edge Animate latest update(2014.1.1). Open creative cloud Desktop app and install latest available udpate.
          2. Please try recreating preferences. Restore preferences | Edge Animate
          Devendra Kumar
          • 2. Re: Edge Animate CC Stops responding. Help!
            rcatalani Level 1
            Thanks for the answer. Sadly, I did all this and it still freezes every time.
            Cleaned the folders and did a clean install too, still doesn't work. Same thing still happens after cleaning the preferences...
            The only way to get the app working again was installing the 3.0 version of Edge Animate. Even tough, I still need to use the latest version with the newest features.
            Here's one of the error logs I got from the freezing:
            Date/Time:       2015-05-03 14:48:31 +0100
            OS Version:      10.10.3 (Build 14D136)
            Architecture:    x86_64h
            Report Version:  21
            Command:         Edge Animate
            Path:            /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/MacOS/Adobe Edge Animate CC 2014.1
            Version:         5.0.1 (5.0.1.386)
            Parent:          launchd [1]
            PID:             548
            Event:           hang
            Duration:        1.00s (process was unresponsive for 43 seconds before sampling)
            Steps:           11 (100ms sampling interval)
            Hardware model:  MacBookPro11,3
            Active cpus:     8
            Fan speed:       2153 rpm
            Timeline format: stacks are sorted chronologically
            Use -i and -heavy to re-report with count sorting
            Heaviest stack for the main thread of the target process:
              11  start + 53 (Adobe Edge Animate CC 2014.1 + 8101) [0x2fa5]
              11  main + 1591 (Adobe Edge Animate CC 2014.1 + 300791) [0x4a6f7]
              11  exo::app::OS_AppBase::RunEventLoop() + 67 (exo + 36835) [0x14c8fe3]
              11  ??? [0x9711e7dc]
              11  -[ExoMacApplication sendEvent:] + 546 (exo + 38418) [0x14c9612]
              11  -[DVAMacApplication sendEvent:] + 648 (dvaui + 3670088) [0xa54048]
              11  ??? [0x971fe594]
              11  ??? [0x97201f9a]
              11  ??? [0x9791c871]
              11  -[DVAMacContainerView mouseUp:] + 127 (dvaui + 3696303) [0xa5a6af]
              11  void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 160 (dvacore + 173280) [0x24c4e0]
              11  void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 125 (dvacore + 167933) [0x24affd]
              11  helium::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 38 (Adobe Edge Animate CC 2014.1 + 196406) [0x30f36]
              11  boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24 (dvacore + 170040) [0x24b838]
              11  int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 36 (dvacore + 167604) [0x24aeb4]
              11  boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvaui::ui::OS_View, NSEvent*>, boost::_bi::list2<boost::_bi::value<dvaui::ui::OS_View*>, boost::_bi::value<NSEvent*> > >, void>::invoke(boost::detail::function::function_buffer&) + 42 (dvaui + 2269706) [0x8fe20a]
              11  dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 66 (dvaui + 3651234) [0xa4f6a2]
              11  dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 29 (dvaui + 3644477) [0xa4dc3d]
              11  dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 147 (dvaui + 3644675) [0xa4dd03]
              11  dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 540 (dvaui + 3652540) [0xa4fbbc]
              11  dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 663 (dvaui + 3653767) [0xa50087]
              11  dvaui::ui::UI_Node::UI_DispatchPointerEvent(dvaui::ui::PointerEvent const&, bool) + 75 (dvaui + 3093403) [0x9c739b]
              11  dvaui::ui::UI_Node::UI_DispatchPointerEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool) + 133 (dvaui + 3093685) [0x9c74b5]
              11  dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEvent const&) + 609 (dvaui + 3095809) [0x9c7d01]
              11  dvaui::ui::UI_NodeManager::EndInputCapture(bool) + 94 (dvaui + 3052190) [0x9bd29e]
              11  dvaui::ui::PointerCapture::InvokeEnd(bool) + 124 (dvaui + 3010092) [0x9b2e2c]
              11  dvaui::controls::HotTextNumberCapture<dvaui::controls::UI_NumberEdit>::End() + 155 (dvaui + 690475) [0x77c92b]
              11  dvaui::controls::UI_ControlView::SendValueChangedMessage() + 85 (dvaui + 528853) [0x7551d5]
              11  boost::detail::function::void_function_obj_invoker1<dvaui::ui::MessageFunctionAdapter<dva ui::ui::MessageT<dvaui::ui::UI_Node>, dvaui::controls::UI_ControlChangedMessage, boost::function1<void, dvaui::controls::UI_ControlChangedMessage*> >, void, dvaui::ui::MessageT<dvaui::ui::UI_Node>*>::invoke(boost::detail::function::function_buffe r&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 79 (dvalua + 200479) [0x2457f1f]
              11  boost::detail::function::void_function_obj_invoker1<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvalua::ui::ControlChangedBinder<dvaui::controls::UI_ControlView>, dvaui::controls::UI_ControlChangedMessage*>, boost::_bi::list2<boost::_bi::value<dvalua::ui::ControlChangedBinder<dvaui::controls::UI_ ControlView>*>, boost::arg<1> > >, void, dvaui::controls::UI_ControlChangedMessage*>::invoke(boost::detail::function::function_buf fer&, dvaui::controls::UI_ControlChangedMessage*) + 40 (dvalua + 205112) [0x2459138]
              11  dvalua::ui::ControlChangedBinder<dvaui::controls::UI_ControlView>::OnChanged(dvaui::contr ols::UI_ControlChangedMessage*) + 100 (dvalua + 199460) [0x2457b24]
              11  dvalua::utility::CallLuaFromCpp(lua_State*, int, int) + 51 (dvalua + 538067) [0x24aa5d3]
              11  lua_pcall + 238 (AgKernel + 80718) [0x23c0b4e]
              11  luaD_pcall(lua_State*, void (*)(lua_State*, void*), void*, int, int) + 100 (AgKernel + 125556) [0x23cba74]
              11  AgExceptionsPrivate_runProtectedCall + 38 (AgKernel + 22870) [0x23b2956]
              11  f_call(lua_State*, void*) + 33 (AgKernel + 80785) [0x23c0b91]
              11  luaD_call(lua_State*, lua_TValue*, int) + 119 (AgKernel + 124743) [0x23cb747]
              11  luaV_execute(lua_State*, int) + 2395 (AgKernel + 211643) [0x23e0abb]
              11  luaD_precall(lua_State*, lua_TValue*, int) + 1287 (AgKernel + 124119) [0x23cb4d7]
              11  helium::lua_UTLogEvent(lua_State*) + 131 (Adobe Edge Animate CC 2014.1 + 303891) [0x4b313]
              11  ??? (<22D91945-735C-3AFB-9298-1C938E2222CB> + 5502) [0x29de57e]
              11  ??? (<22D91945-735C-3AFB-9298-1C938E2222CB> + 56969) [0x29eae89]
              11  ??? (<22D91945-735C-3AFB-9298-1C938E2222CB> + 71427) [0x29ee703]
              11  ??? [0x9684f003]
              11  ??? [0x9a04c54a]
            *11  psynch_mtxcontinue + 0 (pthread + 21926) [0xffffff7f80f495a6]
            Process:         Adobe Edge Animate CC 2014.1 (Edge Animate) [548]
            Architecture:    i386
            Parent:          launchd [1]
            UID:             501
            Task size:       37491 pages (+2)
            CPU Time:        0.004s
            Note:            Unresponsive for 43 seconds before sampling
              Thread 0x1c13       11 samples (1-11)   priority 47
              <frontmost, thread QoS user interactive, boosted, received importance donation from WindowServer [188], IO policy important>
              11  start + 53 (Adobe Edge Animate CC 2014.1 + 8101) [0x2fa5] 1-11
                11  main + 1591 (Adobe Edge Animate CC 2014.1 + 300791) [0x4a6f7] 1-11
                  11  exo::app::OS_AppBase::RunEventLoop() + 67 (exo + 36835) [0x14c8fe3] 1-11
                    11  ??? [0x9711e7dc] 1-11
                      11  -[ExoMacApplication sendEvent:] + 546 (exo + 38418) [0x14c9612] 1-11
                        11  -[DVAMacApplication sendEvent:] + 648 (dvaui + 3670088) [0xa54048] 1-11
                          11  ??? [0x971fe594] 1-11
                            11  ??? [0x97201f9a] 1-11
                              11  ??? [0x9791c871] 1-11
                                11  -[DVAMacContainerView mouseUp:] + 127 (dvaui + 3696303) [0xa5a6af] 1-11
                                  11  void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 160 (dvacore + 173280) [0x24c4e0] 1-11
                                    11  void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 125 (dvacore + 167933) [0x24affd] 1-11
                                      11  helium::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 38 (Adobe Edge Animate CC 2014.1 + 196406) [0x30f36] 1-11
                                        11  boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24 (dvacore + 170040) [0x24b838] 1-11
                                          11  int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 36 (dvacore + 167604) [0x24aeb4] 1-11
                                            11  boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvaui::ui::OS_View, NSEvent*>, boost::_bi::list2<boost::_bi::value<dvaui::ui::OS_View*>, boost::_bi::value<NSEvent*> > >, void>::invoke(boost::detail::function::function_buffer&) + 42 (dvaui + 2269706) [0x8fe20a] 1-11
                                              11  dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 66 (dvaui + 3651234) [0xa4f6a2] 1-11
                                                11  dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 29 (dvaui + 3644477) [0xa4dc3d] 1-11
                                                  11  dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 147 (dvaui + 3644675) [0xa4dd03] 1-11
                                                    11  dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 540 (dvaui + 3652540) [0xa4fbbc] 1-11
                                                      11  dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 663 (dvaui + 3653767) [0xa50087] 1-11
                                                        11  dvaui::ui::UI_Node::UI_DispatchPointerEvent(dvaui::ui::PointerEvent const&, bool) + 75 (dvaui + 3093403) [0x9c739b] 1-11
                                                          11  dvaui::ui::UI_Node::UI_DispatchPointerEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool) + 133 (dvaui + 3093685) [0x9c74b5] 1-11
                                                            11  dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEvent const&) + 609 (dvaui + 3095809) [0x9c7d01] 1-11
                                                              11  dvaui::ui::UI_NodeManager::EndInputCapture(bool) + 94 (dvaui + 3052190) [0x9bd29e] 1-11
        11  dvaui::ui::PointerCapture::InvokeEnd(bool) + 124 (dvaui + 3010092) [0x9b2e2c] 1-11
        11  dvaui::controls::HotTextNumberCapture<dvaui::controls::UI_NumberEdit>::End() + 155 (dvaui + 690475) [0x77c92b] 1-11
        11  dvaui::controls::UI_ControlView::SendValueChangedMessage() + 85 (dvaui + 528853) [0x7551d5] 1-11
        11  boost::detail::function::void_function_obj_invoker1<dvaui::ui::MessageFunctionAdapter<dva ui::ui::MessageT<dvaui::ui::UI_Node>, dvaui::controls::UI_ControlChangedMessage, boost::function1<void, dvaui::controls::UI_ControlChangedMessage*> >, void, dvaui::ui::MessageT<dvaui::ui::UI_Node>*>::invoke(boost::detail::function::function_buffe r&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 79 (dvalua + 200479) [0x2457f1f] 1-11
        11  boost::detail::function::void_function_obj_invoker1<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvalua::ui::ControlChangedBinder<dvaui::controls::UI_ControlView>, dvaui::controls::UI_ControlChangedMessage*>, boost::_bi::list2<boost::_bi::value<dvalua::ui::ControlChangedBinder<dvaui::controls::UI_ ControlView>*>, boost::arg<1> > >, void, dvaui::controls::UI_ControlChangedMessage*>::invoke(boost::detail::function::function_buf fer&, dvaui::controls::UI_ControlChangedMessage*) + 40 (dvalua + 205112) [0x2459138] 1-11
        11  dvalua::ui::ControlChangedBinder<dvaui::controls::UI_ControlView>::OnChanged(dvaui::contr ols::UI_ControlChangedMessage*) + 100 (dvalua + 199460) [0x2457b24] 1-11
        11  dvalua::utility::CallLuaFromCpp(lua_State*, int, int) + 51 (dvalua + 538067) [0x24aa5d3] 1-11
        11  lua_pcall + 238 (AgKernel + 80718) [0x23c0b4e] 1-11
        11  luaD_pcall(lua_State*, void (*)(lua_State*, void*), void*, int, int) + 100 (AgKernel + 125556) [0x23cba74] 1-11
        11  AgExceptionsPrivate_runProtectedCall + 38 (AgKernel + 22870) [0x23b2956] 1-11
        11  f_call(lua_State*, void*) + 33 (AgKernel + 80785) [0x23c0b91] 1-11
        11  luaD_call(lua_State*, lua_TValue*, int) + 119 (AgKernel + 124743) [0x23cb747] 1-11
        11  luaV_execute(lua_State*, int) + 2395 (AgKernel + 211643) [0x23e0abb] 1-11
        11  luaD_precall(lua_State*, lua_TValue*, int) + 1287 (AgKernel + 124119) [0x23cb4d7] 1-11
        11  helium::lua_UTLogEvent(lua_State*) + 131 (Adobe Edge Animate CC 2014.1 + 303891) [0x4b313] 1-11
        11  ??? (<22D91945-735C-3AFB-9298-1C938E2222CB> + 5502) [0x29de57e] 1-11
        11  ??? (<22D91945-735C-3AFB-9298-1C938E2222CB> + 56969) [0x29eae89] 1-11
        11  ??? (<22D91945-735C-3AFB-9298-1C938E2222CB> + 71427) [0x29ee703] 1-11
        11  ??? [0x9684f003] 1-11
        11  ??? [0x9a04c54a] 1-11
        *11  psynch_mtxcontinue + 0 (pthread + 21926) [0xffffff7f80f495a6] 1-11
              Thread 0x1c19       11 samples (1-11)   priority 47
              11  ??? [0x942d83a2] 1-11
                11  ??? [0x9a04d8ce] 1-11
                 *11  ??? (kernel + 5989984) [0xffffff80007b6660] 1-11
              Thread 0x1c26       11 samples (1-11)   priority 31
              <frontmost, thread QoS legacy, boosted, received importance donation from WindowServer [188], IO policy important>
              11  ??? [0x9684ee52] 1-11
                11  ??? [0x96850d89] 1-11
                  11  ??? [0x96850e13] 1-11
                    11  ??? (Chromium Embedded Framework + 1760501) [0x2dd4cf5] 1-11
                      11  ??? (Chromium Embedded Framework + 1787111) [0x2ddb4e7] 1-11
                        11  ??? (Chromium Embedded Framework + 1786865) [0x2ddb3f1] 1-11
                          11  ??? (Chromium Embedded Framework + 1559723) [0x2da3cab] 1-11
                            11  ??? (Chromium Embedded Framework + 1680094) [0x2dc12de] 1-11
                              11  ??? (Chromium Embedded Framework + 1561346) [0x2da4302] 1-11
                                11  ??? (Chromium Embedded Framework + 1241564) [0x2d561dc] 1-11
                                  11  ??? (Chromium Embedded Framework + 1243167) [0x2d5681f] 1-11
                                    11  ??? [0x93c6d34a] 1-11
                                      11  ??? [0x9694390b] 1-11
                                        11  ??? [0x96943aa6] 1-11
                                          11  ??? [0x96944309] 1-11
                                            11  ??? [0x96944ef6] 1-11
                                              11  ??? [0x9a0469ce] 1-11
                                               *11  ipc_mqueue_receive_continue + 0 (kernel + 1148928) [0xffffff8000318800] 1-11
              Thread 0x1c27       11 samples (1-11)   priority 31
                                11  ??? (Chromium Embedded Framework + 1236432) [0x2d54dd0] 1-11
                                  11  ??? (Chromium Embedded Framework + 1860585) [0x2ded3e9] 1-11
                                    11  ??? [0x9a04d8b2] 1-11
              Thread 0x1c28       11 samples (1-11)   priority 31
                      11  ??? (Chromium Embedded Framework + 1799088) [0x2dde3b0] 1-11
                        11  ??? (Chromium Embedded Framework + 1798111) [0x2dddfdf] 1-11
                          11  ??? (Chromium Embedded Framework + 1736068) [0x2dced84] 1-11
                            11  ??? [0x96851ce1] 1-11
                              11  ??? [0x9a04c512] 1-11
                               *11  psynch_cvcontinue + 0 (pthread + 26908) [0xffffff7f80f4a91c] 1-11
              Thread 0x1c29       11 samples (1-11)   priority 31
              Thread 0x1c31       11 samples (1-11)   priority 31
                        11  ??? (Chromium Embedded Framework + 2146098) [0x2e32f32] 1-11
                          11  ??? (Chromium Embedded Framework + 2145113) [0x2e32b59] 1-11
                                    11  ??? (Chromium Embedded Framework + 1579311) [0x2da892f] 1-11
                                      11  ??? (Chromium Embedded Framework + 1738562) [0x2dcf742] 1-11
                                        11  ??? (Chromium Embedded Framework + 1739079) [0x2dcf947] 1-11
                                          11  ??? (Chromium Embedded Framework + 1735795) [0x2dcec73] 1-11
                                            11  ??? [0x968551c0] 1-11
              Thread 0x1c32       11 samples (1-11)   priority 31
                        11  ??? (Chromium Embedded Framework + 2146118) [0x2e32f46] 1-11
                          11  ??? (Chromium Embedded Framework + 2145257) [0x2e32be9] 1-11
              Thread 0x1c33       11 samples (1-11)   priority 31
                        11  ??? (Chromium Embedded Framework + 2146138) [0x2e32f5a] 1-11
                          11  ??? (Chromium Embedded Framework + 2145401) [0x2e32c79] 1-11
              Thread 0x1c34       11 samples (1-11)   priority 31
                        11  ??? (Chromium Embedded Framework + 2146158) [0x2e32f6e] 1-11
                          11  ??? (Chromium Embedded Framework + 2145545) [0x2e32d09] 1-11
              Thread 0x1c35       11 samples (1-11)   priority 31
                        11  ??? (Chromium Embedded Framework + 2146178) [0x2e32f82] 1-11
                          11  ??? (Chromium Embedded Framework + 2145689) [0x2e32d99] 1-11
                                    11  ??? (Chromium Embedded Framework + 1236670) [0x2d54ebe] 1-11
              Thread 0x1c36       11 samples (1-11)   priority 31         cpu time 0.001s
                        11  ??? (Chromium Embedded Framework + 2146195) [0x2e32f93] 1-11
                          11  ??? (Chromium Embedded Framework + 2145833) [0x2e32e29] 1-11
              Thread 0x1c37       11 samples (1-11)   priority 31
              Thread 0x1c38       11 samples (1-11)   priority 31
              Thread 0x1c39       11 samples (1-11)   priority 31
              Thread 0x1c3a       11 samples (1-11)   priority 31
                      11  ??? (Chromium Embedded Framework + 3542912) [0x2f87f80] 1-11
              Thread 0x1c3c       11 samples (1-11)   priority 31
                      11  ??? (Chromium Embedded Framework + 1784044) [0x2dda8ec] 1-11
                        11  ??? (Chromium Embedded Framework + 1763340) [0x2dd580c] 1-11
                          11  ??? (Chromium Embedded Framework + 1768031) [0x2dd6a5f] 1-11
              Thread 0x1c3d       11 samples (1-11)   priority 31
              Thread 0x1c45       11 samples (1-11)   priority 31
                    11  ??? [0x9a04c84e] 1-11
                     *11  ??? (kernel + 6143696) [0xffffff80007dbed0] 1-11
              Thread 0x1c46       11 samples (1-11)   priority 31
                    11  worker_thread + 369 (AgKernel + 239057) [0x23e75d1] 1-11
              Thread 0x1c47       11 samples (1-11)   priority 31
              Thread 0x1c48       11 samples (1-11)   priority 31
              Thread 0x1c49       11 samples (1-11)   priority 31
              Thread 0x1c4a       11 samples (1-11)   priority 31
              Thread 0x1c4b       11 samples (1-11)   priority 31
              Thread 0x1c4c       11 samples (1-11)   priority 31
              Thread 0x1c4d       11 samples (1-11)   priority 31
              Thread 0x1c4e       11 samples (1-11)   priority 31
              Thread 0x1c4f       11 samples (1-11)   priority 31
              Thread 0x1c50       11 samples (1-11)   priority 31
              Thread 0x1c51       11 samples (1-11)   priority 31
