2 Replies Latest reply on Nov 25, 2017 2:22 AM by christianc78626444
    Lightroom 6 stops installation. "Installier cannpt be initialized, please download Adobe Support Advisor"
    ruediger11111
      Second day of the misery. No idea how to fix this. I downloaded the upgrade from Lightroom 5 to 6 and got serial and everything. However while running the setup, the installer stops with the error message  "Installier cannpt be initialized, please download Adobe Support Advisor". The link to the Sode Support Advisor just tells me that the Advisor is discontinued.
      Anyone got an idea where the problem could be? Is Adobe somehow not supporting Lightroom 6 as stand alone any more?
        • 1. Re: Lightroom 6 stops installation. "Installier cannpt be initialized, please download Adobe Support Advisor"
          ruediger11111 Level 1
          would like to attach a log file, but can't figure out how, except in text. here it is:
          anyone any idea where the problem could be?
          05/03/15 19:24:11:692 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | Build Version - 8.0.0.160
          05/03/15 19:24:11:692 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | Logging Level verbosity Set  to 4
          05/03/15 19:24:11:699 | [INFO] |  | ASU | Setup |  |  |  | 5660 | Event Guid generated is: 'ae456e77-1d15-4fd9-ab3b-dc3a25ecf8fe'
          05/03/15 19:24:11:699 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | Start Adobe Setup
          05/03/15 19:24:11:699 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | TimeLog: Bootstrapper Start
          05/03/15 19:24:11:699 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | TimeLog: Start initial checks
          05/03/15 19:24:11:700 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | Dictionary Path: C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\resources\Dictionary\de_DE\stringTable.zdct
          05/03/15 19:24:11:703 | [INFO] |  | ASU | Setup | PIM |  |  | 5660 | XML is valid
          05/03/15 19:24:11:703 | [WARN] |  | ASU | Setup | PIM |  |  | 5660 | Failed to find Node
          05/03/15 19:24:11:704 | [INFO] |  | ASU | Setup |  |  |  | 4528 | Event with guid 'ae456e77-1d15-4fd9-ab3b-dc3a25ecf8fe' is being sent
          05/03/15 19:24:11:723 | [INFO] |  | ASU | Setup |  |  |  | 4528 | GetIEProxyInfo - No default proxy present on the user machine
          05/03/15 19:24:11:723 | [INFO] |  | ASU | Setup |  |  |  | 4528 | GetIEProxyInfo - proxy Url is
          05/03/15 19:24:11:749 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | Build Version - 8.0.0.161
          05/03/15 19:24:11:750 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | Logging Level verbosity Set  to 4
          05/03/15 19:24:11:750 | [INFO] |  | ASU | PIM | Utilities |  |  | 5308 | Folder does not exist
          05/03/15 19:24:11:750 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | Build Version - 8.0.0.161
          05/03/15 19:24:11:750 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | CREATE PIM Instance ...
          05/03/15 19:24:11:753 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | trying to createOrUpdatePIMDbSchema.
          05/03/15 19:24:11:773 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | SUCCESS Created Tables.
          05/03/15 19:24:11:773 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | PIM Database is Up To Date.
          05/03/15 19:24:11:773 | [INFO] |  | ASU | PIM | PIM |  |  | 5308 | Updater Inventory location:C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\resources\updaterinventory.dll
          05/03/15 19:24:11:774 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | TimeLog: End initial checks
          05/03/15 19:24:11:776 | [INFO] |  | ASU | Setup | Setup |  |  | 3800 | TimeLog: Begin Installing
          05/03/15 19:24:11:776 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Current OS version is: Major:6, Minor:1, ServicePack:1
          05/03/15 19:24:12:299 | [INFO] |  | ASU | Setup |  |  |  | 3684 | HTTP Request Status code 200.
          05/03/15 19:24:12:299 | [INFO] |  | ASU | Setup |  |  |  | 4528 | The http request returned HTTP_Status:0 HttpCommunicator error:0
          05/03/15 19:24:13:152 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | trying to createOrUpdatePIMDbSchema.
          05/03/15 19:24:13:153 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Current db schema version on machine 2.
