14 Replies Latest reply on May 7, 2015 4:23 AM by Qwertyfly...
    saveAs: overwrite files or ask what to do?
    Doug A Roberts Adobe Community Professional & MVP
      this is one of those situations where i feel like i'm missing something obvious, but with as little knowledge as i have there's a lot to be potentially missed. anyway, enough self-deprecation...
      this script came from a discussion i found ages ago that fit what i needed to do at the time. i don't remember the exact discussion but Larry G.S. rounded it off and posted this:
      Place_JPG_to_AI.jsx
      DESCRIPTION
      This script gets files specified by the user from the
      selected folder and batch processes them and saves them
      as AIs in the user desired destination with the same
      file name.
      Modified from Adobe supplied scripts and
      scripts by Carlos Canto on Illustrator Scripting
      by Larry G. Schneider
      // uncomment to suppress Illustrator warning dialogs
      app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
      var destFolder, sourceFolder, files, fileType;
      // Select the source folder.
      sourceFolder = Folder.selectDialog( 'Select the folder containing M.E.T. JPEG files', '~' );
      // If a valid folder is selected
      if ( sourceFolder != null )
           files = new Array();
           // Get all files with JPEG extension
           files = sourceFolder.getFiles("*.jpg");
           if ( files.length > 0 )
                // Get the destination to save the files
                destFolder = Folder.selectDialog( 'Select the folder where you want to save the AI files.', '~' );
                for ( i = 0; i < files.length; i++ )
                     var idoc = app.open(File("/G/Design & Publishing/Elements/Master Templates/Re-Engineering Templates/Illustrator/MET Template 106.82x60.ai"));  // open template document. Change the file path for different templates
                     var ilayer = idoc.layers["Image"];
                     var iplaced = ilayer.placedItems.add();  // add image place holder
                     iplaced.file = (files[i]);  // place file
                      var PosXY=new Array(2);  // ensure position is 0,0
                      PosXY[0]=0;
                      PosXY[1]=0;
                      iplaced.position = PosXY;
                      iplaced.embed();
                     ilayer.dimPlacedImages = false;   // do not dim images
                     ilayer.locked = true;  // lock layer
                     ilayer.printable = true;
                     var docName = (files[i].name.split('.'))[0];   // take the first part of the placed file name for the new document
                     var destFile = new File(destFolder + "/" +  docName + ".ai");   // make a new file in the dest folder
                     var options = new IllustratorSaveOptions();   // new save options
                     options.compatibility = Compatibility.ILLUSTRATOR15;   // save as AICS5. May want to update if we go to CC
                     options.pdfCompatible = true; // needs to be set to view links in InDesign
                     // Export as AI
                     idoc.saveAs(destFile,  options);  // save the file in the dest folder
                     idoc.close(SaveOptions.DONOTSAVECHANGES);   // close the file without saving
                alert( 'Files are saved as AI in ' + destFolder );
           else
                alert( 'No matching files found.' );
      app.userInteractionLevel = UserInteractionLevel.DISPLAYALERTS
      i edited little bits for our purposes but it's basically the same. user selects a folder with jpegs, a dest folder, and the script places the jpegs on my template and saves them with the original filename. however, occasionally the user will need to do this several times into the same dest folder, and won't necessarily know what jpegs they've already done. so they've ended up overwriting files that might already have been worked on (names can't change after the fact for some very boring and irritating reasons).
      what they'd like, in that case, is for the script to alert them when files with that filename already exist in the dest folder (but run as normal otherwise). i thought just turning DISPLAYALERTS back on might do this (since that's what saveAs does when you go through it manually) but it didn't seem to make any difference. i can't find clues in the reference, but then i'm not entirely sure what i'm looking for.
      any help or pointers at any level of detail welcome.
        • 1. Re: saveAs: overwrite files or ask what to do?
          Qwertyfly... Level 4
          test = destfolder.getFiles(docName + ".ai");
          if(test != null){alert("file exists");}
          not tested as I am not near a computer
          • 2. Re: saveAs: overwrite files or ask what to do?
            g'day Qwerty. that seems to trigger the alert whether there's a file by that name in the folder or not.
            • 3. Re: saveAs: overwrite files or ask what to do?
              getFiles is an array, right? might it need to loop through them?
              • 4. Re: saveAs: overwrite files or ask what to do?
                getFiles is an array, but the docName + ".ai" is a filter, so it should only find that file.
                needs to happen before your "var destFile = ... " line.
                I'm back at my PC now so I'll have a play.
                • 6. Re: saveAs: overwrite files or ask what to do?
                  works great. thanks Qwerty!
                  next on the list might be a dialogue from which the user can choose to continue (and overwrite) or stop. never done that before, so i might well be back when i inevitably get stuck.
                  • 7. Re: saveAs: overwrite files or ask what to do?
                    Place_JPG_to_AI.jsx
                    DESCRIPTION
                    file name.
                    by Larry G. Schneider 072911
                    function jpegMET(){
                                    PosXY[0]=0;
                                    PosXY[1]=0;
                                    iplaced.embed();
                                   var test = destFolder.getFiles(docName + ".ai");
                                   if(test != 0){
                                       var overWrite = confirm("A file with this name already exists. Continue and overwrite?");
                                       if (overWrite){
                                            }else{
                                       return;
                                   }else{
                                   // Export as AI
                         else
                              alert( 'No matching files found' );
                    jpegMET ()
                    this seems to work... one little blip though. most files are named in the format 'AIM_0000' (straight from the user's camera), but one named 'AIM_0000 0' for whatever reason didn't display the message... can't see why it'd skip it. it still overwrites though.
                    • 8. Re: saveAs: overwrite files or ask what to do?
                      nnot sure it will fix the bug.
                      Bit you might be better replacing split with replace.
                      var docName = (files[i].name.replace(".jpg",".ai"));
                      safety against a file file name with a dot in it. Not 100% fail safe as it may silt have the whole .jpg string in file name, but safer.
                      • 9. Re: saveAs: overwrite files or ask what to do?
                        didn't affect the bug i'm afraid, but i have incorporated it anyway. thanks for the advice.
                        • 10. Re: saveAs: overwrite files or ask what to do?
                          seems to be any filename with a space in it... does getFiles not like spaces?
                          hmmm. but it wouldn't work in the first place if that was the case i guess.
                          • 11. Re: saveAs: overwrite files or ask what to do?
                            Try this...
                            var docName = decodeURI(files[i].name.replace(".jpg",".ai"));
                            I'mm plucking at straws but it may be due to the %20 in place of the spaces that's causing the issue.
                            • 12. Re: saveAs: overwrite files or ask what to do?
                              I was just doing a test.
                              I am confident that this is the issue.
                              the above should work.
                              • 13. Re: saveAs: overwrite files or ask what to do?
                                ah! yes, that's it. thank you so much.
