1 Reply Latest reply on May 6, 2015 8:56 AM by userCold9
    Cold Fusion 11 using the datefield on input field issue
    userCold9 Level 1
      I have just installed Colld Fusion 11 in the production environment. I am not able to replicate the issue in the other non production environments using Cold Fusion 11.
      Some users are able to use the date picker using the below. Other users are not able to use the date picker. It appears bu when selected it does not work.
      ...cfinput type="datefield" .....
      Some of the users are using IE 11, IE 9 or IE 8.
      I can access the functionality using IE 11 and 9.
      This affecting the users performing there important functions.
      Is there a solution to this issue?
      Mike
        • 1. Re: Cold Fusion 11 using the datefield on input field issue
          userCold9 Level 1
          The Test environment is running Java Version 1.7.0_51 while the production environment is running 1.8.0_25.
          The date picker works on some IE browsers and does not appear for the IE browser. Works fine in Firefox.
          I found information on Update 5.
          Also, some of the information, states Update 5 breaks CF11
          Is Update 5 included in the build version in production (11,0,03,292866)
          Is the Java version the issue along with Update 5?
          Mike