              Thread 0x1c52       11 samples (1-11)   priority 31
                    11  worker_thread + 2535 (AgKernel + 241223) [0x23e7e47] 1-11
                      11  handle_request + 2356 (AgKernel + 244516) [0x23e8b24] 1-11
                        11  handleWebRequest + 433 (Adobe Edge Animate CC 2014.1 + 210673) [0x346f1] 1-11
                          11  ??? [0x9bc18ace] 1-11
                            11  ??? [0x9bc46811] 1-11
              Thread 0x1c53       11 samples (1-11)   priority 31
              Thread 0x1c54       11 samples (1-11)   priority 31
              Thread 0x1c55       11 samples (1-11)   priority 31
              Thread 0x1c56       11 samples (1-11)   priority 31
              Thread 0x1c57       11 samples (1-11)   priority 31
              Thread 0x1c58       11 samples (1-11)   priority 31
              Thread 0x1c59       11 samples (1-11)   priority 31
              Thread 0x1c66       11 samples (1-11)   priority 47         cpu time 0.003s
                    11  ??? [0x971f9ea0] 1-11
              Thread 0x1cc7       11 samples (1-11)   priority 31
              Thread 0x1d3f       11 samples (1-11)   priority 54
              <frontmost, boosted, received importance donation from WindowServer [188], IO policy important>
                    11  ??? [0x924b0439] 1-11
                      11  ??? [0x924b07ef] 1-11
              Binary Images:
                          0x1000 -            0xb9fff  com.adobe.Adobe Edge Animate CC 2014.1.application 5.0.1 (5.0.1.386) <C0F8C388-76BC-3A79-BA68-04FCAAFDE5ED>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/MacOS/Adobe Edge Animate CC 2014.1
                        0x222000 -           0x4aefff  com.adobe.dvacore.framework 5.0.1 (5.0.1.386)                        <DF526C41-BA69-374A-B71E-E0C57CED6C63>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                        0x6d4000 -           0xc0dfff  com.adobe.dvaui.framework 5.0.1 (5.0.1.386)                          <69AB5344-98FD-361A-BF44-AFFD8F270C26>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                       0x14c0000 -          0x1594fff  com.adobe.exo.framework 5.0.1 (5.0.1.386)                            <FA1C5666-F546-3E49-A540-5F0CA5653D5E>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/exo.framework/Versions/A/exo
                       0x23ad000 -          0x23fafff  com.adobe.AgKernel.framework 5.0.1 (5.0.1.386)                       <665EED97-825F-3D2E-9AE5-8D97180412C3>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
                       0x2427000 -          0x2530fff  com.adobe.dvalua.framework 5.0.1 (5.0.1.386)                         <37C33687-C8E3-3016-B4D0-776B4A431EC0>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/dvalua.framework/Versions/A/dvalua
                       0x29dd000 -                ???  ???        <22D91945-735C-3AFB-9298-1C938E2222CB>
                       0x2c27000 -          0x6734fff  org.chromium.ContentShell.framework 33.0.1750.117 (1750.117)         <4F6C82D5-3077-37B1-91A7-E67C034947E7>  /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/dvawebview.framework/Versions/A/cef/Chromium Embedded Framework.framework/Chromium Embedded Framework
            *0xffffff7f80f44000 - 0xffffff7f80f4cfff  com.apple.kec.pthread 1.0 (1)                                        <8365956C-8613-3ED4-BC64-0D8570D2089F>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
            *0xffffff8000200000 - 0xffffff80009fffff  kernel (2782.20.48)                                                  <4B3A11F4-77AA-3D27-A22D-81A1BC5B504D>  /System/Library/Kernels/kernel
            Process:         360Daemon [54]
            Path:            /Library/Application Support/MICE/360Daemon.app/Contents/MacOS/360Daemon
            Parent:          launchd [1]
            UID:             0
            Task size:       1262 pages
            Process:         accountsd [323]
            Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean (allows idle exit)
            Task size:       2439 pages
              Thread 0x917        DispatchQueue 1     11 samples (1-11)   priority 4
              <thread QoS background, darwinbg, timers coalesced, IO policy utility>
              11  start + 1 (libdyld.dylib + 13769) [0x7fff93d0b5c9] 1-11
                11  ??? (accountsd + 2741) [0x10f716ab5] 1-11
                  11  CFRunLoopRunSpecific + 296 (CoreFoundation + 465880) [0x7fff8de4bbd8] 1-11
                    11  __CFRunLoopRun + 1371 (CoreFoundation + 467835) [0x7fff8de4c37b] 1-11
                      11  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 470708) [0x7fff8de4ceb4] 1-11
                        11  mach_msg_trap + 10 (libsystem_kernel.dylib + 70878) [0x7fff8f3a04de] 1-11
              Thread 0x922        DispatchQueue 2     11 samples (1-11)   priority 4
              11  _dispatch_mgr_thread + 52 (libdispatch.dylib + 19050) [0x7fff974d2a6a] 1-11
                11  kevent64 + 10 (libsystem_kernel.dylib + 94770) [0x7fff8f3a6232] 1-11
              Binary Images:
                     0x10f716000 -        0x10f716fff  accountsd (504.10)                     <04A110E1-7397-35CF-B77A-093318CEF5C8>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                  0x7fff8ddda000 -     0x7fff8e172fff  com.apple.CoreFoundation 6.9 (1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff8f38f000 -     0x7fff8f3acfff  libsystem_kernel.dylib (2782.20.48)    <EAFD7BD0-0C30-3E7D-9528-F9916BA0167C>  /usr/lib/system/libsystem_kernel.dylib
                  0x7fff93d08000 -     0x7fff93d0bfff  libdyld.dylib (353.2.1)                <9EACCA38-291D-38CC-811F-7E9D1451E2D3>  /usr/lib/system/libdyld.dylib
                  0x7fff974ce000 -     0x7fff974f8fff  libdispatch.dylib (442.1.4)            <502CF32B-669B-3709-8862-08188225E4F0>  /usr/lib/system/libdispatch.dylib
            Process:         Adobe Desktop Service [451]
            Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
            Architecture:    i386
            Parent:          launchd [1]
            UID:             501
            Task size:       15543 pages
            Process:         Adobe Edge Animate CC 2014.1 Helper [551]
            Path:            /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/dvawebview.framework/Versions/A/cef/Adobe Edge Animate CC 2014.1 Helper.app/Contents/MacOS/Adobe Edge Animate CC 2014.1 Helper
            Architecture:    i386
            Parent:          Adobe Edge Animate CC 2014.1 (Edge Animate) [548]
            Responsible:     Adobe Edge Animate CC 2014.1 (Edge Animate) [548]
            UID:             501
            Task size:       35606 pages
            Note:            Unresponsive for 84 seconds before sampling
            Process:         Adobe Edge Animate CC 2014.1 Helper [552]
            Architecture:    i386
            UID:             501
            Task size:       6819 pages
            Process:         Adobe Edge Animate CC 2014.1 Helper [553]
            Architecture:    i386
            UID:             501
            Task size:       17485 pages
            Process:         Adobe Edge Animate CC 2014.1 Helper [559]
            Architecture:    i386
            UID:             501
            Task size:       10878 pages (+11)
            CPU Time:        0.034s
            Process:         AdobeCrashDaemon [466]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemon.app /Contents/MacOS/AdobeCrashDaemon
            Parent:          Core Sync [464]
            Responsible:     Adobe Desktop Service [451]
            UID:             501
            Task size:       1406 pages
            Process:         AdobeCrashDaemon [550]
            Path:            /Applications/Adobe Edge Animate CC 2014.1/Adobe Edge Animate CC 2014.1.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemon.a pp/Contents/MacOS/AdobeCrashDaemon
            UID:             501
            Task size:       1371 pages
            Process:         AdobeIPCBroker [438]
            Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
            Architecture:    i386
            Parent:          launchd [1]
            UID:             501
            Task size:       2374 pages
            Process:         AdobeUpdateDaemon [78]
            Path:            /Library/Application Support/Adobe/*/AdobeUpdateDaemon
            Architecture:    i386
            Parent:          launchd [1]
            UID:             0
            Task size:       1608 pages
              Thread 0x1cf        11 samples (1-11)   priority 31
              <thread QoS legacy, timers coalesced, IO policy standard>
              11  start + 53 (AdobeUpdateDaemon + 3621) [0x9ae25] 1-11
                11  ??? (AdobeUpdateDaemon + 5239) [0x9b477] 1-11
                  11  ??? (AdobeUpdateDaemon + 4644) [0x9b224] 1-11
                    11  OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 171 (AdobeUpdateDaemon + 42379) [0xa458b] 1-11
                      11  pthread_cond_wait$UNIX2003 + 71 (libsystem_pthread.dylib + 29120) [0x968551c0] 1-11
                        11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 103698) [0x9a04c512] 1-11
              Thread 0x783        11 samples (1-11)   priority 31
              11  _dispatch_mgr_thread + 52 (libdispatch.dylib + 17314) [0x942d83a2] 1-11
                11  kevent64 + 10 (libsystem_kernel.dylib + 108750) [0x9a04d8ce] 1-11
              Thread 0x1190       11 samples (1-11)   priority 31
              11  thread_start + 34 (libsystem_pthread.dylib + 3666) [0x9684ee52] 1-11
                11  _pthread_start + 162 (libsystem_pthread.dylib + 11657) [0x96850d89] 1-11
                  11  _pthread_body + 138 (libsystem_pthread.dylib + 11795) [0x96850e13] 1-11
                    11  listenerThread(void*) + 81 (AdobeUpdateDaemon + 436385) [0x1048a1] 1-11
                      11  __read + 10 (libsystem_kernel.dylib + 110038) [0x9a04ddd6] 1-11
                       *11  hndl_unix_scall + 216 (kernel + 2314344) [0xffffff8000435068] 1-11
                         *11  unix_syscall + 666 (kernel + 6600362) [0xffffff800084b6aa] 1-11
                           *11  read_nocancel + 115 (kernel + 6210067) [0xffffff80007ec213] 1-11
                             *11  ??? (kernel + 6210730) [0xffffff80007ec4aa] 1-11
                               *11  ??? (kernel + 3559377) [0xffffff8000564fd1] 1-11
                                 *11  fifo_read + 135 (kernel + 3669143) [0xffffff800057fc97] 1-11
                                   *11  soreceive + 2319 (kernel + 6382975) [0xffffff800081657f] 1-11
                                     *11  sbwait + 310 (kernel + 6414806) [0xffffff800081e1d6] 1-11
                                       *11  msleep + 98 (kernel + 6142226) [0xffffff80007db912] 1-11
                                         *11  ??? (kernel + 6143321) [0xffffff80007dbd59] 1-11
                                           *11  lck_mtx_sleep + 134 (kernel + 1276342) [0xffffff80003379b6] 1-11
                                             *11  thread_block_reason + 175 (kernel + 1319343) [0xffffff80003421af] 1-11
                                               *11  ??? (kernel + 1329236) [0xffffff8000344854] 1-11
                                                 *11  machine_switch_context + 367 (kernel + 2176511) [0xffffff80004135ff] 1-11
              Thread 0x11cb       11 samples (1-11)   priority 31
              Thread 0x11cc       11 samples (1-11)   priority 22
                    11  ??? (AdobeUpdateDaemon + 8049) [0x9bf71] 1-11
                      11  ??? (AdobeUpdateDaemon + 8274) [0x9c052] 1-11
              Binary Images:
                         0x9a000 -           0x12bfff  AdobeUpdateDaemon                   <0DD9F5BC-ACFE-3E92-964F-A8868427870E>  /Library/Application Support/Adobe/*/AdobeUpdateDaemon
                      0x942d4000 -         0x942fbfff  libdispatch.dylib (442.1.4)         <B26A176C-39F7-3362-B128-27B1211068B9>  /usr/lib/system/libdispatch.dylib
                      0x9684e000 -         0x96856fff  libsystem_pthread.dylib (105.10.1)  <4A229519-29A1-3ABF-8CEF-43BCE4ACDA06>  /usr/lib/system/libsystem_pthread.dylib
                      0x9a033000 -         0x9a052fff  libsystem_kernel.dylib (2782.20.48) <D1D17CE0-1D1D-3243-9E9D-78C70F19B0ED>  /usr/lib/system/libsystem_kernel.dylib
            Process:         airportd [57]
            Path:            /usr/libexec/airportd
            Parent:          launchd [1]
            UID:             0
            Task size:       2174 pages
              Thread 0x1ba        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (airportd + 244600) [0x105992b78] 1-11
                  11  -[NSRunLoop(NSRunLoop) run] + 74 (Foundation + 1073535) [0x7fff92a1b17f] 1-11
                    11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 278 (Foundation + 592473) [0x7fff929a5a59] 1-11
              Thread 0x3a5        DispatchQueue 2     11 samples (1-11)   priority 4
                11  _dispatch_mgr_invoke + 176 (libdispatch.dylib + 19786) [0x7fff974d2d4a] 1-11
                  11  __select_nocancel + 10 (libsystem_kernel.dylib + 91154) [0x7fff8f3a5412] 1-11
              Thread 0x468        11 samples (1-11)   priority 4
              11  thread_start + 13 (libsystem_pthread.dylib + 5149) [0x7fff9004041d] 1-11
                11  _pthread_start + 176 (libsystem_pthread.dylib + 12773) [0x7fff900421e5] 1-11
                  11  _pthread_body + 131 (libsystem_pthread.dylib + 12904) [0x7fff90042268] 1-11
                    11  __select + 10 (libsystem_kernel.dylib + 91130) [0x7fff8f3a53fa] 1-11
              Binary Images:
                     0x105957000 -        0x105a40fff  airportd (1030.71.6)                   <91AA55A3-8280-3C53-9D58-B315FC0AFE96>  /usr/libexec/airportd
                  0x7fff9003f000 -     0x7fff90048fff  libsystem_pthread.dylib (105.10.1)     <3103AA7F-3BAE-3673-9649-47FFD7E15C97>  /usr/lib/system/libsystem_pthread.dylib
                  0x7fff92915000 -     0x7fff92c46fff  com.apple.Foundation 6.9 (1153.20)     <F0FF3A5D-C5B7-34A1-9319-DE1EF928E58E>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            Process:         amfid [125]
            Path:            /usr/libexec/amfid
            Parent:          launchd [1]
            UID:             0
            Task size:       2621 pages
              Thread 0x255        DispatchQueue 2     11 samples (1-11)   priority 31
              <thread QoS legacy, timers coalesced, IO policy important>
              Thread 0x256        DispatchQueue 11    11 samples (1-11)   priority 31
              11  _dispatch_sig_thread + 45 (libdispatch.dylib + 74669) [0x7fff974e03ad] 1-11
                11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 91970) [0x7fff8f3a5742] 1-11
              Binary Images:
                     0x10b7cf000 -        0x10b7d0fff  amfid (133.1.1)                     <F8BD134A-EF85-312F-BD4B-0E3455B54F76>  /usr/libexec/amfid
            Process:         apple.DevicePropertyReader [387]
            Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Content s/MacOS/apple.DevicePropertyReader
            Parent:          launchd [1]
            Responsible:     PTPCamera [372]
            UID:             501
            Task size:       924 pages
              Thread 0xccc        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0xcce        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10a84c000 -        0x10a84efff  com.apple.DevicePropertyReader 1.0 (1) <02E3508A-5E20-3D42-ACC4-87852D5C07B4>  /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Content s/MacOS/apple.DevicePropertyReader
            Process:         AppleCameraAssistant [386]
            Path:            /Library/CoreMediaIO/*/AppleCamera.plugin/Contents/Resources/AppleCameraAssistant
            Parent:          launchd [1]
            UID:             0
            Task size:       1469 pages
              Thread 0xcbe        DispatchQueue 1     11 samples (1-11)   priority 31
              <thread QoS legacy, IO policy important>
                11  ??? (AppleCameraAssistant + 147413) [0x104506fd5] 1-11
                  11  mach_msg_server + 468 (libsystem_kernel.dylib + 69472) [0x7fff8f39ff60] 1-11
              Thread 0xcc0        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xcbf        11 samples (1-11)   priority 31
                    11  ??? (AppleCameraAssistant + 148155) [0x1045072bb] 1-11
                      11  CFRunLoopRun + 97 (CoreFoundation + 1218161) [0x7fff8df03671] 1-11
              Thread 0xcc1        11 samples (1-11)   priority 31
                    11  ??? (AppleCameraAssistant + 125481) [0x104501a29] 1-11
              Binary Images:
                     0x1044e3000 -        0x10451afff  AppleCameraAssistant (5.33)            <70F4B0CD-5561-367C-9FA5-0E3BBB670962>  /Library/CoreMediaIO/*/AppleCamera.plugin/Contents/Resources/AppleCameraAssistant
            Process:         appleeventsd [48]
            Path:            /System/Library/CoreServices/appleeventsd
            Parent:          launchd [1]
            UID:             55
            Task size:       1076 pages
              Thread 0x37c        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x37e        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x108886000 -        0x108886fff  appleeventsd (681.2)                <17B55FAD-556B-345F-83A6-65C32DE2AA23>  /System/Library/CoreServices/appleeventsd
            Process:         AppleIDAuthAgent [401]
            Path:            /System/Library/CoreServices/AppleIDAuthAgent
            Parent:          launchd [1]
            UID:             501
            Task size:       3670 pages
              Thread 0xf48        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0xf4c        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x14d6       DispatchQueue 26    11 samples (1-11)   priority 4
              11  start_wqthread + 13 (libsystem_pthread.dylib + 5133) [0x7fff9004040d] 1-11
                11  _pthread_wqthread + 729 (libsystem_pthread.dylib + 13879) [0x7fff90042637] 1-11
                  11  _dispatch_worker_thread3 + 91 (libdispatch.dylib + 77796) [0x7fff974e0fe4] 1-11
                    11  _dispatch_root_queue_drain + 463 (libdispatch.dylib + 18103) [0x7fff974d26b7] 1-11
                      11  _dispatch_queue_invoke + 202 (libdispatch.dylib + 28364) [0x7fff974d4ecc] 1-11
                        11  _dispatch_queue_drain + 571 (libdispatch.dylib + 20820) [0x7fff974d3154] 1-11
                          11  _dispatch_source_invoke + 412 (libdispatch.dylib + 22059) [0x7fff974d362b] 1-11
                            11  _dispatch_source_latch_and_call + 721 (libdispatch.dylib + 51326) [0x7fff974da87e] 1-11
                              11  _dispatch_client_callout + 8 (libdispatch.dylib + 7187) [0x7fff974cfc13] 1-11
                                11  _dispatch_after_timer_callback + 77 (libdispatch.dylib + 58744) [0x7fff974dc578] 1-11
                                    11  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 25379) [0x7fff974d4323] 1-11
                                      11  ??? (AppleIDAuthAgent + 13302) [0x10013a3f6] 1-11
                                        11  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 70962) [0x7fff8f3a0532] 1-11
                                         *11  semaphore_wait_continue + 0 (kernel + 1357760) [0xffffff800034b7c0] 1-11
              Thread 0x14fa       11 samples (1-11)   priority 4
                    11  __NSThread__main__ + 1345 (Foundation + 257474) [0x7fff92953dc2] 1-11
                      11  -[AOSConfig listenForSystemEvents:] + 335 (AOSKit + 143920) [0x7fff8f5c0230] 1-11
              Thread 0x1501       11 samples (1-11)   priority 4
                      11  +[NSURLConnection(Loader) _resourceLoadLoop:] + 434 (CFNetwork + 37408) [0x7fff8ec39220] 1-11
              Thread 0x1599       11 samples (1-11)   priority 4
              Binary Images:
