12 Replies Latest reply on May 10, 2015 10:40 AM by A.T. Romano
    after you have created a slideshow how do you burn it to a dvd
    vickia12701353
      After you have created a slideshow how do you burn it to a dvd?
        • 1. Re: after you have created a slideshow how do you burn it to a dvd
          Read the publish and share links at The Elements Tutorial Links Page http://forums.adobe.com/thread/1275830
          • 2. Re: after you have created a slideshow how do you burn it to a dvd
            A.T. Romano Level 7
            vickia
            What version of Premiere Elements and on what computer operating system?
            Where are you creating this slideshow - in the Premiere Elements Editor or the Elements Organizer?
            Then, what is your export goal
            a. DVD-VIDEO standard or widescreen on DVD disc
            or
            b. AVCHD format on DVD disc
            The answer to these questions will enable us give you specific information and avoid reviewing information that you are not really seeking.
            Project set up, properties of source files on the Timeline, and more are important considerations in getting the disc product with the quality that you want. We can get into those matters if needed.
            Any questions or need clarification, please do not hesitate to ask.
            Thank you.
            ATR
            • 3. Re: after you have created a slideshow how do you burn it to a dvd
              vickia12701353 Level 1
              I am using Premiere Elements 13 and I have Windows 7.  I am creating the slideshow in Elements Organizer. I want to burn a DVD for windscreens TV for my DVD player.  Any help would be welcomed.
              Thanks,Vicki
              • 4. Re: after you have created a slideshow how do you burn it to a dvd
                A.T. Romano Level 7
                vickia
                The Elements Organizer 13/13.1 and Premiere Elements 13/13.1 relationship is different than in earlier versions...no more Elements Organizer Slideshow Editor Output "Edit with Premiere Elements Editor".
                If you are going to create your slideshow in Elements Organizer 13/13.1 Slideshow Builder, select from one of the themes and export the slideshow to 1080p. That should give you a AVCHD.mp4 file (1920 x 1080 @ 30 progressive frames per second) saved to the computer hard drive location of your choice.
                Open Premiere Elements 13/13.1, go to Add Media/Files and Folders/ and import your AVCHD.mp4 from its saved hard drive location into the project by dragging it from Project Assets to the Timeline. In doing this, the project should have set the project preset to NTSC DSLR 1080p DSLR 1080p30@29.97.
                Verify that the project set the project settings correctly. See Edit Menu/Project Settings/General. If set correctly for you, then you should see
                Assuming OK, then move on in the project. You can add Movie Menu (Tools Menu/Movie Menu). Next would be Publish+Share/Disc/DVD using preset = NTSC_Widescreen_Dolby DVD.
                Also refer to
                Elements Organizer Help | Create slideshows
                Please review and consider. If any questions, please do not hesitate to ask. If necessary, I will post the how to for manual setting of the project preset.
                Thank you.
                ATR
                • 5. Re: after you have created a slideshow how do you burn it to a dvd
                  I haven't been able too-I don't know how or what to do to get it to burn a DVD.
                  • 6. Re: after you have created a slideshow how do you burn it to a dvd
                    A.T. Romano Level 7
                    vickia
                    Thanks for the reply.
                    Are you OK importing the slideshow (AVCHD.mp4) into a Premiere Elements 13/13.1 project.
                    Add Media/Files and Folder/ and navigate to your file on the computer hard drive. The file will go into Project Assets.
                    From Project Assets, you drag the file to the Timeline.
                    I would bypass any Tools Menu/Movie Menu for the first try and go directly to Publish+Share/Disc/DVD disc with preset = NTSC_Widescreen_Dolby DVD.
                    If you get a message about disc menu when you hit Publish+Share/Disc, then just say No to the message.
                    In this screenshot of the Expert workspace of Premiere Elements 13/13.1, there is no DVD disc in the burner tray, so you will see Status = Media not present.
                    Are you OK with the above information. Maybe give it a mini test run and let us know the outcome.