          05/03/15 19:24:13:154 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Current db schema version to install 1.
          05/03/15 19:24:13:154 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS Created Tables.
          05/03/15 19:24:13:154 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PIM Database is Up To Date.
          05/03/15 19:24:13:169 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:171 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:176 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Package id 2079F15B-0A29-45EC-9A38-0AA7982F81E9 is a old Package, new is installed on the system. Size required: 948786
          05/03/15 19:24:13:185 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:186 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:190 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Package id F5C0E8F3-C5AE-4231-85E5-826BE4A4053D is a old Package, new is installed on the system. Size required: 2746961
          05/03/15 19:24:13:199 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:199 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:200 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Package id ED0F0E42-0710-43F4-92E4-B46CF7362E08 is a old Package, new is installed on the system. Size required: 268601
          05/03/15 19:24:13:202 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:203 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:203 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Same Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is installed on the system. This will be repaired. Size required: 4726256
          05/03/15 19:24:13:206 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:206 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:207 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Same Package id 68BF9F96-CC6F-4CC1-9C3B-D8F28853EB6E is installed on the system. This will be repaired. Size required: 14487367
          05/03/15 19:24:13:209 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:209 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:210 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Same Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is installed on the system. This will be repaired. Size required: 10972666
          05/03/15 19:24:13:215 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:215 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:218 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Package id 76FE3BB4-67F4-4A5B-B90B-1235B9FD1E92 is a old Package, new is installed on the system. Size required: 2576348
          05/03/15 19:24:13:221 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:222 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:222 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Package id 20BCB906-2602-4AD6-9778-82F978A95529 is a old Package, new is installed on the system. Size required: 116733
          05/03/15 19:24:13:224 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:224 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:224 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Same Package id BDD435DF-A1F7-4D60-BA9D-4366B5AC5C7A is installed on the system. This will be repaired. Size required: 894221
          05/03/15 19:24:13:227 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:227 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:230 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | PackageCheck: Package id 577CD58F-FFC9-48EF-B2B7-D04E8141CC72 is a old Package, new is installed on the system. Size required: 6037475
          05/03/15 19:24:13:230 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 48152955
          05/03/15 19:24:13:230 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Executing Adobe Genuine Validation for all the AAM packages
          05/03/15 19:24:13:230 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\core\PDApp.pimx'
          05/03/15 19:24:13:231 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\core\PDApp.pima'
          05/03/15 19:24:13:232 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\D6\D6.pimx'
          05/03/15 19:24:13:232 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\D6\D6.pima'
          05/03/15 19:24:13:233 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DECore\DECore.pimx'
          05/03/15 19:24:13:234 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DECore\DECore.pima'
          05/03/15 19:24:13:234 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DWA\DWA.pimx'
          05/03/15 19:24:13:235 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DWA\DWA.pima'
          05/03/15 19:24:13:236 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P6\P6.pimx'
          05/03/15 19:24:13:236 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P6\P6.pima'
          05/03/15 19:24:13:238 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\LWA\LWA.pimx'
          05/03/15 19:24:13:238 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\LWA\LWA.pima'
          05/03/15 19:24:13:240 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\UWA\UWA.pimx'
          05/03/15 19:24:13:240 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\UWA\UWA.pima'
          05/03/15 19:24:13:242 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\CCM\CCM.pimx'
          05/03/15 19:24:13:242 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\CCM\CCM.pima'
          05/03/15 19:24:13:244 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\IPC\IPC.pimx'
          05/03/15 19:24:13:244 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\IPC\IPC.pima'
          05/03/15 19:24:13:246 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P7\P7.pimx'
          05/03/15 19:24:13:247 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Validating package file: 'C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P7\P7.pima'
          05/03/15 19:24:13:248 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Adobe Genuine Validation PASSED for all the AAM packages
          05/03/15 19:24:13:248 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\core\PDApp.pimx
          05/03/15 19:24:13:251 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:251 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:307 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | srcPath :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\/core/ destPath :C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp/core/
          05/03/15 19:24:13:307 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Function :copyPrimitive
          05/03/15 19:24:13:941 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\D6\D6.pimx
          05/03/15 19:24:13:944 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:13:944 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:13:984 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | srcPath :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\/D6/ destPath :C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp/D6/
          05/03/15 19:24:13:984 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Function :copyPrimitive
          05/03/15 19:24:14:692 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DECore\DECore.pimx
          05/03/15 19:24:14:695 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:14:695 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:14:727 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | srcPath :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\/DECore/ destPath :C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp/DECore/
          05/03/15 19:24:14:727 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Function :copyPrimitive
          05/03/15 19:24:14:778 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DWA\DWA.pimx
          05/03/15 19:24:14:779 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:14:779 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:14:822 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertPackageUpdateList.