                     0x100137000 -        0x100172fff  AppleIDAuthAgent (640.4)                <942CF704-781E-378C-8873-E30065240706>  /System/Library/CoreServices/AppleIDAuthAgent
                  0x7fff8ec30000 -     0x7fff8ee3dfff  com.apple.CFNetwork 720.3.13 (720.3.13) <69E15385-5784-3912-88F6-03B16F1C1A5C>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                  0x7fff8f59d000 -     0x7fff8f834fff  com.apple.AOSKit 1.06 (217)             <92537A36-DF3F-3ABC-834C-FC723318A8A3>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
            Process:         AppleSpell [449]
            Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       912 pages
              Thread 0xf8b        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (AppleSpell + 5312) [0x10bf8e4c0] 1-11
                  11  -[NSSpellServer run] + 73 (Foundation + 1850856) [0x7fff92ad8de8] 1-11
              Thread 0xf8c        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x10bf8d000 -        0x10c070fff  com.apple.AppleSpell 2.2.3 (282)       <C1985DA2-E1F8-3D7C-97B1-738025FF8318>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
            Process:         apsd [77]
            Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
            Parent:          launchd [1]
            UID:             0
            Task size:       3814 pages
            Note:            1 idle work queue threads omitted
              Thread 0x1ce        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (apsd + 372483) [0x10f02bf03] 1-11
              Thread 0x32f        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x540        11 samples (1-11)   priority 63
              <timers coalesced, IO policy important>
              Thread 0x79a        11 samples (1-11)   priority 31
              Binary Images:
                     0x10efd1000 -        0x10f097fff  apsd (275.6)                            <081D5A04-3804-3540-9514-545D498254E5>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
            Process:         askpermissiond [405]
            Path:            /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermiss iond
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       2996 pages
              Thread 0xd3b        DispatchQueue 1     11 samples (1-11)   priority 1
                11  ??? (askpermissiond + 49060) [0x109b50fa4] 1-11
              Thread 0xde3        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x109b45000 -        0x109b5dfff  askpermissiond (59)                    <8585971D-726E-3BA0-BFE0-49B2838518D5>  /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermiss iond
            Process:         authd [129]
            Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty (allows idle exit)
            Task size:       1314 pages
              Thread 0x2c8        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x2ca        DispatchQueue 10    11 samples (1-11)   priority 4
                    11  _dispatch_root_queue_drain + 935 (libdispatch.dylib + 18575) [0x7fff974d288f] 1-11
                          11  ??? (authd + 73492) [0x1054f9f14] 1-11
                            11  au_sdev_read_aia + 557 (libbsm.0.dylib + 60012) [0x7fff98e0ca6c] 1-11
                              11  fgetc + 52 (libsystem_c.dylib + 247124) [0x7fff8eb7c554] 1-11
                                11  __srget + 14 (libsystem_c.dylib + 274536) [0x7fff8eb83068] 1-11
                                  11  __srefill1 + 24 (libsystem_c.dylib + 274251) [0x7fff8eb82f4b] 1-11
                                    11  __read_nocancel + 10 (libsystem_kernel.dylib + 90890) [0x7fff8f3a530a] 1-11
                                     *11  hndl_unix_scall64 + 22 (kernel + 2315126) [0xffffff8000435376] 1-11
                                       *11  unix_syscall64 + 662 (kernel + 6601350) [0xffffff800084ba86] 1-11
                                               *11  spec_read + 609 (kernel + 3672849) [0xffffff8000580b11] 1-11
                                                 *11  ??? (kernel + 5837892) [0xffffff8000791444] 1-11
              Thread 0x2cb        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x1054e8000 -        0x1054fffff  com.apple.authd 1.0 (57031.20.26)   <AB7C810F-2D5F-3F41-B56A-9B00D227A37B>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
                  0x7fff8eb40000 -     0x7fff8ebccfff  libsystem_c.dylib (1044.10.1)       <86FBED7A-F2C8-3591-AD6F-486DD57E6B6A>  /usr/lib/system/libsystem_c.dylib
                  0x7fff98dfe000 -     0x7fff98e0efff  libbsm.0.dylib (34)                 <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB>  /usr/lib/libbsm.0.dylib
            Process:         autofsd [86]
            Path:            /usr/libexec/autofsd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       677 pages
              Thread 0x2fb        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x5a8        DispatchQueue 11    11 samples (1-11)   priority 31
              Binary Images:
                     0x100587000 -        0x100588fff  autofsd (246.10.1)                  <DD6CEE95-086D-3882-8966-0693B702B8A6>  /usr/libexec/autofsd
            Process:         AV_Systray [416]
            Path:            /Applications/Avira.app/Contents/MacOS/AV_Systray.app/Contents/MacOS/AV_Systray
            Parent:          launchd [1]
            UID:             501
            Task size:       5030 pages
            Process:         avbackendproxy [281]
            Path:            /Applications/Avira.app/Contents/MacOS/avbackendproxy
            Parent:          avwatchdox.bin [55]
            Responsible:     avwatchdox.bin [55]
            UID:             -2
            Task size:       215 pages
              Thread 0x7ce        DispatchQueue 1     11 samples (1-11)   priority 31
              <thread QoS legacy, IO policy standard>
                11  main + 1022 (avbackendproxy + 81790) [0x107c9ef7e] 1-11
              Binary Images:
                     0x107c8b000 -        0x107d16fff  avbackendproxy (0)                  <A420951C-CE1B-3A8F-992F-8FF0D0D4FB44>  /Applications/Avira.app/Contents/MacOS/avbackendproxy
            Process:         avguard-ondemand-mgmt [534]
            Path:            /Applications/Avira.app/Contents/guard/avguard-ondemand-mgmt
            Parent:          avguard.bin [291]
            UID:             0
            Task size:       1310 pages
            CPU Time:        0.006s
              Thread 0x162d       DispatchQueue 1     11 samples (1-11)   priority 31         cpu time 0.006s
                11  ??? (avguard-ondemand-mgmt + 14426) [0x101e5285a] 1-11
                  11  ??? (avguard-ondemand-mgmt + 15906) [0x101e52e22] 1-11
                    11  poll + 10 (libsystem_kernel.dylib + 95682) [0x7fff8f3a65c2] 1-11
                         *11  poll_nocancel + 880 (kernel + 6220384) [0xffffff80007eea60] 1-11
                           *11  kqueue_scan + 404 (kernel + 5982196) [0xffffff80007b47f4] 1-11
              Binary Images:
                     0x101e4f000 -        0x101fc1fff  avguard-ondemand-mgmt (0)           <785E61E6-C202-383E-9D0B-C5C3BE387FDB>  /Applications/Avira.app/Contents/guard/avguard-ondemand-mgmt
            Process:         avguard-scanner [469]
            Path:            /Applications/Avira.app/Contents/guard/avguard-scanner
            UID:             0
            Task size:       1383 pages
              Thread 0x1115       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10c46969c] 1-11
              Binary Images:
                     0x10c467000 -        0x10c5e5fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [475]
            UID:             0
            Task size:       1364 pages
              Thread 0x1158       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10070269c] 1-11
              Binary Images:
                     0x100700000 -        0x10087efff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [476]
            UID:             0
              Thread 0x1159       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x103b2e69c] 1-11
              Binary Images:
                     0x103b2c000 -        0x103caafff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [477]
            UID:             0
            Task size:       1356 pages
              Thread 0x115b       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10610969c] 1-11
              Binary Images:
                     0x106107000 -        0x106285fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [478]
            UID:             0
            Task size:       1366 pages
              Thread 0x1160       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x1097e969c] 1-11
              Binary Images:
                     0x1097e7000 -        0x109965fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [479]
            UID:             0
            Task size:       1365 pages
              Thread 0x1161       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10441c69c] 1-11
              Binary Images:
                     0x10441a000 -        0x104598fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [480]
            UID:             0
            Task size:       1353 pages
              Thread 0x1162       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10d3e869c] 1-11
              Binary Images:
                     0x10d3e6000 -        0x10d564fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [481]
            UID:             0
            Task size:       1376 pages
              Thread 0x1163       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10d20f69c] 1-11
              Binary Images:
                     0x10d20d000 -        0x10d38bfff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [482]
            UID:             0
            Task size:       1363 pages
              Thread 0x1164       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10ba6469c] 1-11
              Binary Images:
                     0x10ba62000 -        0x10bbe0fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard-scanner [483]
            UID:             0
            Task size:       1367 pages
              Thread 0x1165       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard-scanner + 9884) [0x10107d69c] 1-11
              Binary Images:
                     0x10107b000 -        0x1011f9fff  avguard-scanner (0)                 <5AAA694E-B933-32D0-8075-6375CDE5C1FA>  /Applications/Avira.app/Contents/guard/avguard-scanner
            Process:         avguard.bin [291]
            Path:            /Applications/Avira.app/Contents/guard/avguard.bin
            UID:             0
            Task size:       83331 pages
              Thread 0x7e9        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (avguard.bin + 30529) [0x10f08a741] 1-11
                  11  ??? (avguard.bin + 36678) [0x10f08bf46] 1-11
              Binary Images:
                     0x10f083000 -        0x10f38ffff  avguard.bin (0)                     <CFB7BE9C-7CD0-3157-9E0E-66327D24DC63>  /Applications/Avira.app/Contents/guard/avguard.bin
            Process:         avlogwriter [283]
            Path:            /Applications/Avira.app/Contents/MacOS/avlogwriter
            UID:             -2
            Task size:       629 pages
              Thread 0x7d0        DispatchQueue 1     11 samples (1-11)   priority 31
                11  main + 1104 (avlogwriter + 36960) [0x108d1f060] 1-11
              Thread 0x7d2        11 samples (1-11)   priority 31
                    11  boost::(anonymous namespace)::thread_proxy(void*) + 133 (avlogwriter + 1320869) [0x108e587a5] 1-11
                      11  SignalThread::operator()() + 37 (avlogwriter + 83541) [0x108d2a655] 1-11
                        11  __sigwait + 10 (libsystem_kernel.dylib + 91994) [0x7fff8f3a575a] 1-11
                             *11  __sigwait_nocancel + 413 (kernel + 6126861) [0xffffff80007d7d0d] 1-11
              Thread 0x7d3        11 samples (1-11)   priority 31
                      11  boost::detail::thread_data<Consumer>::run() + 16 (avlogwriter + 57440) [0x108d24060] 1-11
                        11  Consumer::operator()() + 598 (avlogwriter + 58038) [0x108d242b6] 1-11
                          11  boost::this_thread::hiden::sleep_until(timespec const&) + 78 (avlogwriter + 1324030) [0x108e593fe] 1-11
                            11  boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76 (avlogwriter + 1328636) [0x108e5a5fc] 1-11
                              11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 90422) [0x7fff8f3a5136] 1-11
              Thread 0x1114       11 samples (1-11)   priority 31
                      11  __recvfrom + 10 (libsystem_kernel.dylib + 90938) [0x7fff8f3a533a] 1-11
                           *11  recvfrom_nocancel + 234 (kernel + 6440682) [0xffffff80008246ea] 1-11
                             *11  ??? (kernel + 6452651) [0xffffff80008275ab] 1-11
              Binary Images:
                     0x108d16000 -        0x108eb4fff  avlogwriter (0)                     <BE6A6C99-F302-3B1F-8524-ECE920C4204F>  /Applications/Avira.app/Contents/MacOS/avlogwriter
            Process:         avqmd [286]
            Path:            /Applications/Avira.app/Contents/MacOS/avqmd
            UID:             333
            Task size:       3488 pages
              Thread 0x7dd        DispatchQueue 1     11 samples (1-11)   priority 31
                11  main + 2305 (avqmd + 9729) [0x10d56d601] 1-11
                  11  __semwait_signal + 10 (libsystem_kernel.dylib + 91274) [0x7fff8f3a548a] 1-11
              Thread 0x7e0        11 samples (1-11)   priority 31
                    11  ??? (avqmd + 13110) [0x10d56e336] 1-11
              Thread 0x7e1        11 samples (1-11)   priority 31
                    11  kevent + 10 (libsystem_kernel.dylib + 94746) [0x7fff8f3a621a] 1-11
              Thread 0x7e2        11 samples (1-11)   priority 31
                    11  ??? (avqmd + 11871) [0x10d56de5f] 1-11
              Thread 0x7e3        11 samples (1-11)   priority 31
              Binary Images:
                     0x10d56b000 -        0x10d80cfff  avqmd (0)                           <CC942C31-B368-3C45-83AE-D4E0DC6A48B2>  /Applications/Avira.app/Contents/MacOS/avqmd
            Process:         avqmd [288]
            Parent:          avqmd [286]
            UID:             0
            Task size:       110 pages
              Thread 0x7df        DispatchQueue 1     11 samples (1-11)   priority 31
              <IO policy standard>
                11  main + 1473 (avqmd + 8897) [0x10d56d2c1] 1-11
              Binary Images:
            Process:         avsavapi-super [484]
            Path:            /Applications/Avira.app/Contents/guard/avsavapi-super
            UID:             0
            Task size:       413 pages
              Thread 0x1166       DispatchQueue 1     11 samples (1-11)   priority 31
                11  __wait4 + 10 (libsystem_kernel.dylib + 92418) [0x7fff8f3a5902] 1-11
              Binary Images:
                     0x1009e8000 -        0x100a38fff  avsavapi-super (0)                  <4B103970-50A8-3960-BD04-90B73CFDD25D>  /Applications/Avira.app/Contents/guard/avsavapi-super
            Process:         avwatchdox.bin [55]
            Path:            /Applications/Avira.app/Contents/MacOS/avwatchdox.bin
            Parent:          launchd [1]
            UID:             0
            Task size:       703 pages
              Thread 0x1b8        DispatchQueue 1     11 samples (1-11)   priority 31
                11  main + 4830 (avwatchdox.bin + 8702) [0x104c5c1fe] 1-11
              Binary Images:
                     0x104c5a000 -        0x104c96fff  avwatchdox.bin (0)                  <8DB30202-4E03-3ED7-8535-60D82D96D080>  /Applications/Avira.app/Contents/MacOS/avwatchdox.bin
            Process:         awdd [72]
            Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
            Parent:          launchd [1]
            UID:             0
            Task size:       1346 pages
              Thread 0x1c9        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (awdd + 14756) [0x10a4ef9a4] 1-11
              Thread 0x3b3        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10a4ec000 -        0x10a58efff  awdd (712)                             <8F5FF32F-92FE-383C-B30A-8F76E16CEAFD>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
            Process:         bird [340]
            Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
            Parent:          launchd [1]
            UID:             501
            Task size:       4756 pages
              Thread 0x9db        DispatchQueue 1     11 samples (1-11)   priority 3
                11  ??? (bird + 6197) [0x10429b835] 1-11
              Thread 0x9e7        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10429a000 -        0x10429bfff  bird (321.6)                           <16D08E4D-FB56-3839-B03F-36F6BC78DCD7>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
            Process:         blued [87]
            Path:            /usr/sbin/blued
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       1316 pages
              Thread 0x1d8        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (blued + 111486) [0x106a2037e] 1-11
              Thread 0x321        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x4da        11 samples (1-11)   priority 31
              Binary Images:
                     0x106a05000 -        0x106a9bfff  blued (4304.4.4)                       <F4E578DF-8878-3A20-9139-7444B7C4C890>  /usr/sbin/blued
            Process:         CalendarAgent [327]
            Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
            Parent:          launchd [1]
            UID:             501
            Task size:       7829 pages
              Thread 0x93b        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (CalendarAgent + 6289) [0x10167a891] 1-11
              Thread 0x9c9        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0xb03        11 samples (1-11)   priority 4
              Thread 0xcbc        11 samples (1-11)   priority 4
              Binary Images:
                     0x101679000 -        0x10167afff  CalendarAgent (316.1)                   <918815B9-181F-3CBA-B219-5715DE483BEC>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
            Process:         CallHistoryPluginHelper [348]
            Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
            Parent:          launchd [1]
            UID:             501
            Task size:       2912 pages
              Thread 0xa1a        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (CallHistoryPluginHelper + 5595) [0x10b9c05db] 1-11
              Thread 0xa21        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10b9bf000 -        0x10b9c0fff  CallHistoryPluginHelper (405)          <20811A6C-56E2-35E4-B5B5-821532129ABD>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
            Process:         CallHistorySyncHelper [350]
            Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
            Parent:          launchd [1]
            UID:             501
            Task size:       3223 pages
              Thread 0xa2d        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (CallHistorySyncHelper + 34483) [0x10bbd66b3] 1-11
              Thread 0xa34        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10bbce000 -        0x10bbe2fff  CallHistorySyncHelper (405)            <7CE3BC23-49FA-31B1-94BB-C3ACC304D7A8>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
            Process:         callservicesd [357]
            Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
            Parent:          launchd [1]
            UID:             501
            Task size:       5618 pages
              Thread 0xa8e        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (callservicesd + 197919) [0x102d8b51f] 1-11
