2 Replies Latest reply on Jan 19, 2007 3:30 PM by jlingwai
    List question
    jlingwai Level 1
      I have a list box which is populated by an item renderer. The current poblem is that I have a Hrule in the renderer to seperate each item in the list, and when I roll over the selection the highlight extends past the Hrule line. It makes it look sloppy like a kid that can't stay in the lines when coloring.
      Does anyone know a way to reduce the area the rollover covers? or add a line after each item in the list¿
      Danke!
      JoSh
        • 1. Re: List question
          FlightGuy Level 1
          You won't be able to change the size of the rollover without extending the List class and drawing the rollover yourself. I don't believe the List has any functionality to leave space between items.
          You could extend List and make it leave a gap - or even draw a line between items. This would probably be your best bet.
          Tim
          • 2. Re: List question
            jlingwai Level 1
            What I did was create a customer component class and extended the list. I then changed the highlight and select parameters to meet my needs.