                    Please let me know where you are stopped. In the Elements Organizer 13/13.1 Slideshow Builder or in the Premiere Elements 13/13.1 Editor? Then I will go into more detail in the specific area where you are stopped.
                    Thank you.
                    ATR
                    • 7. Re: after you have created a slideshow how do you burn it to a dvd
                      Thanks, I will give this a try and see how I do.
                      Sent from Yahoo Mail on Android
                      Date:Thu, May 7, 2015 at 3:29 PM
                      Subject:[Premiere Elements] after you have created a slideshow how do you burn it to a dvd
                      created by A.T. Romano in Premiere Elements - View the full discussion
                      vickia
                      https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-7523023-760131/558-370/DSLRPr oject+Settings.JPG
                      Also refer to
                      Thank you.
                      ATR
                      If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/7523023#7523023 and clicking ‘Correct’ below the answer
                      Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
                      Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/7523023#7523023
                      To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"
                      Start a new discussion in Premiere Elements by email or at Adobe Community
                      For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
                      • 8. Re: after you have created a slideshow how do you burn it to a dvd
                        A.T. Romano Level 7
                        vickia
                        You should do fine. Master one phase at a time. We will fine tune details as we go until the project is completed successfully.
                        Just let me know when and if fine tuning is needed.
                        Best wishes.
                        ATR
                        • 9. Re: after you have created a slideshow how do you burn it to a dvd
                          I have experienced success and can now burn my slideshows to dvds.  Should I be able to use the tools: transitions, titles & text, effects, audio and graphics?  If so, how?
                          • 10. Re: after you have created a slideshow how do you burn it to a dvd
                            A.T. Romano Level 7
                            vickia
                            So glad for the great news of success with your slideshows to dvds projects.
                            When you build the slideshow in the Elements Organizer 13/13.1, many of the options are limited - not like you would have had with the earlier Elements Organizer or if you build the slideshow in Premiere Elements 13/13.1 Editor. If you go the Elements Organizer 13/13.1 Slideshow Builder route, I see
                            1. No opportunity for user selected transitions, other than what is in the theme you must select at the onset. Inserting the transitions once the AVCHD.mp4 1080p slideshow is in the Premiere Elements will need cutting of the file. And, with the built in theme, it is probably going to be difficult to impossible to get worthwhile user transition into that theme scheme.
                            2. Titles and Text. The enabled Captions feature in the Slideshow Builder is typically going to place a caption above or below the photo or video being displayed. When that gets into the Premiere Elements Editor, it will display the way that you saw it in the Slideshow Builder. What you could do is disable Captions in the Slideshow Builder and, in Premiere Elements, create text titles to be placed on Video Track 2 above your AVCHD.mp4 on Video Track 1. Your best opportunity is to explore "overlays" on Video Track 2 above the video on Video Track 1.
                            3. Audio. Best set that up in the Slideshow Builder under its Audio Tab at the bottom. However, when you do get the slideshow into Premiere Elements Editor, you could right click this whole video file, select Delete Audio, and then replace the Audio with a file that you import into the Premiere Elements Editor's with the Editor's Add Media/Files and Folders/Project Assets from where you drag your replacement file to the audio track.
                            4. Graphics. I see no opportunities for graphics in the Slideshow Builder. Once the slideshow is in the Premiere Elements Editor, you could use the overlay approach as described in Titles and Text above, using one of the Premiere Elements' Graphics Tab choices.
                            Please consider. Any questions or need clarification, please ask.
                            Thanks.
                            ATR
                            • 11. Re: after you have created a slideshow how do you burn it to a dvd
                              Thanks for the information.
                              vickia
                              Also refer to
                              Thank you.
                              ATR
                              • 12. Re: after you have created a slideshow how do you burn it to a dvd
                                A.T. Romano Level 7
                                vickia
                                Sounding good. Looking forward to your results. You are doing well, but, if any questions come up along the way, please do not hesitate to ask.
                                Best wishes.
                                ATR