              Thread 0xb06        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x102d5b000 -        0x102da2fff  callservicesd (420.17)                 <54099B88-9C3F-3E20-97C0-6E73912450D9>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
            Process:         CalNCService [342]
            Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/XPCServices/CalNCSer vice.xpc/Contents/MacOS/CalNCService
            Parent:          launchd [1]
            Responsible:     CalendarAgent [327]
            UID:             501
            Task size:       5302 pages
              Thread 0x9f3        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 111 (CalNCService + 7583) [0x10b41fd9f] 1-11
                  11  -[NSXPCListener resume] + 163 (Foundation + 708362) [0x7fff929c1f0a] 1-11
                    11  xpc_main + 490 (libxpc.dylib + 98400) [0x7fff8eeff060] 1-11
                      11  _xpc_objc_main + 751 (libxpc.dylib + 92462) [0x7fff8eefd92e] 1-11
              Thread 0xa45        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10b41e000 -        0x10b427fff  com.apple.CalendarAgent.CalNCService 1.0 (316.1) <444446BE-CD7E-3B53-91B4-7767630A18E6>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/XPCServices/CalNCSer vice.xpc/Contents/MacOS/CalNCService
                  0x7fff8eee7000 -     0x7fff8ef0ffff  libxpc.dylib (559.20.9)                          <D35D0DB2-D7BD-3BE4-8378-062BFE545E1D>  /usr/lib/system/libxpc.dylib
            Process:         cfprefsd [127]
            Path:            /usr/sbin/cfprefsd
            Parent:          launchd [1]
            UID:             0
            Task size:       920 pages
            Note:            4 idle work queue threads omitted
              Thread 0x277        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x279        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x10bc8b000 -        0x10bc8bfff  cfprefsd (1153.18)                  <13F2A682-DE1A-30D8-9F5F-133C97A721A1>  /usr/sbin/cfprefsd
            Process:         cfprefsd [301]
            Parent:          launchd [1]
            UID:             501
            Task size:       2324 pages (+1)
            Note:            6 idle work queue threads omitted
              Thread 0x834        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x838        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x10930e000 -        0x10930efff  cfprefsd (1153.18)                  <13F2A682-DE1A-30D8-9F5F-133C97A721A1>  /usr/sbin/cfprefsd
            Process:         cloudd [317]
            Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
            Parent:          launchd [1]
            UID:             501
            Task size:       5882 pages
              Thread 0x8cc        DispatchQueue 1     11 samples (1-11)   priority 2
                11  ??? (cloudd + 10063) [0x10ba9474f] 1-11
              Thread 0x903        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0xafd        11 samples (1-11)   priority 4
              Thread 0xb70        11 samples (1-11)   priority 4
              Binary Images:
                     0x10ba92000 -        0x10ba96fff  cloudd (283.67.2)                       <AFD37F84-1CE3-3A06-BB58-AE0927F34399>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
            Process:         CloudKeychainProxy [436]
            Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
            Parent:          launchd [1]
            UID:             501
            Task size:       741 pages
              Thread 0xe3c        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (CloudKeychainProxy + 5967) [0x1057f674f] 1-11
              Thread 0xe4a        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x1057f5000 -        0x105801fff  com.apple.security.cloudkeychainproxy3 1.0 (57031.20.26) <00BE309A-62E4-3C40-B0FA-B73EAE2EB59F>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
            Process:         cloudpaird [409]
            Path:            /System/Library/CoreServices/cloudpaird
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       1195 pages
              Thread 0xd3f        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (cloudpaird + 49124) [0x10e03dfe4] 1-11
              Thread 0xf13        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10e032000 -        0x10e041fff  cloudpaird (4304.4.4)                  <AD8CF379-7CA6-3227-8E23-6E6B1BAB4B3A>  /System/Library/CoreServices/cloudpaird
            Process:         cloudphotosd [493]
            Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
            Parent:          launchd [1]
            UID:             501
            Task size:       6917 pages
              Thread 0x11d7       DispatchQueue 1     11 samples (1-11)   priority 4
              <thread QoS background, darwinbg, IO policy utility>
                11  NSApplicationMain + 1832 (AppKit + 13140) [0x7fff92d89354] 1-11
                  11  -[NSApplication run] + 594 (AppKit + 551923) [0x7fff92e0cbf3] 1-11
                    11  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346 (AppKit + 593768) [0x7fff92e16f68] 1-11
                      11  _DPSNextEvent + 978 (AppKit + 596411) [0x7fff92e179bb] 1-11
                        11  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 205099) [0x7fff9ae0412b] 1-11
                          11  ReceiveNextEventCommon + 431 (HIToolbox + 205546) [0x7fff9ae042ea] 1-11
                            11  RunCurrentEventLoopInMode + 235 (HIToolbox + 206191) [0x7fff9ae0456f] 1-11
              Thread 0x11e4       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1235       11 samples (1-11)   priority 4
                    11  _NSEventThread + 137 (AppKit + 1414763) [0x7fff92edf66b] 1-11
              Binary Images:
                     0x10fee4000 -        0x10ffbafff  com.apple.cloudphotosd 1.0 (209.52.0)  <13D1A56E-0308-3F1C-8657-8955C1EFA95E>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
                  0x7fff92d86000 -     0x7fff93907fff  com.apple.AppKit 6.9 (1347.57)         <B214D528-7D1C-39B2-BE36-821D417A0297>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff9add2000 -     0x7fff9b0d7fff  com.apple.HIToolbox 2.1.1 (758.7)      <6711FAA9-904A-3B49-9665-FC8D13B93C42>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            Process:         com.apple.AccountPolicyHelper [267]
            Path:            /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPo licyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
            Parent:          launchd [1]
            UID:             0
            Task size:       733 pages
              Thread 0x77c        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x77d        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10a88c000 -        0x10a895fff  com.apple.AccountPolicyHelper 1.0 (1) <34AA9AAD-917C-3B06-B889-76DAF2AEE819>  /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPo licyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
            Process:         com.apple.AddressBook.InternetAccountsBridge [385]
            Path:            /System/Library/Frameworks/AddressBook.framework/Versions/A/XPCServices/com.apple.Address Book.InternetAccountsBridge.xpc/Contents/MacOS/com.apple.AddressBook.InternetAccountsBridg e
            Parent:          launchd [1]
            UID:             501
            Task size:       2732 pages
              Thread 0xcc5        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0xcc6        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x10bbe7000 -        0x10bbe8fff  com.apple.AddressBook.InternetAccountsBridge 9.0 (1579) <EDA95366-BAC9-35E1-B7F2-8DE97A759DF2>  /System/Library/Frameworks/AddressBook.framework/Versions/A/XPCServices/com.apple.Address Book.InternetAccountsBridge.xpc/Contents/MacOS/com.apple.AddressBook.InternetAccountsBridg e
            Process:         com.apple.AmbientDisplayAgent [243]
            Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
            Parent:          launchd [1]
            UID:             0
            Task size:       1478 pages
              Thread 0x7b2        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 269 (com.apple.AmbientDisplayAgent + 5238) [0x10f40f476] 1-11
              Thread 0x87f        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x897        11 samples (1-11)   priority 4
                    11  ??? (com.apple.AmbientDisplayAgent + 9007) [0x10f41032f] 1-11
              Binary Images:
                     0x10f40e000 -        0x10f411fff  com.apple.AmbientDisplayAgent 1.0 (1)  <6D12A516-9EF6-3845-894F-8865CB89479E>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
            Process:         com.apple.audio.DriverHelper [314]
            Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
            Parent:          launchd [1]
            Responsible:     coreaudiod [311]
            UID:             202
            Task size:       615 pages
              Thread 0x8a5        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x8a8        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10706f000 -        0x107071fff  com.apple.audio.DriverHelper 1.0 (1) <448F47AC-6EFB-34E4-891A-55D266712933>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
            Process:         com.apple.BKAgentService [462]
            Path:            /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAg entService.xpc/Contents/MacOS/com.apple.BKAgentService
            Parent:          launchd [1]
            UID:             501
            Task size:       2098 pages
              Thread 0x10cb       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x10cc       DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x105aee000 -        0x105b52fff  com.apple.BKAgentService 1.1 (255)  <FF6618DD-D599-3D50-8115-87F9BE18C49D>  /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAg entService.xpc/Contents/MacOS/com.apple.BKAgentService
            Process:         com.apple.CloudPhotosConfiguration [448]
            Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotoServicesConfiguration.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfigur ation.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
            Parent:          launchd [1]
            UID:             501
            Task size:       3677 pages
              Thread 0xf66        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 24 (com.apple.CloudPhotosConfiguration + 8536) [0x106344158] 1-11
                  11  ??? (com.apple.CloudPhotosConfiguration + 8860) [0x10634429c] 1-11
                    11  ??? (com.apple.CloudPhotosConfiguration + 9070) [0x10634436e] 1-11
              Thread 0xf6b        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x106342000 -        0x106352fff  com.apple.CloudPhotosConfiguration 1.0 (209.52.0) <C76CDB20-D9AE-3A5D-818D-AF2DC8425F0B>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotoServicesConfiguration.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfigur ation.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
            Process:         com.apple.CodeSigningHelper [254]
            Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
            Parent:          launchd [1]
            UID:             0
            Task size:       411 pages
              Thread 0x6e2        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x6e3        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1e70       11 samples (1-11)   priority 4
            *11  wq_unsuspend_continue + 0 (pthread + 18452) [0xffffff7f80f48814] (suspended) 1-11
              Binary Images:
                     0x1035d3000 -        0x1035d4fff  com.apple.CodeSigningHelper 1.0 (1) <4EB1BF4A-DE24-37D1-AAF0-F92EF4E994B4>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
            Process:         com.apple.ctkpcscd [140]
            Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
            Parent:          launchd [1]
            Responsible:     securityd [81]
            UID:             0
            Task size:       719 pages
              Thread 0x32c        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x331        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10bada000 -        0x10bae2fff  com.apple.ctkpcscd 1.0 (1)          <3FD25F21-0339-31AC-A331-5EB0C2E7E219>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
            Process:         com.apple.dock.extra [337]
            Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
            Parent:          launchd [1]
            Responsible:     Dock [307]
            UID:             501
            Task size:       5638 pages
              Thread 0x9a5        DispatchQueue 1     11 samples (1-11)   priority 46
              <thread QoS user interactive, boosted, IO policy important>
                11  ??? (com.apple.dock.extra + 7840) [0x103502ea0] 1-11
                    11  _xpc_objc_main + 793 (libxpc.dylib + 92504) [0x7fff8eefd958] 1-11
                                           *8   ipc_mqueue_receive_continue + 0 (kernel + 1148928) [0xffffff8000318800] 1-8
              <dropped boost>
                                           *3   ipc_mqueue_receive_continue + 0 (kernel + 1148928) [0xffffff8000318800] 9-11
              Thread 0x9af        DispatchQueue 2     11 samples (1-11)   priority 46
                 *8   ??? (kernel + 5989984) [0xffffff80007b6660] 1-8
              <dropped boost>
                 *3   ??? (kernel + 5989984) [0xffffff80007b6660] 9-11
              Thread 0x9cc        11 samples (1-11)   priority 46
              <dropped boost>
              Binary Images:
                     0x103501000 -        0x103505fff  com.apple.dock.extra 1.0 (1)           <A52D9E84-6FA3-3DC9-A84F-2642C4ED18D2>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
            Process:         com.apple.geod [495]
            Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
            Parent:          launchd [1]
            UID:             501
            Task size:       1459 pages
              Thread 0x1213       DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 771 (com.apple.geod + 47230) [0x10051987e] 1-11
              Thread 0x1216       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x121a       11 samples (1-11)   priority 4
                    11  _runNetworkThread + 445 (GeoServices + 2056528) [0x7fff8e79a150] 1-11
              Thread 0x121c       11 samples (1-11)   priority 4
              Thread 0x121f       11 samples (1-11)   priority 4
              Binary Images:
                     0x10050e000 -        0x10051cfff  com.apple.geod 1.0 (1077.0.18)          <93760CE6-FE8A-39DC-92C0-000B86E7CCC7>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                  0x7fff8e5a4000 -     0x7fff8e8a6fff  com.apple.GeoServices 1.0 (1077.0.18)   <2BBF8B44-DD46-3432-8C84-6D6AA004C233>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
            Process:         com.apple.iCloudHelper [366]
            Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
            Architecture:    x86_64
            Parent:          launchd [1]
            UID:             501
            Task size:       2630 pages
              Thread 0xb37        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 167 (com.apple.iCloudHelper + 15671) [0x107e6ed37] 1-11
              Thread 0xb40        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0xf78        11 samples (1-11)   priority 4
              Thread 0x1070       11 samples (1-11)   priority 4
              Binary Images:
                     0x107e6b000 -        0x107e7dfff  com.apple.iCloudHelper 1.06 (217)       <F91FBEDA-2B17-36DA-B5C0-55AAB31EAB58>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
            Process:         com.apple.ifdreader [214]
            Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
            Parent:          launchd [1]
            UID:             0
            Task size:       686 pages
              Thread 0x5d5        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 81 (com.apple.ifdreader + 3713) [0x104881e81] 1-11
              Thread 0x5f7        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x104881000 -        0x104886fff  com.apple.ifdreader 1.0 (1)            <6E6F8ECC-0539-3A6F-BB56-C7CF1660FB6F>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
            Process:         com.apple.InputMethodKit.UserDictionary [457]
            Path:            /System/Library/Frameworks/InputMethodKit.framework/Versions/A/XPCServices/com.apple.Inpu tMethodKit.UserDictionary.xpc/Contents/MacOS/com.apple.InputMethodKit.UserDictionary
            Parent:          launchd [1]
            UID:             501
            Task size:       2090 pages
              Thread 0x103c       DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 116 (com.apple.InputMethodKit.UserDictionary + 6804) [0x10ea61a94] 1-11
              Thread 0x103f       DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10ea60000 -        0x10ea6bfff  com.apple.InputMethodKit.UserDictionary 1.0 (1) <D3546409-547B-34DB-ABF3-080301C31BF9>  /System/Library/Frameworks/InputMethodKit.framework/Versions/A/XPCServices/com.apple.Inpu tMethodKit.UserDictionary.xpc/Contents/MacOS/com.apple.InputMethodKit.UserDictionary
            Process:         com.apple.internetaccounts [428]
            Path:            /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/XPCServices/com.a pple.internetaccounts.xpc/Contents/MacOS/com.apple.internetaccounts
            Parent:          launchd [1]
            UID:             501
            Task size:       6843 pages
              Thread 0xdb8        DispatchQueue 1     11 samples (1-11)   priority 46
                11  main + 252 (com.apple.internetaccounts + 6967) [0x104f20b37] 1-11
              <dropped boost>
              Thread 0xdd0        DispatchQueue 2     11 samples (1-11)   priority 46
              <dropped boost>
              Thread 0xf24        11 samples (1-11)   priority 46
              <dropped boost>
              Binary Images:
                     0x104f1f000 -        0x104f3dfff  com.apple.internetaccounts 1.0 (1)     <F34C8012-1DD1-37AE-9C9F-CDFAE0816921>  /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/XPCServices/com.a pple.internetaccounts.xpc/Contents/MacOS/com.apple.internetaccounts
            Process:         com.apple.PerformanceAnalysis.animationperfd [263]
            Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/XPCServices/com.apple.Per formanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animation perfd
            Parent:          launchd [1]
            UID:             0
            Task size:       723 pages
              Thread 0x755        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x757        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10bf8d000 -        0x10bf93fff  com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <DB05010E-99BC-3CB8-A125-0A39F859A029>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/XPCServices/com.apple.Per formanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animation perfd
            Process:         com.apple.photomodel [525]
            Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS /com.apple.photomodel
            Parent:          launchd [1]
            Responsible:     photolibraryd [458]
            UID:             501
            Task size:       3483 pages
              Thread 0x14fc       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x14fe       DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x100288000 -        0x10028afff  com.apple.photomodel 1.0 (209.52.0) <5CCE09C6-87C9-3D0A-9B66-5CA0A3EE05F4>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS /com.apple.photomodel
            Process:         com.apple.photomoments [492]
            Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/Mac OS/com.apple.photomoments
            Parent:          launchd [1]
