1 Reply Latest reply on Jan 16, 2007 3:43 AM by Newsgroup_User
    Detect Directxversion  installed
    Level 7
      Hello:
      I have bought Mediaplayer Expanded Xtra and It needs to run DirectX 9 or
      newer.
      I have to make 2 thousand copies of a CD-ROM.
      Do you know how to detect what version of DirectX is installed and if is an
      older version then proceed with installation.
      How canI do that, please?
      or other solution for that
      Thank you very much
        • 1. Re: Detect Directxversion  installed
          Level 7
          put the environment.directXVersion
          -- "9.0.1.1"
          Notice that it returns a STRING and it has 3 decimal points. In order
          to do any sort of mathematical comparison, you need to convert it to a
          standard number. If all you care about is the 1st number (the 9 in this
          case), then this handler will find out what it is (put it in a MOVIE
          script):
          on DirectXVersion
          oldDelim=the itemDelimiter
          the itemDelimiter="."
          dxVersion=integer(the environment.directXVersion.item[1])
          the itemDelimiter=oldDelim
          return dxVersion
          end
          Now somewhere in your script, you can do something like this:
          if directXVersion()>=9 then
          --do something if it is 9 or better
          else
          --do something if it needs to be installed
          end if