          05/03/15 19:24:14:822 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertAppletRegInfoList.
          05/03/15 19:24:14:824 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:15:302 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\DWA\DWA.pimx.
          05/03/15 19:24:15:319 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P6\P6.pimx
          05/03/15 19:24:15:325 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:15:326 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:15:394 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertPackageUpdateList.
          05/03/15 19:24:15:395 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertAppletRegInfoList.
          05/03/15 19:24:16:280 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P6\P6.pimx.
          05/03/15 19:24:16:296 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\LWA\LWA.pimx
          05/03/15 19:24:16:300 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:16:300 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:16:358 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertPackageUpdateList.
          05/03/15 19:24:16:358 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertAppletRegInfoList.
          05/03/15 19:24:16:360 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:17:309 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\LWA\LWA.pimx.
          05/03/15 19:24:17:321 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\UWA\UWA.pimx
          05/03/15 19:24:17:324 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:17:324 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:17:359 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | srcPath :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\/UWA/ destPath :C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp/UWA/
          05/03/15 19:24:17:359 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Function :copyPrimitive
          05/03/15 19:24:18:233 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\CCM\CCM.pimx
          05/03/15 19:24:18:236 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:18:236 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:18:277 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | srcPath :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\/CCM/ destPath :C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp/CCM/
          05/03/15 19:24:18:277 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Function :copyPrimitive
          05/03/15 19:24:18:321 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\IPC\IPC.pimx
          05/03/15 19:24:18:321 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:18:321 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:18:348 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertPackageUpdateList.
          05/03/15 19:24:18:348 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:18:348 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS insertAppletRegInfoList.
          05/03/15 19:24:18:403 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | SUCCESS installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\IPC\IPC.pimx.
          05/03/15 19:24:18:417 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | START installPackage at file C:\Users\Ruediger\Desktop\Adobe\Photoshop Lightroom 6.0\packages\P7\P7.pimx
          05/03/15 19:24:18:418 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | XML is valid
          05/03/15 19:24:18:418 | [WARN] |  | ASU | PIM | PIM |  |  | 3800 | Failed to find Node
          05/03/15 19:24:18:441 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | srcPath :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\/P7/ destPath :C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp/P7/
          05/03/15 19:24:18:441 | [INFO] |  | ASU | PIM | PIM |  |  | 3800 | Function :copyPrimitive
          05/03/15 19:24:21:107 | [INFO] |  | ASU | Setup | Setup |  |  | 3800 | TimeLog: End Installing. Now launching PDApp
          05/03/15 19:24:21:607 | [FATAL] |  | ASU | Setup | Setup |  |  | 3800 | Adobe Application Manager executable does not exist at the location: C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp\core\PDApp.exe
          05/03/15 19:24:21:607 | [FATAL] |  | ASU | Setup | Setup |  |  | 3800 | Unable to launch PDApp. File missing
          05/03/15 19:24:21:607 | [INFO] |  | ASU | Setup |  |  |  | 3800 | Event Guid generated is: '0e6ebfb2-cce8-4239-839e-9d2f210d62b7'
          05/03/15 19:24:21:607 | [INFO] |  | ASU | Setup |  |  |  | 3800 | Event Guid generated is: '9694039e-f042-4c59-b73e-52ef1ebd2b9a'
          05/03/15 19:24:21:610 | [INFO] |  | ASU | Setup |  |  |  | 4528 | Event with guid '0e6ebfb2-cce8-4239-839e-9d2f210d62b7' is being sent
          05/03/15 19:24:21:631 | [INFO] |  | ASU | Setup |  |  |  | 4528 | GetIEProxyInfo - No default proxy present on the user machine
          05/03/15 19:24:21:631 | [INFO] |  | ASU | Setup |  |  |  | 4528 | GetIEProxyInfo - proxy Url is
          05/03/15 19:24:23:844 | [INFO] |  | ASU | PIM | PIM |  |  | 5660 | PIMSqlite closeDB status 0
          05/03/15 19:24:23:846 | [INFO] |  | ASU | PIM | PIM |  |  | 5660 | PIMSqlite closeDB status 0
          05/03/15 19:24:23:846 | [INFO] |  | ASU | PIM | PIM |  |  | 5660 | FREE PIM Instance ...