            UID:             501
            Task size:       3704 pages
              Thread 0x11d6       DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 400 (com.apple.photomoments + 6864) [0x104d79ad0] 1-11
              Thread 0x11dc       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1212       11 samples (1-11)   priority 4
              Binary Images:
                     0x104d78000 -        0x104d7dfff  com.apple.photomoments 1.0 (209.52.0)  <BAA819C7-86A1-344A-816B-7C1AA04DF908>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/Mac OS/com.apple.photomoments
            Process:         com.apple.wifi.proxy [365]
            Path:            /System/Library/CoreServices/Menu Extras/AirPort.menu/Contents/XPCServices/com.apple.wifi.proxy.xpc/Contents/MacOS/com.appl e.wifi.proxy
            Parent:          launchd [1]
            Responsible:     SystemUIServer [309]
            UID:             501
            Task size:       862 pages
              Thread 0xb30        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 413 (com.apple.wifi.proxy + 6685) [0x102daea1d] 1-11
              Thread 0xb35        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x102dad000 -        0x102dbafff  com.apple.wifi.proxy 1.0 (1)           <416BF67D-93D8-316D-913C-08041A41B2E3>  /System/Library/CoreServices/Menu Extras/AirPort.menu/Contents/XPCServices/com.apple.wifi.proxy.xpc/Contents/MacOS/com.appl e.wifi.proxy
            Process:         configd [49]
            Path:            /usr/libexec/configd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       1578 pages
              Thread 0x1b2        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (configd + 4674) [0x104d4c242] 1-11
                  11  ??? (configd + 8462) [0x104d4d10e] 1-11
              Thread 0x1f3        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x1f4        11 samples (1-11)   priority 31
                    11  ??? (configd + 11143) [0x104d4db87] 1-11
              Thread 0x259        11 samples (1-11)   priority 31
                    11  ??? (configd + 60769) [0x104d59d61] 1-11
              Thread 0x2c2        11 samples (1-11)   priority 31
                    11  pppcntl_run_thread + 724 (PPPController + 49427) [0x105f95113] 1-11
              Thread 0x2c6        11 samples (1-11)   priority 31
              Thread 0x370        11 samples (1-11)   priority 31
                    11  ??? (EAPOLController + 11743) [0x105f36ddf] 1-11
              Binary Images:
                     0x104d4b000 -        0x104d80fff  configd (699.1.5)                                           <0B27B37F-DF61-358B-9CFB-E97E3DCA42B5>  /usr/libexec/configd
                     0x105f34000 -        0x105f39fff  com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0) <F7944BE8-BCE0-33CC-AC84-0397A1AE6868>  /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
                     0x105f89000 -        0x105fd8fff  com.apple.SystemConfiguration.PPPController 1.10 (1.10)     <B8A767ED-87F6-3805-B18E-A88A00091E10>  /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
            Process:         ConsumerTouchDriver [443]
            Path:            /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app/Contents/Ma cOS/ConsumerTouchDriver
            Parent:          launchd [1]
            UID:             501
            Task size:       3298 pages
            Process:         ContainerMetadataExtractor [456]
            Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadata Extractor.xpc/Contents/MacOS/ContainerMetadataExtractor
            Parent:          launchd [1]
            Responsible:     bird [340]
            UID:             501
            Task size:       1707 pages
              Thread 0x1014       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (ContainerMetadataExtractor + 5970) [0x10daac752] 1-11
              Thread 0x1015       DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10daab000 -        0x10daadfff  com.apple.CloudDocsDaemon.container-metadata-extractor 1.0 (1) <F98B3FB9-A288-395D-B9A8-DC2B8BF6E008>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadata Extractor.xpc/Contents/MacOS/ContainerMetadataExtractor
            Process:         ControllerMateHelper (ControllerMate Helper) [403]
            Path:            /Library/Application Support/ControllerMate/ControllerMateHelper.app/Contents/MacOS/ControllerMateHelper
            Parent:          launchd [1]
            UID:             501
            Task size:       10690 pages
            Process:         Copy [424]
            Path:            /Applications/Copy.app/Contents/MacOS/Copy
            Parent:          launchd [1]
            UID:             501
            Task size:       18378 pages
            CPU Time:        0.003s
            Process:         Core Sync [464]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/MacOS/Core Sync
            Parent:          Adobe Desktop Service [451]
            UID:             501
            Task size:       8716 pages
            Process:         coreaudiod [311]
            Path:            /usr/sbin/coreaudiod
            Parent:          launchd [1]
            UID:             202
            Sudden Term:     Dirty
            Task size:       2287 pages
              Thread 0x871        DispatchQueue 1     11 samples (1-11)   priority 63
                11  ??? (coreaudiod + 483709) [0x10dd9317d] 1-11
              Thread 0x889        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x9d9        11 samples (1-11)   priority 61
                    11  ??? (coreaudiod + 543457) [0x10dda1ae1] 1-11
                      11  ??? (coreaudiod + 503689) [0x10dd97f89] 1-11
              Binary Images:
                     0x10dd1d000 -        0x10ddf8fff  coreaudiod (375.10)                    <B13B8EFE-E4B9-3098-BA78-FCA9255741F3>  /usr/sbin/coreaudiod
            Process:         coreduetd [69]
            Path:            /usr/libexec/coreduetd
            Parent:          launchd [1]
            UID:             0
            Task size:       2872 pages
              Thread 0x1c6        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (coreduetd + 147344) [0x10f8dff90] 1-11
              Thread 0x31c        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10f8bc000 -        0x10f92ffff  coreduetd (154.1.14)                   <95EA195F-0B15-370D-AC2E-81B5A12F9CB0>  /usr/libexec/coreduetd
            Process:         coreservicesd [139]
            Path:            /System/Library/CoreServices/coreservicesd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       2422 pages
              Thread 0x2dc        DispatchQueue 1     11 samples (1-11)   priority 31
                11  _CoreServicesServerMain + 721 (CarbonCore + 605314) [0x7fff98fbdc82] 1-11
              Thread 0x2dd        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x2e0        11 samples (1-11)   priority 31
                    11  fmodWatchConsumer + 319 (CarbonCore + 323528) [0x7fff98f78fc8] 1-11
              Thread 0x2e1        11 samples (1-11)   priority 31
                    11  read + 10 (libsystem_kernel.dylib + 95874) [0x7fff8f3a6682] 1-11
                             *11  ??? (kernel + 3659648) [0xffffff800057d780] 1-11
                               *11  ??? (kernel + 6143287) [0xffffff80007dbd37] 1-11
              Binary Images:
                     0x1055e3000 -        0x1055e3fff  coreservicesd (1108.6)                            <AB6CADDA-87BC-3574-8B0D-7424FB14337E>  /System/Library/CoreServices/coreservicesd
                  0x7fff98f2a000 -     0x7fff99211fff  com.apple.CoreServices.CarbonCore 1108.6 (1108.6) <8953580E-7857-33B2-AA64-98296830D3A8>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            Process:         CoreServicesUIAgent [328]
            Path:            /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
            Parent:          launchd [1]
            UID:             501
            Task size:       3556 pages
              Thread 0x946        DispatchQueue 1     11 samples (1-11)   priority 31
              Thread 0x969        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xa06        11 samples (1-11)   priority 37
              <thread QoS user initiated, IO policy important>
              Binary Images:
                     0x10be6a000 -        0x10be8efff  com.apple.coreservices.uiagent 134.7 (134.7) <A8CF4852-8693-3703-9190-D19FFB5AA897>  /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
            Process:         corestoraged [216]
            Path:            /usr/libexec/corestoraged
            Parent:          launchd [1]
            UID:             0
            Task size:       751 pages
              Thread 0x5e0        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (corestoraged + 8168) [0x103b3ffe8] 1-11
              Thread 0x5f3        DispatchQueue 2     11 samples (1-11)   priority 31
                 *11  ??? (kernel + 5989984) [0xffffff80007b6660] 1-11
              Binary Images:
                     0x103b3e000 -        0x103b45fff  corestoraged (471.20.7)                <A9DDB248-D377-35EA-A0B2-C5C483A34682>  /usr/libexec/corestoraged
            Process:         crashpad_handler [322]
            Path:            /Applications/Google Chrome.app/Contents/Versions/42.0.2311.135/Google Chrome Framework.framework/Helpers/crashpad_handler
            Parent:          launchd [1]
            Responsible:     Google Chrome (Chrome) [303]
            UID:             501
            Task size:       1335 pages
              Thread 0x915        DispatchQueue 1     11 samples (1-11)   priority 31
              11  ??? (crashpad_handler + 4116) [0x10654e014] 1-11
                11  ??? (crashpad_handler + 16627) [0x1065510f3] 1-11
                  11  ??? (crashpad_handler + 13214) [0x10655039e] 1-11
                    11  ??? (crashpad_handler + 165120) [0x106575500] 1-11
                      11  ??? (crashpad_handler + 163982) [0x10657508e] 1-11
                         *11  ipc_mqueue_receive_continue + 0 (kernel + 1148928) [0xffffff8000318800] 1-11
              Thread 0x928        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x927        11 samples (1-11)   priority 31
                    11  ??? (crashpad_handler + 6920) [0x10654eb08] 1-11
                      11  ??? (crashpad_handler + 181752) [0x1065795f8] 1-11
              Binary Images:
                     0x10654d000 -        0x10658cfff  crashpad_handler                    <52048AA5-8001-3712-97E4-B5753EF4C448>  /Applications/Google Chrome.app/Contents/Versions/42.0.2311.135/Google Chrome Framework.framework/Helpers/crashpad_handler
            Process:         CrashReporterSupportHelper [433]
            Path:            /System/Library/CoreServices/CrashReporterSupportHelper
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       692 pages
              Thread 0xded        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (CrashReporterSupportHelper + 9075) [0x10c36a373] 1-11
              Thread 0xdf3        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10c368000 -        0x10c36afff  CrashReporterSupportHelper (631)       <D3D2AFDD-ED23-3C7C-A2E1-419A2EC4D077>  /System/Library/CoreServices/CrashReporterSupportHelper
            Process:         ctkd [157]
            Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
            Parent:          launchd [1]
            UID:             0
            Task size:       712 pages
              Thread 0x349        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x34c        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10aa32000 -        0x10aa38fff  ctkd (22.20.4)                      <1E7E7628-D7C7-3D2F-8594-7DACEAB40E3B>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
            Process:         CVMCompiler [257]
            Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Parent:          launchd [1]
            UID:             212
            Sudden Term:     Dirty
            Task size:       2160 pages
              Thread 0x717        DispatchQueue 11    11 samples (1-11)   priority 31
              Thread 0x718        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x106d88000 -        0x106d8cfff  CVMCompiler (79.1)                  <19E0A278-E949-365B-BB3C-62259DDB24D2>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Process:         CVMCompiler [293]
            Parent:          launchd [1]
            UID:             92
            Sudden Term:     Dirty
            Task size:       5217 pages
              Thread 0x7f8        DispatchQueue 11    11 samples (1-11)   priority 31
              Thread 0x7f9        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x1070db000 -        0x1070dffff  CVMCompiler (79.1)                  <19E0A278-E949-365B-BB3C-62259DDB24D2>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Process:         CVMCompiler [358]
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Dirty
            Task size:       8169 pages
              Thread 0xab3        DispatchQueue 11    11 samples (1-11)   priority 31
                 *11  ??? (kernel + 6143696) [0xffffff80007dbed0] 1-11
              Thread 0xab4        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x106fb4000 -        0x106fb8fff  CVMCompiler (79.1)                  <19E0A278-E949-365B-BB3C-62259DDB24D2>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Process:         CVMCompiler [370]
            Architecture:    i386
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Dirty
            Task size:       4261 pages
              Thread 0xc04        11 samples (1-11)   priority 31
              11  _dispatch_sig_thread + 44 (libdispatch.dylib + 76102) [0x942e6946] 1-11
                11  _dispatch_sigsuspend + 25 (libdispatch.dylib + 76127) [0x942e695f] 1-11
                  11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 105498) [0x9a04cc1a] 1-11
              Thread 0xc05        11 samples (1-11)   priority 31
              Binary Images:
                         0xbc000 -            0xc0fff  CVMCompiler (79.1)                  <66E73F35-9F9F-3D84-84AC-7DACFF553F8F>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Process:         CVMServer [241]
            Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty
            Task size:       378 pages
            Note:            2 idle work queue threads omitted
              Thread 0x6b7        DispatchQueue 11    11 samples (1-11)   priority 31
              Thread 0x6b9        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x103747000 -        0x103750fff  CVMServer (79.1)                    <28A968A4-A557-3C0B-9F2E-E45313EE1F92>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
            Process:         deleted [316]
            Path:            /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
            Parent:          launchd [1]
            UID:             0
            Task size:       850 pages
              Thread 0x8bc        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x8c6        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x10bd8c000 -        0x10bd96fff  deleted (17.20.4)                   <8CB5C42E-CA6E-3B0C-8219-FFAD953608D5>  /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
            Process:         diagnosticd [126]
            Path:            /usr/libexec/diagnosticd
            Parent:          launchd [1]
            UID:             0
            Task size:       293 pages (+282)
            CPU Time:        0.008s
            Note:            3 idle work queue threads omitted
              Thread 0x260        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x271        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x10ab5c000 -        0x10ab63fff  diagnosticd (72.20.1)               <61FE6402-4FC2-3675-AEEF-91357FB02746>  /usr/libexec/diagnosticd
            Process:         diagnostics_agent [415]
            Path:            /System/Library/CoreServices/diagnostics_agent
            Parent:          launchd [1]
            UID:             501
            Task size:       2172 pages
              Thread 0xd47        DispatchQueue 1     11 samples (1-11)   priority 4
              <thread QoS background, darwinbg, timers coalesced, IO policy throttle>
                11  ??? (diagnostics_agent + 21224) [0x10bac32e8] 1-11
              Thread 0xeb9        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10babe000 -        0x10bad9fff  diagnostics_agent (631)                <56C9DF0E-60A2-3A88-BE03-CE9C2280FAB7>  /System/Library/CoreServices/diagnostics_agent
            Process:         DictationIM [368]
            Path:            /System/Library/Input Methods/DictationIM.app/Contents/MacOS/DictationIM
            Parent:          launchd [1]
            UID:             501
            Task size:       5515 pages
              Thread 0xbd1        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (DictationIM + 60000) [0x106389a60] 1-11
              Thread 0xbea        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xbf3        11 samples (1-11)   priority 31
                      11  ??? (DictationIM + 103942) [0x106394606] 1-11
              Thread 0xc07        11 samples (1-11)   priority 37
              Binary Images:
                     0x10637b000 -        0x1063d1fff  com.apple.inputmethod.ironwood 1.6.1 (1.6.1) <79125322-907C-30FC-9D65-B8867CB9A96D>  /System/Library/Input Methods/DictationIM.app/Contents/MacOS/DictationIM
            *0xffffff8000200000 - 0xffffff80009fffff  kernel (2782.20.48)                          <4B3A11F4-77AA-3D27-A22D-81A1BC5B504D>  /System/Library/Kernels/kernel
            Process:         discoveryd [76]
            Path:            /usr/libexec/discoveryd
            Parent:          launchd [1]
            UID:             65
            Task size:       2129 pages
              Thread 0x1cd        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (discoveryd + 9133) [0x10ad1e3ad] 1-11
              Thread 0x33a        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x51e        DispatchQueue 12    11 samples (1-11)   priority 37
              <thread QoS user initiated, timers coalesced, IO policy important>
                          11  ??? (discoveryd + 284830) [0x10ad6189e] 1-11
              Thread 0x521        DispatchQueue 12    11 samples (1-11)   priority 37
              Thread 0x52d        DispatchQueue 12    11 samples (1-11)   priority 37
              Thread 0x52e        DispatchQueue 12    11 samples (1-11)   priority 37
              Thread 0x533        DispatchQueue 12    11 samples (1-11)   priority 37
              Thread 0x534        DispatchQueue 12    11 samples (1-11)   priority 37
              Thread 0x51d        DispatchQueue 28    11 samples (1-11)   priority 37
                        11  _dispatch_async_redirect_invoke + 650 (libdispatch.dylib + 35230) [0x7fff974d699e] 1-11
                              11  ??? (discoveryd + 282858) [0x10ad610ea] 1-11
                                11  ??? (discoveryd + 283676) [0x10ad6141c] 1-11
                                  11  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 70938) [0x7fff8f3a051a] 1-11
              Thread 0x522        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x523        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x528        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x529        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x52a        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x52b        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x52c        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x532        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x538        DispatchQueue 28    11 samples (1-11)   priority 37
              Thread 0x56b        DispatchQueue 28    11 samples (1-11)   priority 37
              Binary Images:
