• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Flash Remoting on Linux Box
Explorer ,
Jan 14, 2007 Jan 14, 2007
Sorry, for the cross-post, but I know not all Flash developers check the CF forums and vice versa. Since the problem applies to both I figured it wouldn't hurt to try both areas.
I'm getting the following error when trying to connect to a CFC using flash remoting.
Service threw an exception during method invocation: An error occurred when performing a file operation read on file {web_server_path}/flashservices/.
The flash file is on a Windows box, the CFC on a Linux box running CF Standard Edition, Version 6,1,0,63958. I've tested remoting to the CFC on several windows servers running the same version (6.1) of CF (But Enterprise and Developer edition) and it works fine. My 2 Linux boxes give me grief. I did try doing what this technote suggests to no avail.
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_18608
I also tried to manually create the /flashservices/gateway directory structure which someone else suggested for AMFPHP. Any suggestions?
TOPICS
Advanced techniques
Views
278
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
LATEST
Forgot to add the logfile error message I'm getting.
"Information","jrpp-1","01/14/07","15:40:42",,"[Flash Remoting MX]->coldfusion.tagext.io.FileTag$SingleFileOperationException: An error occurred when performing a file operation read on file {web_server_path}/flashservices. at coldfusion.tagext.io.FileTag.read(FileTag.java:352) at coldfusion.tagext.io.FileTag.doStartTag(FileTag.java:244) at cftop2ecfm1287979117.runPage({web_server_path}/template/top.cfm:4) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357) at coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1876) at cfApplication2ecfm1709211115.runPage({web_server_path}/Application.cfm:11) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357) at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62) at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:30) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:93) at coldfusion.filter.FlashFilter.invoke(FlashFilter.java:75) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.flash.FlashProxy.invokeComponent(FlashProxy.java:139) at flashgateway.adapter.coldfusion.CFCAdapter.invokeFunction(CFCAdapter.java:95) at flashgateway.filter.AdapterFilter.invoke(AdapterFilter.java:266) at flashgateway.filter.SecurityFilter.invoke(SecurityFilter.java:85) at flashgateway.filter.LicenseFilter.invoke(LicenseFilter.java:58) at flashgateway.filter.ErrorFilter.invoke(ErrorFilter.java:44) at flashgateway.filter.LogFilter.invoke(LogFilter.java:43) at flashgateway.filter.BatchProcessFilter.invoke(BatchProcessFilter.java:63) at flashgateway.filter.DebugFilter.invoke(DebugFilter.java:38) at flashgateway.filter.SerializationFilter.invoke(SerializationFilter.java:59) at flashgateway.Gateway.invoke(Gateway.java:194) at flashgateway.controller.GatewayServlet.service(GatewayServlet.java:56) at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:249) at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527) at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192) at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348) at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451) at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66) "
Votes
Translate
Translate
Report
Report
Resources
Documentation
