I have set up a purchase order system using dreamweaver and my own PC as a test server. The system works great. When i transfer it to the webHosing service, I get an error as indicated in the subject line of this post. I am running CF8 on my test server and the web host is using CF9. The server error log shows "
"Error","jrpp-33671","05/04/15","06:18:52","Name","'' The specific sequence of files included or processed is: D:\home\batt26.com\wwwroot\sch\POinsert.cfm, line: 64 "
at cfPOinsert2ecfm1666762724.runPage(D:\home\batt26.com\wwwroot\sch\POinsert.cfm:64)
As far as i can find from extensive googling (is that a word) it is likely a database problem. I am using Microsoft access. What is strange is that it runs line 64 and completes the data insert before it throws this error.
Below is my code, i have underlined the line in question:
<cfparam name="FORM.vend_nme" default="1">
<cfparam name="FORM.job_nme" default="1">
<cfparam name="FORM.newVendID" default="1503004">
<cfquery name="rs_vend" datasource="db_sch">
SELECT *
FROM tbl_vend
WHERE vend_recStatus ='a' OR vend_recStatus = 'u'
ORDER BY newVendID DESC
</cfquery>
<cfquery name="rs_job" datasource="db_sch">
SELECT *
FROM tbl_job
ORDER BY newJobid DESC
</cfquery>
<cfquery name="rs_allPOs" datasource="db_sch">
SELECT *
FROM tbl_po
ORDER BY po_numbr DESC
</cfquery>
<cfset todayDate = now()>
<cfif len(trim(rs_allPOs.po_numbr))NEQ 0>
<cfset lastPO = #right(rs_allPOs.po_numbr,4)#>
<cfelse>
<cfset lastPO = 0>
</cfif>
<cfset form.po_numbr ="P" & DateFormat(todayDate,"yymm") & numberFormat((lastPO+1),'0000')><!---set newVendID to yydd and last vend_id from table +1 to get newVendID--->
<!---check to see if a new vendor is being created--->
<cfif len(trim(form.vend_nme)) NEQ 0>
<cfset form.vend_creatBy = #Session.MM_userID#>
<cfif len(trim(rs_vend.newVendID))NEQ 0>
<cfset lastVendID = #right(rs_vend.newVendID,4)#>
<cfelse>
<cfset lastVendID = 0>
</cfif>
<cfset form.newVendID = 'V' & DateFormat(todayDate,"yymm") & numberFormat((lastVendID+1),'0000')><!---set newVendID to yydd and last vend_id from table +1 to get newVendID--->
line 64 <cfinsert datasource="db_sch" dbtype="ODBC" dbname="sch_po" tablename="tbl_vend" formfields=" newVendID,vend_nme,vend_creatBy">
</cfif>
<!---check to see if a new job is being created--->
<cfif len(trim(form.job_nme)) NEQ 0>
<cfset form.job_creatBy = #Session.MM_userID#>
<cfif len(trim(rs_job.newJobID))NEQ 0>
<cfset lastJobID = #right(rs_Job.newJobID,4)#>
<cfelse>
<cfset lastJobID = 0>
</cfif>
<cfset form.newJobID = 'J' & DateFormat(todayDate,"yymm") & numberFormat((lastJobID+1),'0000')><!---set newJobID to yydd and last job_id from table +1 to get newJobID--->
<cfinsert datasource="db_sch" dbtype="ODBC" dbname="sch_po" tablename="tbl_job" formfields="job_id, newJobID, job_nme, job_creatBy">
</cfif>
<cfif ((len(trim(form.job_nme)) NEQ 0) OR (len(trim(form.vend_nme)) NEQ 0))>
</cfif>
<cfquery name="rs_vend1" datasource="db_sch">
SELECT newVendID, vend_nme
FROM tbl_vend
WHERE newVendID = <cfqueryparam value="#FORM.newVendID#" cfsqltype="cf_sql_clob" maxlength="255">
</cfquery>
<cfset form.newVendID = rs_vend1.newvendid>
</cfif>
<cfquery name="rs_job1" datasource="db_sch">
SELECT job_id, newJobID, job_nme
FROM tbl_job
WHERE job_nme = <cfqueryparam value="#FORM.job_nme#" cfsqltype="cf_sql_clob" maxlength="255">
ORDER BY job_id DESC
</cfquery>
<cfset form.newjob_id = rs_job1.newJobID>
</cfif>
<cfinsert datasource="db_sch" dbtype="ODBC" tablename="tbl_po" formfields="newJobID,emp_req,newVendID,purch_amt,po_note,po_entby,po_numbr">
<cfquery name="rs_newPO" datasource="db_sch">
SELECT *
FROM qry_po
ORDER BY po_id DESC
</cfquery>
SELECT *
FROM tbl_po
</cfquery>
<cfquery name="rs_users" datasource="db_sch">
SELECT *
FROM tbl_emp
WHERE emp_id = #form.emp_req#
</cfquery>
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
<title>Untitled Document</title>
<link href="mobile.css" rel="stylesheet" type="text/css">
</head>
<p align="center"><a href="menu.cfm" class="menuBar" >Home</a> </p>
<p> </p>
<table width="450" border="1" align="center" class="mobile">
<tr>
<td width="144">PO Number:</td>
<td width="290"><cfoutput><span class="red">#form.po_numbr#</span></cfoutput></td>
</tr>
<tr>
<td>Job:</td>
<td><cfoutput>#rs_newPO.job_nme#</cfoutput></td>
</tr>
<tr>
<td>Vendor:</td>
<td><cfoutput>#rs_newPO.vend_nme#</cfoutput></td>
</tr>
<tr>
<td>Issued To:</td>
<td><cfoutput>#rs_newPO.Requested_by#</cfoutput></td>
</tr>
<tr>
<td>Approx. amount:</td>
<td><cfoutput></cfoutput><cfoutput>#rs_newPO.purch_amt#</cfoutput></td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
</table>
<!---<cfif isdefined ("rs_users.cell_ph")>
<cfset textTo = ((rs_users.cell_ph)&(rs_users.cell_carrier))>
<cfmail to="#textTo#" from="Purchase Order" subject="" replyto="New Purchase Order" server="mail.batt26.com" port="26" username="noreply@batt26.com" password="Battalion26" mailerid="Battalion 26">
<cfoutput>Job Name: #rs_newPO.job_nme#, Vendor: #rs_newPO.vend_nme#, Purchase Order Number: #rs_newPO.PO_numbr#"</cfoutput>
</cfmail>
</cfif>
</p>
<p> </p>
<p> </p>
<cfoutput>#textTo#</cfoutput>--->
</body>
</html>
My guess would be that the form fields used in the cfinsert tag do not all exists. Also, it appears from what you posted that there is a preceding space in the field list -- this may be causing an issue.
My preference is to not use cfinsert because of unknown behaviors like these. I prefer to use cfquery for everything and write my own SQL code with cfqueryparam.
