3 Replies Latest reply on May 11, 2015 3:46 AM by owen_bayley
    CSS classes not global ??
    g.bollmann Level 1
      I have code in a menu symbol which controls classes.
      I have classes applied to other symbols, which should react together. Ex:
      sym.getSymbol(".indef").play("indef-art");
      This should cause 4 symbols with the respective class to play at the same time, right?
      Instead, either only 1 symbol plays, or they play in sequence when the button is clicked.
      Thanks for your advice.
        • 1. Re: CSS classes not global ??
          owen_bayley Level 1
          hey g.bollmann,
          I have personally found that to use a class  in the way you are describing you need to make a function for the class then call this function: e.g in creation competed
          sym.playIndef = function() {
          sym.getSymbol(".indefl").play();
          then just call this when you want a all symbols with the class indefl to play:
          sym.playIndef();
          I would personal recommend the first way I described as I find you have control over the project
          hope this helped
          • 2. Re: CSS classes not global ??
            g.bollmann Level 1
            Thanks Owen,
            I've been jumping through every hoop but no luck.
            Perhaps I am not creating the function correctly or maybe a class cannot access the timeline.
            Any other ideas? If so ... much appreciated!
            BR/Grace
            • 3. Re: CSS classes not global ??
              owen_bayley Level 1
              hey g.bollmann,
              how are you using it?
              can I see examples of what you have done/ how you are using it? how your projects is set out? as you may have conflicting code or something.
              I would recommend you play the symbols manually if it does not work with a function: e.g
              sym.getSymbol("symbolname").getSymbol("symbolname").play("lablename");
              you will need to have this code for every symbol you wan to start the animation in. I would further recommend putting this in a click.
              hope this helped
              Owen