                     0x10ad1c000 -        0x10ae1efff  discoveryd (64.7)                      <5069C498-77F9-3736-A1D8-84477436A6F6>  /usr/libexec/discoveryd
                  0x7fff8ddda000 -     0x7fff8e172fff  com.apple.CoreFoundation 6.9 (1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff8f38f000 -     0x7fff8f3acfff  libsystem_kernel.dylib (2782.20.48)    <EAFD7BD0-0C30-3E7D-9528-F9916BA0167C>  /usr/lib/system/libsystem_kernel.dylib
                  0x7fff93d08000 -     0x7fff93d0bfff  libdyld.dylib (353.2.1)                <9EACCA38-291D-38CC-811F-7E9D1451E2D3>  /usr/lib/system/libdyld.dylib
                  0x7fff974ce000 -     0x7fff974f8fff  libdispatch.dylib (442.1.4)            <502CF32B-669B-3709-8862-08188225E4F0>  /usr/lib/system/libdispatch.dylib
            Process:         discoveryd_helper [182]
            Path:            /usr/libexec/discoveryd_helper
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       292 pages
              Thread 0x531        DispatchQueue 11    11 samples (1-11)   priority 31
              Thread 0x537        DispatchQueue 2     11 samples (1-11)   priority 31
              11  _dispatch_mgr_thread + 52 (libdispatch.dylib + 19050) [0x7fff974d2a6a] 1-11
                11  kevent64 + 10 (libsystem_kernel.dylib + 94770) [0x7fff8f3a6232] 1-11
              Binary Images:
                     0x108f5a000 -        0x108f68fff  discoveryd_helper (64.7)            <33AF8F3F-EE07-301E-A5C7-12D282670EEB>  /usr/libexec/discoveryd_helper
            Process:         diskarbitrationd [66]
            Path:            /usr/libexec/diskarbitrationd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty
            Task size:       578 pages
              Thread 0x1c3        DispatchQueue 1     11 samples (1-11)   priority 31
              11  start + 1 (libdyld.dylib + 13769) [0x7fff93d0b5c9] 1-11
                11  ??? (diskarbitrationd + 31903) [0x10f80bc9f] 1-11
                    11  CFRunLoopRunSpecific + 296 (CoreFoundation + 465880) [0x7fff8de4bbd8] 1-11
                      11  __CFRunLoopRun + 1371 (CoreFoundation + 467835) [0x7fff8de4c37b] 1-11
                        11  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 470708) [0x7fff8de4ceb4] 1-11
                          11  mach_msg_trap + 10 (libsystem_kernel.dylib + 70878) [0x7fff8f3a04de] 1-11
              Thread 0x1ff        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x10f804000 -        0x10f81afff  diskarbitrationd (268)                 <79E68552-828F-3E36-845C-8A9DBE84C9D6>  /usr/libexec/diskarbitrationd
            Process:         displaypolicyd [85]
            Path:            /usr/libexec/displaypolicyd
            Parent:          launchd [1]
            UID:             244
            Task size:       1379 pages
              Thread 0x1d6        DispatchQueue 1     11 samples (1-11)   priority 4
              <thread QoS background, darwinbg, timers coalesced, IO policy utility>
                11  ??? (displaypolicyd + 8655) [0x1009ae1cf] 1-11
              Thread 0x346        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x749        11 samples (1-11)   priority 4
                    11  ??? (displaypolicyd + 31569) [0x1009b3b51] 1-11
                      11  ??? (displaypolicyd + 27234) [0x1009b2a62] 1-11
                         *11  psynch_cvcontinue + 0 (pthread + 26908) [0xffffff7f80f4a91c] 1-11
              Thread 0x74a        11 samples (1-11)   priority 4
                    11  ??? (displaypolicyd + 32643) [0x1009b3f83] 1-11
                      11  ??? (displaypolicyd + 31709) [0x1009b3bdd] 1-11
              Thread 0x74b        11 samples (1-11)   priority 4
                    11  ??? (displaypolicyd + 72578) [0x1009bdb82] 1-11
              Binary Images:
                     0x1009ac000 -        0x1009c9fff  displaypolicyd (3.10.22)               <9A050D17-E020-3DB1-95CB-1D9289B46BF2>  /usr/libexec/displaypolicyd
            *0xffffff7f80f44000 - 0xffffff7f80f4cfff  com.apple.kec.pthread 1.0 (1)          <8365956C-8613-3ED4-BC64-0D8570D2089F>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
            Process:         distnoted [103]
            Path:            /usr/sbin/distnoted
            Parent:          launchd [1]
            UID:             241
            Task size:       582 pages
              Thread 0x1f7        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (distnoted + 17677) [0x108a3c50d] 1-11
              Thread 0x2f7        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x108a38000 -        0x108a40fff  distnoted (1153.18)                    <65486E6E-F837-34D3-B738-FB675538803C>  /usr/sbin/distnoted
            Process:         distnoted [299]
            Parent:          launchd [1]
            UID:             501
            Task size:       1411 pages
            Note:            10 idle work queue threads omitted
              Thread 0x831        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (distnoted + 17677) [0x109be850d] 1-11
              Thread 0x83b        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x109be4000 -        0x109becfff  distnoted (1153.18)                    <65486E6E-F837-34D3-B738-FB675538803C>  /usr/sbin/distnoted
            Process:         Dock [307]
            Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
            Parent:          launchd [1]
            UID:             501
            Task size:       17148 pages (-119)
            Pageins:         1 pages
            CPU Time:        0.009s
              Thread 0x869        DispatchQueue 1     11 samples (1-11)   priority 47         cpu time 0.002s
              <frontmost, thread QoS user interactive, boosted, received importance donation from Adobe Edge Animate CC 2014.1 Helper [551], received importance donation from WindowServer [188], IO policy important>
                11  ??? (Dock + 23095) [0x1082f6a37] 1-11
                    1   __CFRunLoopRun + 2159 (CoreFoundation + 468623) [0x7fff8de4c68f] 1
                      1   __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9 (CoreFoundation + 750585) [0x7fff8de913f9] 1
                        1   _dispatch_main_queue_callback_4CF + 416 (libdispatch.dylib + 56066) [0x7fff974dbb02] 1
                                1   ??? (Dock + 824078) [0x1083ba30e] 1
                                  1   ??? (Dock + 675905) [0x108396041] 1
                                    1   ??? (Dock + 677555) [0x1083966b3] 1
                                      1   ??? (Dock + 805847) [0x1083b5bd7] 1
                                        1   _HandlePopUpMenuSelection7 + 88 (HIToolbox + 1821728) [0x7fff9af8ec20] 1
                                          1   _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned int, Point, unsigned short, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 633 (HIToolbox + 462196) [0x7fff9ae42d74] 1
                                            1   PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1877 (HIToolbox + 466113) [0x7fff9ae43cc1] 1
                                              1   FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 (HIToolbox + 612873) [0x7fff9ae67a09] 1
                                                1   SendMenuItemSelectedEvent + 188 (HIToolbox + 613168) [0x7fff9ae67b30] 1
                                                  1   SendMenuCommandWithContextAndModifiers + 59 (HIToolbox + 613261) [0x7fff9ae67b8d] 1
                                                    1   SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 428 (HIToolbox + 360261) [0x7fff9ae29f45] 1
                                                      1   SendEventToEventTarget + 40 (HIToolbox + 122038) [0x7fff9adefcb6] 1
                                                        1   SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386 (HIToolbox + 32686) [0x7fff9add9fae] 1
                                                          1   DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1260 (HIToolbox + 35692) [0x7fff9addab6c] 1
                                                            1   ??? (Dock + 676461) [0x10839626d] 1
                                                              1   ??? (Dock + 736149) [0x1083a4b95] 1
        1   ??? (Dock + 672037) [0x108395125] 1
        1   LQForceQuit + 103 (libquit.dylib + 6738) [0x7fff8ff1ba52] 1
        1   _CRProcessWillBeForceQuit + 83 (CrashReporterSupport + 24544) [0x7fff8dd35fe0] 1
        1   _CRCopyCrashHistoryForProcess + 62 (CrashReporterSupport + 24034) [0x7fff8dd35de2] 1
        1   _CRCreateDictionaryWithPath + 54 (CrashReporterSupport + 9948) [0x7fff8dd326dc] 1
        1   CreateDictionaryWithURL + 84 (CrashReporterSupport + 10055) [0x7fff8dd32747] 1
        1   CFPropertyListCreateWithStream + 181 (CoreFoundation + 735605) [0x7fff8de8d975] 1
        1   CFReadStreamRead + 413 (CoreFoundation + 736685) [0x7fff8de8ddad] 1
        *1   hndl_unix_scall64 + 22 (kernel + 2315126) [0xffffff8000435376] 1
        *1   unix_syscall64 + 662 (kernel + 6601350) [0xffffff800084ba86] 1
        *1   read_nocancel + 115 (kernel + 6210067) [0xffffff80007ec213] 1
        *1   ??? (kernel + 6210730) [0xffffff80007ec4aa] 1
        *1   ??? (kernel + 3559377) [0xffffff8000564fd1] 1
        *1   hfs_vnop_read + 616 (kernel + 5502456) [0xffffff800073f5f8] 1
        *1   cluster_read_ext + 5922 (kernel + 3355042) [0xffffff80005331a2] 1
        *1   ??? (kernel + 3371487) [0xffffff80005371df] 1
        *1   ??? (kernel + 6143321) [0xffffff80007dbd59] 1
        *1   lck_mtx_sleep + 134 (kernel + 1276342) [0xffffff80003379b6] 1
        *1   thread_block_reason + 175 (kernel + 1319343) [0xffffff80003421af] 1
        *1   ??? (kernel + 1329236) [0xffffff8000344854] 1
        *1   machine_switch_context + 367 (kernel + 2176511) [0xffffff80004135ff] 1
                    9   __CFRunLoopRun + 1371 (CoreFoundation + 467835) [0x7fff8de4c37b] 2-10
                      9   __CFRunLoopServiceMachPort + 212 (CoreFoundation + 470708) [0x7fff8de4ceb4] 2-10
                        9   mach_msg_trap + 10 (libsystem_kernel.dylib + 70878) [0x7fff8f3a04de] 2-10
                         *9   ipc_mqueue_receive_continue + 0 (kernel + 1148928) [0xffffff8000318800] 2-10
                    1   __CFRunLoopRun + 2024 (CoreFoundation + 468488) [0x7fff8de4c608] 11
                      1   __CFRunLoopDoTimers + 301 (CoreFoundation + 1221949) [0x7fff8df0453d] 11
                        1   __CFRunLoopDoTimer + 1059 (CoreFoundation + 749427) [0x7fff8de90f73] 11
                          1   __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 750308) [0x7fff8de912e4] 11
                            1   LQSendSignal + 68 (libquit.dylib + 7457) [0x7fff8ff1bd21] 11
                              1   _LSKillApplication + 105 (LaunchServices + 605235) [0x7fff9b16bc33] 11
                                1   _LSCopyApplicationInformationItem + 154 (LaunchServices + 72300) [0x7fff9b0e9a6c] 11
                                  1   _LSCopyApplicationInformation + 75 (LaunchServices + 29992) [0x7fff9b0df528] 11
                                    1   _LSCompareASNs + 115 (LaunchServices + 28841) [0x7fff9b0df0a9] 11
                                      1   DYLD-STUB$$_os_object_dealloc + 6 (libxpc.dylib + 126556) [0x7fff8ef05e5c] (running) 11
              Thread 0x899        DispatchQueue 2     11 samples (1-11)   priority 47
              Thread 0x959        11 samples (1-11)   priority 31         cpu time 0.007s
              <frontmost, thread QoS legacy, boosted, received importance donation from Adobe Edge Animate CC 2014.1 Helper [551], received importance donation from WindowServer [188], IO policy important>
              11  thread_start + 13 (libsystem_pthread.dylib + 5149) [0x7fff9004041d] 1-11
                11  _pthread_start + 176 (libsystem_pthread.dylib + 12773) [0x7fff900421e5] 1-11
                  11  _pthread_body + 131 (libsystem_pthread.dylib + 12904) [0x7fff90042268] 1-11
                    1   ??? (Dock + 172724) [0x10831b2b4] 1
                       *1   psynch_cvcontinue + 0 (pthread + 26908) [0xffffff7f80f4a91c] 1
                    2   ??? (Dock + 172878) [0x10831b34e] 2-3
                      2   ??? (Dock + 314738) [0x10833dd72] 2-3
                        2   ??? (Dock + 327128) [0x108340dd8] 2-3
                          2   ??? (Dock + 172480) [0x10831b1c0] 2-3
                            2   CGSSetBackgroundEventMaskAndShape + 106 (CoreGraphics + 762384) [0x7fff94861210] 2-3
                              2   _CGSSetBackgroundEventMaskAndShape + 161 (CoreGraphics + 575886) [0x7fff9483398e] 2-3
                                2   mach_msg_trap + 10 (libsystem_kernel.dylib + 70878) [0x7fff8f3a04de] 2-3
                                 *2   ipc_mqueue_receive_continue + 0 (kernel + 1148928) [0xffffff8000318800] 2-3
                    8   ??? (Dock + 172724) [0x10831b2b4] 4-11
                      8   __psynch_cvwait + 10 (libsystem_kernel.dylib + 90422) [0x7fff8f3a5136] 4-11
                       *8   psynch_cvcontinue + 0 (pthread + 26908) [0xffffff7f80f4a91c] 4-11
              Thread 0x2048       11 samples (1-11)   priority 31
              <frontmost, boosted, received importance donation from Adobe Edge Animate CC 2014.1 Helper [551], received importance donation from WindowServer [188], IO policy important>
              Binary Images:
                     0x1082f1000 -        0x108573fff  com.apple.dock 1.8 (1476.30)               <B2953155-AACA-3C62-BE3B-CE985DE95F35>  /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                  0x7fff8dd30000 -     0x7fff8dd3bfff  com.apple.CrashReporterSupport 10.10 (631) <D87A64FA-64B1-3B23-BB43-ADE173C108C6>  /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                  0x7fff8ff1a000 -     0x7fff8ff1bfff  libquit.dylib (182.4)                      <C8E6E06A-0D28-3084-B97A-76EF28DD7F7C>  /usr/lib/libquit.dylib
                  0x7fff9003f000 -     0x7fff90048fff  libsystem_pthread.dylib (105.10.1)         <3103AA7F-3BAE-3673-9649-47FFD7E15C97>  /usr/lib/system/libsystem_pthread.dylib
                  0x7fff947a7000 -     0x7fff94fe3fff  com.apple.CoreGraphics 1.600.0 (779.11)    <DC15AADD-387C-348E-84F0-1C8BAAB1B567>  /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                  0x7fff9b0d8000 -     0x7fff9b1fcfff  com.apple.LaunchServices 644.56 (644.56)   <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
            Process:         eprocsd [284]
            Path:            /Applications/Avira.app/Contents/eprocsd/eprocsd
            UID:             0
            Task size:       1127 pages
            Process:         filecoordinationd [345]
            Path:            /usr/sbin/filecoordinationd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       855 pages
              Thread 0xa08        DispatchQueue 2     11 samples (1-11)   priority 31
              <thread QoS legacy, timers coalesced, IO policy important>
              Thread 0xa09        DispatchQueue 11    11 samples (1-11)   priority 31
              11  _dispatch_sig_thread + 45 (libdispatch.dylib + 74669) [0x7fff974e03ad] 1-11
                11  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 91970) [0x7fff8f3a5742] 1-11
              Binary Images:
                     0x107eb6000 -        0x107ebbfff  filecoordinationd (1153.20)         <AA712440-C919-334E-ACBD-6747F62928E8>  /usr/sbin/filecoordinationd
            Process:         Finder [310]
            Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       20462 pages
            Note:            1 idle work queue threads omitted
              Thread 0x86d        DispatchQueue 1     11 samples (1-11)   priority 4-46
              <thread QoS user interactive, boosted, IO policy important, priority 46>
                11  ??? (Finder + 25554) [0x107b523d2] 1-11
              <dropped boost, suppressed, timers limited, IO policy standard, priority 4>
              Thread 0x8a7        DispatchQueue 2     11 samples (1-11)   priority 4-46
              Thread 0xd4f        11 samples (1-11)   priority 4-46
              Thread 0x1131       11 samples (1-11)   priority 4-31
              <boosted, IO policy important, priority 31>
              11  ??? [0xdeadbea7dad] 1-11
                11  ??? [0x108648999] 1-11
                  11  thread_suspend + 71 (libsystem_kernel.dylib + 54902) [0x7fff8f39c676] 1-11
                     *8   special_handler_continue + 0 (kernel + 1420816) [0xffffff800035ae10] (suspended) 1-8
                     *3   special_handler_continue + 0 (kernel + 1420816) [0xffffff800035ae10] (suspended) 9-11
              Thread 0x1137       11 samples (1-11)   priority 4-31
              <thread QoS legacy, boosted, IO policy important, priority 31>
                    11  __NSThread__main__ + 1345 (Foundation + 257474) [0x7fff92953dc2] 1-11
                      11  -[NSConnection run] + 152 (Foundation + 1199024) [0x7fff92a39bb0] 1-11
              Thread 0x113d       11 samples (1-11)   priority 4-31
              Thread 0x147e       11 samples (1-11)   priority 4-31
                11  ??? [0x1082dd83f] 1-11
              Thread 0x158c       11 samples (1-11)   priority 4-31
                    11  thread_start(_tagBRTTHR*) + 97 (libBrt.dylib + 910945) [0x10f019661] 1-11
                      11  __timer_process(unsigned int, _tagVariant*) + 1097 (libBrt.dylib + 923129) [0x10f01c5f9] 1-11
                        11  brt_svcthr_wait_2(_tagBRTSVCTHR*, unsigned int) + 46 (libBrt.dylib + 905406) [0x10f0180be] 1-11
                          11  brt_svcthr_wait_locked_2(_tagBRTSVCTHR*, unsigned int) + 174 (libBrt.dylib + 905150) [0x10f017fbe] 1-11
                            11  osd_cond_wait(_tagBRTCOND*, _tagBRTMUTEX*, unsigned int) + 269 (libBrt.dylib + 978829) [0x10f029f8d] 1-11
                               *8   psynch_cvcontinue + 0 (pthread + 26908) [0xffffff7f80f4a91c] 1-8
                               *3   psynch_cvcontinue + 0 (pthread + 26908) [0xffffff7f80f4a91c] 9-11
              Binary Images:
                     0x107b4c000 -        0x108054fff  com.apple.finder 10.10.4 (10.10.4)     <55C0DBA2-3FC5-3747-A7FF-ACE05500E4AB>  /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
                     0x10ef3b000 -        0x10f4d2fff  libBrt.dylib (0)                       <9DEC26CA-B35F-3A80-9574-51F8621E4101>  /Library/Application Support/Copy Agent/OverlayLoader.app/Contents/Resources/Overlay-20150407144411.bundle/Contents/MacOS/l ibBrt.dylib
                  0x7fff92915000 -     0x7fff92c46fff  com.apple.Foundation 6.9 (1153.20)     <F0FF3A5D-C5B7-34A1-9319-DE1EF928E58E>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            Process:         findmydeviced [160]
            Path:            /usr/libexec/findmydeviced
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean (allows idle exit)
            Task size:       2830 pages
              Thread 0x351        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (findmydeviced + 37146) [0x10afe511a] 1-11
                  11  ??? (findmydeviced + 104739) [0x10aff5923] 1-11
                    11  -[NSRunLoop(NSRunLoop) run] + 74 (Foundation + 1073535) [0x7fff92a1b17f] 1-11
                      11  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 278 (Foundation + 592473) [0x7fff929a5a59] 1-11
              Thread 0x357        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x4e7        11 samples (1-11)   priority 4
                      11  +[NSURLConnection(Loader) _resourceLoadLoop:] + 434 (CFNetwork + 37408) [0x7fff8ec39220] 1-11
              Thread 0x7db        11 samples (1-11)   priority 4
                    11  __select + 10 (libsystem_kernel.dylib + 91130) [0x7fff8f3a53fa] 1-11
              Binary Images:
                     0x10afdc000 -        0x10b02afff  findmydeviced (24.9)                    <1DBF7E8B-7036-3F24-8118-AAA8E2334D8B>  /usr/libexec/findmydeviced
                  0x7fff8ec30000 -     0x7fff8ee3dfff  com.apple.CFNetwork 720.3.13 (720.3.13) <69E15385-5784-3912-88F6-03B16F1C1A5C>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
