I was having this same problem and spent most of this
afternoon tracking it down. It seems the problem arises from the
fact that the factory instance doesn't touch the fill, sync, etc
methods. For some reason, flex interprets not using certain
properties of a ConfigMap object as a fatal however which seems a
little odd.
In this case though, it is correct because the sync and fill
methods actually aren't getting set on the underlying java adapter.
This isn't a problem if you use the the Assembler approach, but it
is if you obviously.
I found two fixes one is to get the data adapter for the
current instance in the SpringFactoryInstance constructor and
initiliaze it with the properties ConfigMap so it will set its
syncMethodProperty and the fill-method to its fillMethodProperties
list. This prevents the properties from showing up in the unused
properties of the ConfigMap and so the error is no longer called
and the adapter is configured.
The other option is to upgrade two Lifecyle Data Services
(FDS 2.5). It seems to be fixed there.
