5 Replies Latest reply on May 4, 2015 9:34 AM by kglad
    When i export the project as swf
    sotirisv77862423
      I have this code in scene4 and when i play it from the project with ctrl+enter the kuler in this scene play and load the color theme correctly. When i export the project as swf the scene4 with this code play but they do not load the color theme. why?
      stop();
      button_12.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene1);
      function fx_ClickToGoToScene1(event:MouseEvent):void
        MovieClip(this.root).gotoAndPlay(1, "Scene1");
      button_13.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene2);
      function barca_ClickToGoToScene2(event:MouseEvent):void
        MovieClip(this.root).gotoAndPlay(1, "Scene2");
      button_14.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene3);
      function dfdfs_ClickToGoToScene3(event:MouseEvent):void
        MovieClip(this.root).gotoAndPlay(1, "Scene3");
      import com.pixelfumes.kuler.*;
      import flash.events.Event;
      import fl.managers.StyleManager;
      StyleManager.setStyle("scrollBarWidth",11);
      var kuler:JSFLKuler = new JSFLKuler();
      var devKey:String = "29CE344635AB36DB7F2A50B3C8AC7E55";
      kuler.loadFeed("http://kuler-api.adobe.com/rss/get.cfm?listtype=recent&key="+devKey);
      preloader_mc.gotoAndPlay(2);
      kuler.addEventListener(com.pixelfumes.kuler.JSFLKuler.FEED_LOADED, onFeedReady);
      kuler.addEventListener(com.pixelfumes.kuler.JSFLKuler.FEED_FAILED, onFeedFailed);
      var stubMC:MovieClip = new MovieClip();
      sp.source = stubMC;
      function onFeedReady(e:Event):void{
        if(kuler.getItemCount() < 1){
        feedControl_mc.status_txt.text = "No Results";
        }else{
        for(var i:uint=0;i<kuler.getItemCount();i++){
        var ki = new KulerItem();
        stubMC.addChild(ki);
        ki.y = i*60;
        ki.setLabel(kuler.getItem(i).title);
        ki.setSwatchColors(kuler.getItem(i).hexColor)
        ki.setRating(kuler.getItem(i).rating);
        sp.refreshPane();
        hidePreloader()
      function onFeedFailed(e:Event):void{
        feedControl_mc.status_txt.text = "Feed Load Failed";
        hidePreloader();
      function removeKulerItems():void{
        stubMC = null;
        stubMC = new MovieClip();
        sp.source = stubMC;
      function hidePreloader():void{
        preloader_mc.visible = false;
      function showPreloader():void{
        preloader_mc.visible = true;
      var kulerTF:TextFormat = new TextFormat();
      kulerTF.color = 0xFFFFFF;
      kulerTF.font = "Arial";
      StyleManager.setComponentStyle(TextInput, "textFormat", kulerTF);
      search_btn.addEventListener("mouseDown",onSearch);
      function onSearch(e:Event):void{
        if(search_txt.text != ""){
        feedControl_mc.gotoAndStop(4);
        removeKulerItems();
        showPreloader();
        kuler.loadFeed("http://kuler-api.adobe.com/rss/search.cfm?searchQuery="+search_txt.text+"&startIndex=0&itemsPerPage=100&key="+devKey);
      search_txt.addEventListener("keyDown",onKeyDownEvent);
      function onKeyDownEvent(e:KeyboardEvent):void{
        if(e.keyCode == 13){
        onSearch(e);
      //JSFL
      function executeJSFL(args){
        var file = args.shift();
        var func = args.shift();
        var result;
        if( args.length > 0 ){
        var arg = args.join( "\',\'" );
        result = MMExecute(((((("fl.runScript(fl.configURI+\'Commands/" + file) + "\',\'") + func) + "\',\'") + arg) + "\');");
        else{
        result = MMExecute(((("fl.runScript(fl.configURI+\'Commands/"+ file) + "\',\'") + func) + "\');");
        return( result );
      function flTrace(str){
        MMExecute("fl.trace(unescape(\""+ escape(str)+"\"));");
      this.addEventListener(com.pixelfumes.kuler.KulerItem.ITEM_SELECTED, onItemSelected);
      function onItemSelected(e:Event):void{
        var args:Array = e.target.swatchColors;
        args.push(escape(e.target.schemeName));
        trace(e.target.swatchColors);
        executeJSFL(["kuler/kuler.jsfl","addSwatches",args]);
      info_btn.addEventListener("mouseDown",onInfoClick);
      function onInfoClick(e:Event):void{
        executeJSFL(["kuler/kuler.jsfl","showInfo"]);