            Process:         fmfd [363]
            Path:            /usr/libexec/fmfd
            Parent:          launchd [1]
            UID:             501
            Task size:       3751 pages
              Thread 0xb23        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (fmfd + 27982) [0x10ae03d4e] 1-11
                  11  ??? (fmfd + 79775) [0x10ae1079f] 1-11
              Thread 0xb2b        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10adfd000 -        0x10ae3efff  fmfd (98.6)                            <BF74AB7E-4347-32EA-BFF7-CC058816136E>  /usr/libexec/fmfd
            Process:         fontd [320]
            Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       1903 pages
              Thread 0x910        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main_handler + 4440 (libATSServer.dylib + 529393) [0x7fff8e37f3f1] 1-11
                  11  CFRunLoopRun + 97 (CoreFoundation + 1218161) [0x7fff8df03671] 1-11
              Thread 0x911        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x919        11 samples (1-11)   priority 4
                    11  AsyncFileThread(void*) + 281 (CarbonCore + 455728) [0x7fff98f99430] 1-11
                      11  TSWaitOnSemaphoreCommon + 403 (CarbonCore + 698425) [0x7fff98fd4839] 1-11
                        11  TSWaitOnConditionTimedRelative + 147 (CarbonCore + 699486) [0x7fff98fd4c5e] 1-11
              Binary Images:
                     0x10b0bb000 -        0x10b0befff  fontd (375.2)                                     <57A4B43F-EEA2-3216-81C2-25EFA2CD6ED4>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                  0x7fff8e2fe000 -     0x7fff8e395fff  libATSServer.dylib (375.2)                        <8473B225-D603-3CB3-BF89-6BF31240BBF4>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libATSServer.dylib
            Process:         fseventsd [44]
            Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/Support/fseventsd
            Parent:          launchd [1]
            UID:             0
            Task size:       1117 pages
              Thread 0x1ad        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (fseventsd + 4613) [0x1012e6205] 1-11
                  11  mach_msg_server + 468 (libsystem_kernel.dylib + 69472) [0x7fff8f39ff60] 1-11
              Thread 0x1f0        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x1ee        11 samples (1-11)   priority 49
              <timers coalesced, IO policy important>
                    11  ??? (fseventsd + 47242) [0x1012f088a] 1-11
                      11  ??? (fseventsd + 46008) [0x1012f03b8] 1-11
              Thread 0x201        11 samples (1-11)   priority 31
              <thread QoS legacy, timers coalesced, IO policy important and passive>
                    11  ??? (fseventsd + 12816) [0x1012e8210] 1-11
              Thread 0x202        11 samples (1-11)   priority 50
                     *11  hndl_unix_scall64 + 22 (kernel + 2315126) [0xffffff8000435376] 1-11
                       *11  unix_syscall64 + 662 (kernel + 6601350) [0xffffff800084ba86] 1-11
                         *11  read_nocancel + 115 (kernel + 6210067) [0xffffff80007ec213] 1-11
                           *11  ??? (kernel + 6210730) [0xffffff80007ec4aa] 1-11
                                 *11  thread_block_reason + 175 (kernel + 1319343) [0xffffff80003421af] 1-11
                                   *11  ??? (kernel + 1329236) [0xffffff8000344854] 1-11
                                     *11  machine_switch_context + 367 (kernel + 2176511) [0xffffff80004135ff] 1-11
              Thread 0x203        11 samples (1-11)   priority 31
                    11  ??? (fseventsd + 31016) [0x1012ec928] 1-11
              Thread 0x9a4        11 samples (1-11)   priority 31
                    11  ??? (fseventsd + 31090) [0x1012ec972] 1-11
              Thread 0xd9a        11 samples (1-11)   priority 31
              Binary Images:
                     0x1012e5000 -        0x1012f4fff  fseventsd (1210.20.1)                  <B9298BBA-E12E-3861-8CE1-81A5B350321A>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/Support/fseventsd
            Process:         Google Chrome (Chrome) [303]
            Path:            /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
            Parent:          launchd [1]
            UID:             501
            Task size:       49910 pages
            CPU Time:        0.010s
            Process:         Google Chrome Helper (Chrome Helper) [334]
            Path:            /Applications/Google Chrome.app/Contents/Versions/42.0.2311.135/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
            Parent:          Google Chrome (Chrome) [303]
            UID:             501
            Task size:       27998 pages
            Process:         Google Chrome Helper (Chrome Helper) [351]
            UID:             501
            Task size:       40670 pages
            Process:         Google Chrome Helper (Chrome Helper) [353]
            UID:             501
            Task size:       67867 pages
            CPU Time:        0.001s
            Process:         Google Chrome Helper (Chrome Helper) [364]
            UID:             501
            Task size:       15103 pages
            Process:         Google Chrome Helper (Chrome Helper) [371]
            UID:             501
            Task size:       14700 pages
            Process:         Google Chrome Helper (Chrome Helper) [373]
            UID:             501
            Task size:       41865 pages
            Process:         Google Chrome Helper (Chrome Helper) [374]
            UID:             501
            Task size:       13888 pages
            Process:         Google Chrome Helper (Chrome Helper) [375]
            UID:             501
            Task size:       31318 pages
            Process:         Google Chrome Helper (Chrome Helper) [376]
            UID:             501
            Task size:       12239 pages
            Process:         Google Chrome Helper (Chrome Helper) [377]
            UID:             501
            Task size:       12094 pages
            Process:         Google Chrome Helper (Chrome Helper) [378]
            UID:             501
            Task size:       13150 pages
            Process:         Google Chrome Helper (Chrome Helper) [379]
            UID:             501
            Task size:       15611 pages
            Process:         Google Chrome Helper (Chrome Helper) [439]
            UID:             501
            Task size:       19092 pages
            CPU Time:        0.001s
            Process:         Google Chrome Helper (Chrome Helper) [442]
            UID:             501
            Task size:       37191 pages
            Process:         Google Chrome Helper (Chrome Helper) [468]
            UID:             501
            Task size:       21516 pages
            Process:         Google Chrome Helper (Chrome Helper) [474]
            UID:             501
            Task size:       18151 pages (+1)
            CPU Time:        0.017s
            Process:         Google Chrome Helper (Chrome Helper) [499]
            UID:             501
            Task size:       24807 pages
            CPU Time:        0.024s
            Process:         Google Chrome Helper (Chrome Helper) [504]
            UID:             501
            Task size:       24920 pages (+13)
            CPU Time:        0.001s
            Process:         Google Chrome Helper (Chrome Helper) [522]
            UID:             501
            Task size:       25152 pages
            Process:         Google Chrome Helper (Chrome Helper) [524]
            UID:             501
            Task size:       23264 pages
            Process:         Google Chrome Helper (Chrome Helper) [526]
            UID:             501
            Task size:       46707 pages (+2)
            CPU Time:        0.005s
            Process:         Google Chrome Helper (Chrome Helper) [530]
            UID:             501
            Task size:       32934 pages
            Process:         Google Chrome Helper (Chrome Helper) [562]
            UID:             501
            Task size:       37067 pages (+22)
            CPU Time:        0.002s
            Process:         Google Chrome Helper NP (Chrome Helper NP) [465]
            Path:            /Applications/Google Chrome.app/Contents/Versions/42.0.2311.135/Google Chrome Helper NP.app/Contents/MacOS/Google Chrome Helper NP
            UID:             501
            Task size:       9429 pages
            Process:         helpd [410]
            Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       1426 pages
              Thread 0xd40        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (helpd + 41486) [0x1060a820e] 1-11
              Thread 0xeb8        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10609e000 -        0x1060acfff  helpd (101.3)                          <EBBF1D6A-A092-3C7F-91A5-C4248558D7BF>  /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
            Process:         hidd [98]
            Path:            /usr/libexec/hidd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       1058 pages (+4)
              Thread 0x1e3        DispatchQueue 1     11 samples (1-11)   priority 31
              <thread QoS legacy, IO policy important>
                11  ??? (hidd + 3885) [0x10c5a6f2d] 1-11
              Thread 0x1f5        DispatchQueue 2     11 samples (1-11)   priority 63
              <IO policy important>
              Thread 0x325        11 samples (1-11)   priority 63
                    11  __IOHIDServiceRunLoopCompatibilityThread + 195 (IOKit + 229975) [0x7fff9a3fd257] 1-11
              Thread 0x1ff7       11 samples (1-11)   priority 63
                    11  _dispatch_worker_thread + 122 (libdispatch.dylib + 17512) [0x7fff974d2468] 1-11
                      11  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 70962) [0x7fff8f3a0532] 1-11
                       *11  semaphore_wait_continue + 0 (kernel + 1357760) [0xffffff800034b7c0] 1-11
              Thread 0x2049       11 samples (1-11)   priority 63
              Thread 0x205e       7 samples (5-11)    priority 63
              <Thread not seen for 4 samples, IO policy important>
              7  thread_start + 13 (libsystem_pthread.dylib + 5149) [0x7fff9004041d] 5-11
                7  _pthread_start + 176 (libsystem_pthread.dylib + 12773) [0x7fff900421e5] 5-11
                  7  _pthread_body + 131 (libsystem_pthread.dylib + 12904) [0x7fff90042268] 5-11
                    7  _dispatch_worker_thread + 122 (libdispatch.dylib + 17512) [0x7fff974d2468] 5-11
                      7  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 70962) [0x7fff8f3a0532] 5-11
                       *7  semaphore_wait_continue + 0 (kernel + 1357760) [0xffffff800034b7c0] 5-11
              Binary Images:
                     0x10c5a6000 -        0x10c5a6fff  hidd (606.20.4)                             <C962FDE5-52DC-31CE-AD27-A30FEAE090FF>  /usr/libexec/hidd
                  0x7fff9a3c5000 -     0x7fff9a437fff  com.apple.framework.IOKit 2.0.2 (1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF>  /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
            Process:         iconservicesagent [65]
            Path:            /System/Library/CoreServices/iconservicesagent
            Parent:          launchd [1]
            UID:             0
            Task size:       727 pages
              Thread 0x31f        DispatchQueue 2     11 samples (1-11)   priority 31
              <thread QoS legacy, boosted, timers coalesced, IO policy important>
              Thread 0x327        DispatchQueue 11    11 samples (1-11)   priority 31
              Binary Images:
                     0x10d5c9000 -        0x10d5c9fff  iconservicesagent (47.1)            <1D1BCBF1-4641-34C3-96AD-8AB94144A153>  /System/Library/CoreServices/iconservicesagent
            Process:         iconservicesagent [326]
            Parent:          launchd [1]
            UID:             501
            Task size:       757 pages
              Thread 0x94c        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x952        DispatchQueue 11    11 samples (1-11)   priority 4
              Binary Images:
                     0x1046ac000 -        0x1046acfff  iconservicesagent (47.1)            <1D1BCBF1-4641-34C3-96AD-8AB94144A153>  /System/Library/CoreServices/iconservicesagent
            Process:         iconservicesd [64]
            Path:            /System/Library/CoreServices/iconservicesd
            Parent:          launchd [1]
            UID:             240
              Thread 0x369        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x36a        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1c07       11 samples (1-11)   priority 4
              Binary Images:
                     0x105d86000 -        0x105d86fff  iconservicesd (47.1)                <092416DB-7AA1-323B-82E0-39C44506949A>  /System/Library/CoreServices/iconservicesd
            Process:         identityservicesd [341]
            Path:            /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/iden tityservicesd
            Parent:          launchd [1]
            UID:             501
            Task size:       4426 pages
              Thread 0x9e4        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (identityservicesd + 107146) [0x106f2e28a] 1-11
              Thread 0x9eb        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xa99        11 samples (1-11)   priority 31
              Binary Images:
                     0x106f14000 -        0x1072e2fff  com.apple.identityservicesd 10.0 (1000) <B39400A2-094F-3376-9F73-A69C37BEED47>  /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/iden tityservicesd
            Process:         Image Capture Extension [440]
            Path:            /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       11835 pages
              Thread 0xe6d        DispatchQueue 1     11 samples (1-11)   priority 46
              <dropped boost>
              Thread 0xe83        DispatchQueue 2     11 samples (1-11)   priority 46
              <dropped boost>
              Thread 0xea2        11 samples (1-11)   priority 46
              <dropped boost>
              Binary Images:
                     0x107592000 -        0x1075d8fff  com.apple.ImageCaptureExtension2 10.2 (10.2) <E55B3297-1044-3385-BDA3-96D51EC2797E>  /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
            Process:         imagent [346]
            Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
            Parent:          launchd [1]
            UID:             501
            Task size:       3770 pages
              Thread 0xa17        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (imagent + 34101) [0x100a17535] 1-11
              Thread 0xa1c        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x100a0f000 -        0x100a38fff  com.apple.imagent 10.0 (1000)          <44A765AC-386B-3FA7-BF6D-210CB685CBD5>  /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
            Process:         IMDPersistenceAgent [349]
            Path:            /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgen t.xpc/Contents/MacOS/IMDPersistenceAgent
            Parent:          launchd [1]
            UID:             501
            Task size:       1224 pages
              Thread 0xa20        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (IMDPersistenceAgent + 5770) [0x10547668a] 1-11
                  11  xpc_main + 490 (libxpc.dylib + 98400) [0x7fff8eeff060] 1-11
                    11  _xpc_objc_main + 751 (libxpc.dylib + 92462) [0x7fff8eefd92e] 1-11
              Thread 0xa2f        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x105475000 -        0x105486fff  com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000) <722F9C40-36AF-316A-B9FD-4E026B246C0D>  /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgen t.xpc/Contents/MacOS/IMDPersistenceAgent
                  0x7fff8eee7000 -     0x7fff8ef0ffff  libxpc.dylib (559.20.9)                                  <D35D0DB2-D7BD-3BE4-8378-062BFE545E1D>  /usr/lib/system/libxpc.dylib
            Process:         imklaunchagent [367]
            Path:            /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       859 pages
              Thread 0xb9d        DispatchQueue 1     11 samples (1-11)   priority 31
              <thread QoS legacy, timers coalesced, IO policy standard>
                11  ??? (imklaunchagent + 19977) [0x10c94ce09] 1-11
              Thread 0xbc3        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x1b67       11 samples (1-11)   priority 31
              <timers coalesced, IO policy standard>
              Binary Images:
                     0x10c948000 -        0x10c950fff  imklaunchagent (231.1)                 <8C683CC4-3D2C-38F9-902C-74DEF5695AE5>  /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
            Process:         iTunesHelper (iTunes Helper) [422]
            Path:            /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
            Parent:          launchd [1]
            UID:             501
            Task size:       2965 pages
              Thread 0xd52        DispatchQueue 1     11 samples (1-11)   priority 46
              <thread QoS user interactive, IO policy important>
              11  ??? (iTunesHelper + 8084) [0x10e910f94] 1-11
                11  ??? (iTunesHelper + 89336) [0x10e924cf8] 1-11
              Thread 0xd6e        DispatchQueue 2     11 samples (1-11)   priority 46
              Thread 0xd75        11 samples (1-11)   priority 46
              Binary Images:
                     0x10e90f000 -        0x10e938fff  com.apple.iTunesHelper 12.1.2 (12.1.2.27) <13279CCD-B072-3BFD-8715-4453C6F50699>  /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
            Process:         KernelEventAgent [96]
            Path:            /usr/sbin/KernelEventAgent
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       281 pages
              Thread 0x1e1        DispatchQueue 1     11 samples (1-11)   priority 31
                11  main + 711 (KernelEventAgent + 4098) [0x10a570002] 1-11
              Thread 0x1ec        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x1ed        11 samples (1-11)   priority 31
              Binary Images:
                     0x10a56f000 -        0x10a574fff  KernelEventAgent (91)                  <9E27CCCF-6B03-3064-B860-12C5DFCA0D7E>  /usr/sbin/KernelEventAgent
            Process:         kextd [43]
            Path:            /usr/libexec/kextd
            Parent:          launchd [1]
            UID:             0
            Task size:       5501 pages
              Thread 0x1ac        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (kextd + 4812) [0x10ebcb2cc] 1-11
              Thread 0x37a        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x10ebca000 -        0x10ebe6fff  kextd (384.20.1)                       <D2348FA1-FEBC-382F-8717-AB2C411E321E>  /usr/libexec/kextd
            Process:         Keychain Circle Notification [396]
            Path:            /System/Library/CoreServices/Keychain Circle Notification.app/Contents/MacOS/Keychain Circle Notification
            Parent:          launchd [1]
            UID:             501
            Task size:       4338 pages
              Thread 0xd30        DispatchQueue 1     11 samples (1-11)   priority 31
              <thread QoS legacy, IO policy standard>
              Thread 0xd64        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xe38        11 samples (1-11)   priority 37
              <thread QoS user initiated, IO policy standard>
              Binary Images:
                     0x109df5000 -        0x109dfefff  com.security.apple.Keychain-Circle-Notification 1.0 () <47A62699-23D1-37C4-9C05-6BB659470F0B>  /System/Library/CoreServices/Keychain Circle Notification.app/Contents/MacOS/Keychain Circle Notification