          05/03/15 19:24:23:847 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | cleanUSF: Deleting Path C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp
          05/03/15 19:24:23:847 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | Setting current directory to C:\Users\Ruediger\AppData\Local\Adobe\OOBE
          05/03/15 19:24:24:379 | [WARN] |  | ASU | Setup | Setup |  |  | 5660 | Error in deleting folder C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp\P7. Error Code:145
          05/03/15 19:24:24:429 | [ERROR] |  | ASU | Setup | Setup |  |  | 5660 | Error in deleting folder C:\Users\Ruediger\AppData\Local\Adobe\OOBE\PDApp. Error Code:145
          05/03/15 19:24:24:429 | [ERROR] |  | ASU | Setup | Setup |  |  | 5660 | Error in deleting folder C:\Users\Ruediger\AppData\Local\Adobe\OOBE. Error Code:145
          05/03/15 19:24:24:429 | [ERROR] |  | ASU | Setup | Setup |  |  | 5660 | Error in deleting folder C:\Users\Ruediger\AppData\Local\Adobe. Error Code:145
          05/03/15 19:24:24:429 | [INFO] |  | ASU | Setup | Setup |  |  | 5660 | =================  End Adobe Setup. Exit code: 1  =================
          05/03/15 19:24:24:429 | [INFO] |  | ASU | Setup |  |  |  | 5660 | Waiting for the async thread to get the task completed
          05/03/15 19:24:25:150 | [INFO] |  | ASU | Setup |  |  |  | 4276 | HTTP Request Status code 200.
          05/03/15 19:24:25:151 | [INFO] |  | ASU | Setup |  |  |  | 4528 | The http request returned HTTP_Status:0 HttpCommunicator error:0
          05/03/15 19:24:25:151 | [INFO] |  | ASU | Setup |  |  |  | 4528 | Event with guid '9694039e-f042-4c59-b73e-52ef1ebd2b9a' is being sent
          05/03/15 19:24:25:172 | [INFO] |  | ASU | Setup |  |  |  | 4528 | GetIEProxyInfo - No default proxy present on the user machine
          05/03/15 19:24:25:172 | [INFO] |  | ASU | Setup |  |  |  | 4528 | GetIEProxyInfo - proxy Url is
          05/03/15 19:24:25:684 | [INFO] |  | ASU | Setup |  |  |  | 3020 | HTTP Request Status code 200.
          05/03/15 19:24:25:685 | [INFO] |  | ASU | Setup |  |  |  | 4528 | The http request returned HTTP_Status:0 HttpCommunicator error:0
          05/03/15 19:24:25:685 | [INFO] |  | ASU | Setup |  |  |  | 4528 | Async thread is completed. Now exiting from function.
          • 2. Re: Lightroom 6 stops installation. "Installier cannpt be initialized, please download Adobe Support Advisor"
            christianc78626444
            Hello,
            Until yesterday, Lightroom 6 give me complete satisfaction. Then, I could not restart it. I uninstalled it then after downloading the version 6/6 the server I wanted to install it again. Problems encountered, Messages: Setup was unable to initialize. Download Adobe support Advisor to identify the problem. Since impossible to reinstall. Screenshots below.
