0 Replies Latest reply on May 6, 2015 8:51 PM by suresh0208
    Need help to combine two scripts
    suresh0208 Level 1
      I created two scripts and running 2 times for checking the files. One is for Print files and another for the web files. I tried to combine the both scripts to one script. But the combine script is working only for the print files.
      So can any one helps to solve this. . .
      The script goes here:
      #target photoshop
      var myPrintFolder = Folder.selectDialog ("Select Print Folder");
      if(myPrintFolder!=null){
          var myFiles_Print = myPrintFolder.getFiles(/\.(tif)$/i);
          for(var fileIndex=0;fileIndex<myFiles_Print.length;fileIndex++)
              var currentFile = myFiles_Print[fileIndex];
              if(currentFile instanceof File)
                      if(currentFile.hidden) continue;
                          var doc = app.open(currentFile);
      //Checks Resolution of Image
          var docResolution = doc.resolution
              if (docResolution != 300)
                  alert("File Resolution is not 300dpi");
                  //doc.resizeImage(undefined, undefined, 300, ResampleMethod.NONE);
      //Checks Document information and copyrighted Information
                              docInfoRef = doc.info;
          if(docInfoRef.copyrighted == CopyrightedType.COPYRIGHTEDWORK)
          alert("image has copyrighted");
          docInfoRef.copyrighted = CopyrightedType.UNMARKED;
          else{
              if(docInfoRef.copyrighted == CopyrightedType.PUBLICDOMAIN)
                       alert("image has Public-Domain");
      //Reads Path Items count in the document
              var docPathsItems = doc.pathItems.length
                if (docPathsItems > 1)
                   alert(doc.name + " "  + "File has More Path Items");
      //Reads All Path  Elements
                  if(doc.pathItems[0].kind != PathKind.CLIPPINGPATH)
                      alert(doc.name + " "  + "is not containing Clipping Path")
                  if(doc.pathItems[0].name != "Path 1")
                      alert(doc.name + " "  + "Path name should be Path 1");
                  if(doc.pathItems[0].name != "Path 1" && doc.pathItems[0].kind == PathKind.WORKPATH)
                      alert(doc.name + " "  + "Path is in WorkPath");
                      doc.pathItems[0].name = "Path 1"
      //Checks color profile
                  if(doc.colorProfileType == ColorProfile.NONE)
                      alert(doc.name + " "  + "Color profile is not correct")
      //Checks Colour Mode
               if (doc.mode != DocumentMode.CMYK)
                   alert(doc.name + " "  + "Colour mode should be CMYK");
                  //doc.changeMode(ChangeMode.CMYK);
      //Checks the size of width or height less than 2.8 CM
          var x = 2.8;
           if(doc.width > doc.height)
               var roundUp = Math.round (doc.width)
               //alert ("Document width is more than height" + doc.width);
              if(roundUp < x)
                  alert(doc.name + " "  + "The document width is less than 2.8CM's" );
      if(doc.height > doc.width)
              var roundUp1 = Math.round (doc.height)
              //alert ("Document height is more than width " + doc.height);
             if(roundUp1 < x)
                  alert(doc.name + " "  + "The document height is less than 2.8CM's" )
      //Checks the file naming convension
              myDoc = doc.name;
              value = myDoc.slice(8,-4);
              if(value < 30 || value > 40)
                  alert("Print File naming conversion should be -30");
      doc.close(SaveOptions.DONOTSAVECHANGES);
      //Ends the Print Script
      var myWebFolder = Folder.selectDialog ("Select Web Folder");
      if(myWebFolder!=null){
          var myFiles_Web = myWebFolder.getFiles(/\.(tif)$/i);
          for(var fileIndex1=0;fileIndex1<myFiles_Web.length;fileIndex1++)
              var currentFile = myWebFolder[fileIndex1];
          else{
                      //doc.pathItems[0].name = "Path 1"
               if (doc.mode != DocumentMode.RGB)
                   alert(doc.name + " "  + "Colour mode should be RGB");
                  //doc.changeMode(ChangeMode.RGB);
          var x = 2.8;
              if(roundUp < x)
             if(roundUp1 < x)
              myDoc = doc.name;
              if(value < 40 || value > 40)
                  alert("Print File naming conversion should be -40");
      //Ends the Web Script
      function print(){
      if (myFiles_Print.length  != myFiles_Web.length)
          alert("Print Files is not equal" + " " + "Total images are:" + " " + myFiles_Print.length);
      else
          alert("Print Files  is equal"+ " " + "Total images are:" + " " + myFiles_Print.length);
      function web(){
      if (myFiles_Web.length  != myFiles_Print.length)
          alert("Web Files Count is not equal" + " " + "Total images are:" + " " + myFiles_Web.length);
      else
          alert("Web Files Count is equal"+ " " + "Total images are:" + " " + myFiles_Web.length);
      print();
      web();
      Thanks in Advance,
      Suresh.