            Process:         LaterAgent [527]
            Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents /MacOS/LaterAgent
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       3348 pages
              Thread 0x154c       DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (LaterAgent + 4695) [0x102ed4257] 1-11
                  11  NSApplicationMain + 1832 (AppKit + 13140) [0x7fff92d89354] 1-11
                    11  -[NSApplication run] + 594 (AppKit + 551923) [0x7fff92e0cbf3] 1-11
                      11  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346 (AppKit + 593768) [0x7fff92e16f68] 1-11
                        11  _DPSNextEvent + 978 (AppKit + 596411) [0x7fff92e179bb] 1-11
                          11  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 205099) [0x7fff9ae0412b] 1-11
                            11  ReceiveNextEventCommon + 431 (HIToolbox + 205546) [0x7fff9ae042ea] 1-11
                              11  RunCurrentEventLoopInMode + 235 (HIToolbox + 206191) [0x7fff9ae0456f] 1-11
              Thread 0x154d       DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x155a       11 samples (1-11)   priority 37
                    11  _NSEventThread + 137 (AppKit + 1414763) [0x7fff92edf66b] 1-11
              Binary Images:
                     0x102ed3000 -        0x102edefff  com.apple.lateragent 1.0 (1)           <89692E28-CBD1-37B9-BE5C-AF7A94125250>  /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents /MacOS/LaterAgent
                  0x7fff92d86000 -     0x7fff93907fff  com.apple.AppKit 6.9 (1347.57)         <B214D528-7D1C-39B2-BE36-821D417A0297>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff9add2000 -     0x7fff9b0d7fff  com.apple.HIToolbox 2.1.1 (758.7)      <6711FAA9-904A-3B49-9665-FC8D13B93C42>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            Process:         launchd [1]
            Path:            /sbin/launchd
            Parent:          kernel_task [0]
            UID:             0
            Task size:       3237 pages
              Thread 0x162        DispatchQueue 10    11 samples (1-11)   priority 31
              11  start_wqthread + 13 (libsystem_pthread.dylib + 5133) [0x7fff9004040d] 1-11
                11  _pthread_wqthread + 729 (libsystem_pthread.dylib + 13879) [0x7fff90042637] 1-11
                  11  _dispatch_worker_thread3 + 91 (libdispatch.dylib + 77796) [0x7fff974e0fe4] 1-11
                    11  _dispatch_root_queue_drain + 935 (libdispatch.dylib + 18575) [0x7fff974d288f] 1-11
                      11  _dispatch_client_callout + 8 (libdispatch.dylib + 7187) [0x7fff974cfc13] 1-11
                        11  ??? (launchd + 190711) [0x10a6638f7] 1-11
                          11  au_sdev_read_aia + 557 (libbsm.0.dylib + 60012) [0x7fff98e0ca6c] 1-11
                            11  fgetc + 52 (libsystem_c.dylib + 247124) [0x7fff8eb7c554] 1-11
                              11  __srget + 14 (libsystem_c.dylib + 274536) [0x7fff8eb83068] 1-11
                                11  __srefill1 + 24 (libsystem_c.dylib + 274251) [0x7fff8eb82f4b] 1-11
                                  11  __read_nocancel + 10 (libsystem_kernel.dylib + 90890) [0x7fff8f3a530a] 1-11
                                           *11  ??? (kernel + 3559377) [0xffffff8000564fd1] 1-11
                                             *11  spec_read + 609 (kernel + 3672849) [0xffffff8000580b11] 1-11
                                               *11  ??? (kernel + 5837892) [0xffffff8000791444] 1-11
                                                 *11  ??? (kernel + 6143321) [0xffffff80007dbd59] 1-11
                                                   *11  lck_mtx_sleep + 134 (kernel + 1276342) [0xffffff80003379b6] 1-11
              Thread 0x163        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x167        DispatchQueue 11    11 samples (1-11)   priority 31
              Thread 0x165        DispatchQueue 35    11 samples (1-11)   priority 31
                    11  _dispatch_root_queue_drain + 463 (libdispatch.dylib + 18103) [0x7fff974d26b7] 1-11
                      11  _dispatch_queue_invoke + 202 (libdispatch.dylib + 28364) [0x7fff974d4ecc] 1-11
                        11  _dispatch_queue_drain + 1100 (libdispatch.dylib + 21349) [0x7fff974d3365] 1-11
                            11  ??? (launchd + 97409) [0x10a64cc81] 1-11
              Binary Images:
                     0x10a635000 -        0x10a672fff  launchd (559.20.9)                  <7F885D63-B284-3471-B6E3-172489232C37>  /sbin/launchd
                  0x7fff8eb40000 -     0x7fff8ebccfff  libsystem_c.dylib (1044.10.1)       <86FBED7A-F2C8-3591-AD6F-486DD57E6B6A>  /usr/lib/system/libsystem_c.dylib
                  0x7fff98dfe000 -     0x7fff98e0efff  libbsm.0.dylib (34)                 <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB>  /usr/lib/libbsm.0.dylib
            Process:         launchservicesd [79]
            Path:            /System/Library/CoreServices/launchservicesd
            Parent:          launchd [1]
            UID:             0
            Task size:       2281 pages
              Thread 0x244        DispatchQueue 11    11 samples (1-11)   priority 4
              Thread 0x245        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10bf05000 -        0x10bf0ffff  launchservicesd (644.56)            <265B08DC-F7C9-3AB7-9B84-D941D8C4C9C3>  /System/Library/CoreServices/launchservicesd
            Process:         locationd [83]
            Path:            /usr/libexec/locationd
            Parent:          launchd [1]
            UID:             205
            Task size:       2719 pages
              Thread 0x1d4        DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (locationd + 165703) [0x1097cd747] 1-11
                  11  ??? (locationd + 18804) [0x1097a9974] 1-11
                    11  ??? (locationd + 17587) [0x1097a94b3] 1-11
              Thread 0x38f        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x3c9        11 samples (1-11)   priority 4
                    11  ??? (locationd + 1398258) [0x1098fa5f2] 1-11
              Thread 0x3ce        11 samples (1-11)   priority 4
                    11  ??? (locationd + 145507) [0x1097c8863] 1-11
              Thread 0x3cf        11 samples (1-11)   priority 4
                    11  ??? (locationd + 145521) [0x1097c8871] 1-11
                      11  ??? (locationd + 150118) [0x1097c9a66] 1-11
                        11  ??? (locationd + 143784) [0x1097c81a8] 1-11
                          11  ??? (locationd + 144547) [0x1097c84a3] 1-11
                            11  __psynch_cvwait + 10 (libsystem_kernel.dylib + 90422) [0x7fff8f3a5136] 1-11
              Thread 0x3d0        11 samples (1-11)   priority 4
                    11  ??? (locationd + 145535) [0x1097c887f] 1-11
                      11  kevent + 10 (libsystem_kernel.dylib + 94746) [0x7fff8f3a621a] 1-11
              Thread 0x1bf6       11 samples (1-11)   priority 4
              Thread 0x1c0d       11 samples (1-11)   priority 4
              Binary Images:
                     0x1097a5000 -        0x109be9fff  locationd (1615.24)                     <E6A1B272-5762-3F69-9D0B-E046A930DD6B>  /usr/libexec/locationd
            Process:         logind [95]
            Path:            /System/Library/CoreServices/logind
            Parent:          launchd [1]
            UID:             0
            Task size:       701 pages
              Thread 0x1e0        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (logind + 6595) [0x102c299c3] 1-11
              Thread 0x21a        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x102c28000 -        0x102c2efff  logind (23.3)                          <727B331E-D3A7-380E-AF94-6AEB80993202>  /System/Library/CoreServices/logind
            Process:         loginwindow [94]
            Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
            Parent:          launchd [1]
            UID:             501
            Task size:       5350 pages
              Thread 0x1df        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (loginwindow + 22755) [0x106fe78e3] 1-11
              Thread 0x54d        DispatchQueue 2     11 samples (1-11)   priority 31
              Binary Images:
                     0x106fe2000 -        0x10707cfff  com.apple.loginwindow 10.4 (10.4)      <66748489-BF5B-3A2B-8A19-2711537A4BCB>  /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
            Process:         lsuseractivityd [329]
            Path:            /System/Library/CoreServices/lsuseractivityd
            Parent:          launchd [1]
            UID:             501
            Task size:       1172 pages
              Thread 0x95a        DispatchQueue 1     11 samples (1-11)   priority 3
                11  ??? (lsuseractivityd + 10200) [0x10ea8a7d8] 1-11
              Thread 0x96e        DispatchQueue 2     11 samples (1-11)   priority 4
              Binary Images:
                     0x10ea88000 -        0x10eabdfff  lsuseractivityd (644.56)               <D77926F9-5FE7-39CA-88BC-7DAE9004A730>  /System/Library/CoreServices/lsuseractivityd
            Process:         mapspushd [430]
            Path:            /System/Library/CoreServices/mapspushd
            Parent:          launchd [1]
            UID:             501
            Task size:       2236 pages
              Thread 0xdc0        DispatchQueue 1     11 samples (1-11)   priority 4
                11  main + 210 (mapspushd + 5856) [0x10644f6e0] 1-11
                  11  -[MapsPushDaemonLocalProxy runServer] + 171 (mapspushd + 37274) [0x10645719a] 1-11
              Thread 0xddd        DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0xdf5        11 samples (1-11)   priority 4
              Thread 0xdfc        11 samples (1-11)   priority 4
              Binary Images:
                     0x10644e000 -        0x10645ffff  mapspushd (1844.0.15)                   <69691DD7-2D95-364D-A663-8B0A8511E8C7>  /System/Library/CoreServices/mapspushd
            Process:         maspushagent [432]
            Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/maspushagent
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       1629 pages
              Thread 0xddc        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xdde        DispatchQueue 11    11 samples (1-11)   priority 31
              Binary Images:
                     0x10315c000 -        0x103160fff  maspushagent (376.24)               <A3657798-D515-3DDF-85C8-7A18719966E7>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/maspushagent
            Process:         mdflagwriter [532]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       234 pages
              Thread 0x1605       DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x1607       DispatchQueue 11    11 samples (1-11)   priority 31
              Binary Images:
                     0x10d2c9000 -        0x10d2cafff  mdflagwriter (917.35)               <C6DF9F9A-E0C5-3F22-916D-EE308A91876F>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
            Process:         mds [60]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
            Parent:          launchd [1]
            UID:             0
            Task size:       11950 pages
              Thread 0x1bd        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (mds + 41145) [0x10ba000b9] 1-11
              Thread 0x54c        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x576        11 samples (1-11)   priority 50
              <timers coalesced, IO policy important and passive>
              Thread 0x2001       11 samples (1-11)   priority 31
            *11  wq_unsuspend_continue + 0 (pthread + 18452) [0xffffff7f80f48814] (suspended) 1-11
              Binary Images:
                     0x10b9f6000 -        0x10bb66fff  mds (917.35)                           <379457A0-F98A-37E4-B15C-13839599FA99>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
            Process:         mds_stores [203]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mds_stores
            Architecture:    x86_64
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty
            Task size:       37310 pages (+1)
              Thread 0x5a4        DispatchQueue 1     11 samples (1-11)   priority 31
                11  ??? (mds_stores + 19319) [0x105002b77] 1-11
              Thread 0x5ad        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0x204b       11 samples (1-11)   priority 31
              Binary Images:
                     0x104ffe000 -        0x105043fff  mds_stores (917.35)                    <53A0F4C7-5E70-3CF4-9697-A0821171FB9D>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mds_stores
            Process:         mdworker [505]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       1984 pages
              Thread 0x139f       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x109522619] 1-11
              Thread 0x13a4       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x13e9       11 samples (1-11)   priority 4
              <thread QoS maintenance, darwinbg, timers coalesced, IO policy throttle>
                    11  ??? (mdworker + 40377) [0x109523db9] 1-11
                      11  ??? (mdworker + 52471) [0x109526cf7] 1-11
              Binary Images:
                     0x10951a000 -        0x10957bfff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [507]
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       4154 pages
              Thread 0x13d0       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x10d3b2619] 1-11
              Thread 0x13de       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x13ea       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 40377) [0x10d3b3db9] 1-11
                      11  ??? (mdworker + 52471) [0x10d3b6cf7] 1-11
              Thread 0x1502       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 135251) [0x10d3cb053] 1-11
              Binary Images:
                     0x10d3aa000 -        0x10d40bfff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [508]
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       4953 pages
              Thread 0x13d1       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x10fd98619] 1-11
              Thread 0x13df       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1403       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 40377) [0x10fd99db9] 1-11
                      11  ??? (mdworker + 52471) [0x10fd9ccf7] 1-11
              Thread 0x14c1       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 135251) [0x10fdb1053] 1-11
              Binary Images:
                     0x10fd90000 -        0x10fdf1fff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [509]
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       5694 pages
              Thread 0x13eb       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x106ac0619] 1-11
              Thread 0x13ed       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1405       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 40377) [0x106ac1db9] 1-11
                      11  ??? (mdworker + 52471) [0x106ac4cf7] 1-11
              Thread 0x14d2       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 135251) [0x106ad9053] 1-11
              Binary Images:
                     0x106ab8000 -        0x106b19fff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [510]
            Parent:          launchd [1]
            UID:             501
            Sudden Term:     Clean
            Task size:       5565 pages
              Thread 0x13ec       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x104b6d619] 1-11
              Thread 0x13ee       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1414       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 40377) [0x104b6edb9] 1-11
                      11  ??? (mdworker + 52471) [0x104b71cf7] 1-11
              Thread 0x1576       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 135251) [0x104b86053] 1-11
              Binary Images:
                     0x104b65000 -        0x104bc6fff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [543]
            Parent:          launchd [1]
            UID:             89
            Sudden Term:     Clean
            Task size:       1584 pages
              Thread 0x1a39       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x10e7d5619] 1-11
              Thread 0x1a3b       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1a47       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 40377) [0x10e7d6db9] 1-11
                      11  ??? (mdworker + 52471) [0x10e7d9cf7] 1-11
              Binary Images:
                     0x10e7cd000 -        0x10e82efff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [544]
            Parent:          launchd [1]
            UID:             89
            Sudden Term:     Clean
            Task size:       2029 pages
              Thread 0x1a3a       DispatchQueue 1     11 samples (1-11)   priority 4
                11  ??? (mdworker + 34329) [0x10b716619] 1-11
              Thread 0x1a3c       DispatchQueue 2     11 samples (1-11)   priority 4
              Thread 0x1a46       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 40377) [0x10b717db9] 1-11
                      11  ??? (mdworker + 52471) [0x10b71acf7] 1-11
              Thread 0x1a4a       11 samples (1-11)   priority 4
                    11  ??? (mdworker + 135251) [0x10b72f053] 1-11
              Binary Images:
                     0x10b70e000 -        0x10b76ffff  mdworker (917.35)                      <756B54E9-BB47-3904-AAEB-1689062CCA5C>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         MIDIServer [435]
            Path:            /System/Library/Frameworks/CoreMIDI.framework/MIDIServer
            Parent:          launchd [1]
            UID:             501
            Task size:       974 pages
              Thread 0xe36        DispatchQueue 1     11 samples (1-11)   priority 46
                11  ??? (MIDIServer + 3796) [0x10420bed4] 1-11
                  11  MIDIServerRun + 705 (CoreMIDI + 63720) [0x1042238e8] 1-11
              Thread 0xe39        DispatchQueue 2     11 samples (1-11)   priority 31
              Thread 0xe48        11 samples (1-11)   priority 97
                    11  CAPThread::Entry(CAPThread*) + 109 (CoreMIDI + 60043) [0x104222a8b] 1-11
                      11  XThread::RunHelper(void*) + 10 (CoreMIDI + 61018) [0x104222e5a] 1-11
                        11  TimerTaskMgr::Run() + 421 (CoreMIDI + 164363) [0x10423c20b] 1-11
                          11  CAGuard::WaitUntil(unsigned long long) + 110 (CoreMIDI + 58030) [0x1042222ae] 1-11
                            11  CAGuard::WaitFor(unsigned long long) + 124 (CoreMIDI + 57830) [0x1042221e6] 1-11
              Thread 0xe49        11 samples (1-11)   priority 97
                        11  DriverIOThread::Run() + 43 (CoreMIDI + 136331) [0x10423548b] 1-11
                          11  sleep + 42 (libsystem_c.dylib + 519613) [0x7fff8ebbedbd] 1-11
                            11  __semwait_signal + 10 (libsystem_kernel.dylib + 91274) [0x7fff8f3a548a] 1-11
              Thread 0xe81        11 samples (1-11)   priority 97
                        11  MIDIIOThread::Run() + 120 (CoreMIDI + 94660) [0x10422b1c4] 1-11
                          11  XServerMachPort::ReceiveMessage(int&, void*, int&) + 125 (CoreMIDI + 56763) [0x104221dbb] 1-11
              Binary Images:
                     0x10420b000 -        0x10420bfff  MIDIServer (145.4)                      <68049309-E734-34EA-BE58-488AD0858443>  /System/Library/Frameworks/CoreMIDI.framework/MIDIServer
                     0x104214000 -        0x10424bfff  com.apple.audio.midi.CoreMIDI 1.10 (88) <4BBCD304-C28F-3C03-AEB8-5E3D5D030602>  /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
            Process:         nehelper [211]
            Path:            /usr/libexec/nehelper
            Parent:          launchd [1]
            UID:   &
