2 Replies Latest reply on May 5, 2015 7:54 AM by =gmckinney=
    Crop Grid Bug in LR6
    =gmckinney= Level 1
      LR6 is pretty good, I like it. I've noticed two bugs however.
      1) With GPU acceleration the crop tool stalls for a couple of seconds before being responsive again. With GPU off it's completely responsive... GPU crash?
      2) The crop grid is no longer a grid, it's a diamond pattern!
      Machine Info Below.
      Lightroom version: 6.0.1 [ 1018573 ]
      License: Perpetual
      Operating system: Mac OS 10
      Version: 10.10 [3]
      Application architecture: x64
      Logical processor count: 4
      Processor speed: 1.3 GHz
      Built-in memory: 4,096.0 MB
      Real memory available to Lightroom: 4,096.0 MB
      Real memory used by Lightroom: 330.4 MB (8.0%)
      Virtual memory used by Lightroom: 2,009.5 MB
      Memory cache size: 838.1 MB
      Maximum thread count used by Camera Raw: 2
      Camera Raw SIMD optimization: SSE2,AVX,AVX2
      Displays: 1) 1440x900
      Graphics Processor Info:
      Intel HD Graphics 5000 OpenGL Engine
      Check OpenGL support: Passed
      Vendor: Intel Inc.
      Version: 4.1 INTEL-10.6.20
      Renderer: Intel HD Graphics 5000 OpenGL Engine
      LanguageVersion: 4.10
      Application folder: /Applications/Adobe Lightroom
      Library Path: <snip>
      Settings Folder: <snip>
      Installed Plugins:
      1) Aperture/iPhoto Importer Plug-in
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      Config.lua flags: None
      Updated Toolkit: Adobe Camera Raw 9.0 for Lightroom 6.0 (build 1014445)
      Updated Toolkit: Book Module 6.0 (build 1014445)
      Updated Toolkit: Develop Module 6.0 (build 1014445)
      Updated Toolkit: Import Module 6.0 (build 1014445)
      Updated Toolkit: Library Module 6.0 (build 1014445)
      Updated Toolkit: Map Module 6.0 (build 1014445)
      Updated Toolkit: Print Module 6.0 (build 1014445)
      Updated Toolkit: Slideshow Module 6.0 (build 1014445)
      Updated Toolkit: Web Module 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.AgNetClient 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.AgWFBridge 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.Headlights 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.LibraryToolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.MultiMonitorToolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.archiving_toolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.bridgetalk 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.catalogconverters 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.cef_toolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.coretech_toolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.curculio 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.discburning 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.email 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.export 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.ftpclient 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.help 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.iac 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.imageanalysis 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.layout_module_shared 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.pdf_toolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.sdk 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.sec 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.socket 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.store_provider 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.substrate 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.ui 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.video_toolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.webview_toolkit 6.0 (build 1014445)
      Updated Toolkit: com.adobe.ag.xml 6.0 (build 1014445)
      Updated Toolkit: com.adobe.wichitafoundation 6.0 (build 1014445)
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Built-in Output
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CoreImage: true
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 2048
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: Intel HD Graphics 5000 OpenGL Engine
      GL_SHADING_LANGUAGE_VERSION: 1.20
      GL_STENCIL_BITS: 8
      GL_VENDOR: Intel Inc.
      GL_VERSION: 2.1 INTEL-10.6.20
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
