I just purchased and downloaded Lightroom 6, only then to realize that it requires Windows 64 bit, and our company only supports 32 bit Windows. Does my purchase of Lightroom 6 give me rights to run any prior version of Lightroom that would run on Windows 7 32 bit?
Grant
Hi Grant, Lightroom 6 doesn't allow you to use Ligthroom 5, also, Lightroom 5 needs 64 bit os to run. Kindly check the System requirements. As your company doesn't support 64- bit and you don't have any other 64 bit machine, you can return Lightroom 6 as of now, please check: Return, cancel, or exchange an Adobe order
If you wish to cancel Lgithroom 6, kindly contact our support team via: http://helpx.adobe.com/in/contact.html?step=CCSN_adobe-id-signing-in_stillNeedHelp
If you are unable to use ch
...Copy link to clipboard
If you are unable to use chat option kindly try below mentioned steps.
If you are still not able to chat, Kindly reply with the below mentioned information.
You can also try to use photoshop Elements on a 32 bit version, here is link to download the trial version: Download Photoshop Elements products | 13, 12, 11, 10
Please respond to this post in case you have any further queries.
Thank,
Atul Saini
Thank you Atul. I went to the link you provided and read about the return process, I purchased this as a download product (no physical media) through Amazon, and they don't seem to have the ability to return this. Do I need to push Amazon on this and reference this discussion? Or is there a different way through Adobe to process the return? Or am I to contact your support team via the link above?
Thank you,
Grant
Lightroom 5 runs on both 32 bit and 64 bit Windows.
Yes, I thought I also read that Lightroom 5 ran on 32 bit. So then the only question left, does my purchase of Lightroom 6 give me permission to run Lightroom 5 instead? Or can I return Lightroom 6 and purchase Lightroom 5 instead?
Grant
