4 Replies Latest reply on May 6, 2015 8:35 AM by BEGINNER_X
    Ungroup, again group
    BEGINNER_X Level 3
      Hi All,
      My Request,
      1. Select the groups(consists of two page items with create outlines)
      2. Ungroup the selection
      3. apply transparency
      app.selection[0].transparencySettings.dropShadowSettings.size = 10;
      4. Again group
      Could you please provide your help.
      Regards
      Siraj
        • 1. Re: Ungroup, again group
          Vamitul Level 4
          You don't really need to ungroup.
          //asssuming myGroup is the group you need:
          myGroup.pageItems[0].transparencySettings.dropShadowSettings.size = 10;
          myGroup.pageItems[1].transparencySettings.dropShadowSettings.size = 10;
          • 2. Re: Ungroup, again group
            BEGINNER_X Level 3
            Hi Vamit,
            Thank you for the fast reply,
            for another scenario, I am trying Seleted item should be ungroup and group.
            I look at forum, but not works for me.
            orggroup = app.activeDocument.groups[0].allPageItems;
            app.activeDocument.groups[0].ungroup();
            newgroup = [];
            for (i=0; i<orggroup.length; i++)
              newgroup.push(orggroup[i]);
            app.activeDocument.groups.add(newgroup);
            Thanks in advance
            • 3. Re: Ungroup, again group
              Daniel Sterchi Level 3
              Hi Beginner_X
              I tested the code. It works, but it does not group and ungroup the selected Item. I just wrote a few lines more. So if you really have to ungroup and group again, give my code a try.
              kind regards
              Daniel (from Switzerland)
              main();
              exit();
              function main() {
                  var orgGroup;
                  // test if the seleted item is a Group
                  if ((app.selection.length > 0) && (app.selection[0].constructor.name  == "Group")) {
                      alert("Info\nGroup selected");
                      orgGroup = app.activeDocument.groups[0].allPageItems;
                      alert("Info\nUngrouped the selected group");
                      // call your function(s)
                      yourStuff();
                  else {
                      alert("Warning\nNo group selected");
                      orgGroup = "";
                  if  (orgGroup != "") {
                      newgroup = [];
                      for (i=0; i<orgGroup.length; i++) newgroup.push(orgGroup[i]);
                      alert("Info\nRegrouped previous grouped Items");
                  alert("Info\nI did my job, what about yours?");
              function yourStuff() {
                  alert ("Info\nDo your stuff here");
              • 4. Re: Ungroup, again group
                BEGINNER_X Level 3
                Dear Vamitul & Dani,
                Sorry for the late response...
                Apologies., for that, I confused two questions in the same thread.
                Vamit: your coding is working fine. Thank You for your immediate response. Again thanks a ton.
                Dani: Thanks for your valuable timing spend for me.
                I will test your code and get back in separate thread.
                Warm Regards
                Siraj
