3 Replies Latest reply on May 6, 2015 6:52 AM by johnrellis
    duplicate folders/images in catalog
    garyq82026120
      I have noticed last couple of days that some of my folders of images are duplicated in my catalog. I have no idea why this has happened. I thought that LR might be linking to my clone copy, but "Show in Finder" for both duplicate folders shows the same path. Oddly, the duplicate folders are in lower-case, while the original folders are in upper-case.
      I  removed one or two of them, working on the theory that it only removes the folder, not the images. This sort of worked (see attached). I removed the following folders as a test: "to promote" and "tanja's images".
      Upon closing/reopening it now seems that "tanja's images" has been successfully removed leaving the original "Tanja's Images". However, the folder "to promote" has reappeared along with the images inside, while the original "To Promote" now has zero images indicated (although clicking on that folder indicates there are still images shown).
      So my catalog appears to be corrupted. Question is how to sort it out without losing any images? Has anyone had this happen? Do I need to split my catalog (it is 70,000+ images)? I am referencing LR to a Master hard drive, while the LR app itself is on a Boot hard drive.
      Cheers
      Gary
        • 1. Re: duplicate folders/images in catalog
          D.A.R Adobe Community Professional
          I had a similar problem a while back, although strictly speaking it wasn't really a "problem" per se. That is, I never had duplicate files on my system and any edits were correctly applied to images even if there appeared to be duplicate folders.
          So what did I do about it? To be honest, I cannot recall that I did anything specific. I do remember removing folders and synchronizing and even changing the name on the hard drive to match the case of what Lightroom was showing. My issue seemed to affect only one master folder, perhaps because it was the most used folder by far.
          It may have been related to system backups running at the same time. I really cannot say for sure.
          Backup the catalog now.
          As for splitting the catalog. I don't see that as a necessary step at this point. I would remove the folder and then synchronize a parent folder.
          I may also try creating a new catalog and importing from the current catalog to see if the problem still exists. When importing from the catalog you don't need to import all the assets 70k+ at once.
          • 2. Re: duplicate folders/images in catalog
            johnrellis Most Valuable Participant
            Mac or Windows?  If Mac, is the hard drive containing your photos a case-sensitive volume?  Adobe officially doesn't support LR installed on a case-sensitive volume but says nothing about whether case-sensitive volumes are supported for storing photos.  However, there have been occasional reports of problems with photos located on case-sensitive drives, and as a plugin developer, I know that LR internally is inconsistent in how it handles the case of file paths.  You can find out if your volume is case-sensitive by right-clicking it in Finder and doing Get Info; the Format line will say "case-sensitive" if it is:
            • 3. Re: duplicate folders/images in catalog
              I've seen other threads discussing solutions for cleaning up folders that differ in name by case. You might do a thorough search in this forum and the feedback forum.  A quick search reveals this thread: Lightroom creates duplicate folder after PS edit or Import from disk,but I'm sure there are others. I have a vague memory that an Adobe employee provided a solution in one of the threads.
