2 Replies Latest reply on May 7, 2015 2:40 AM by Peter Spier
    Indesign CS6 won't reopen
    daniellef32908076
      I recently uninstalled indesign CS6 following an unexpected error. Indesign shut down and I couldn't reopen it hence why I uninstalled the program. I have reinstalled indesign yet it still won't reopen due to it shutting unexpectedly?
        • 1. Re: Indesign CS6 won't reopen
          Daniel Sterchi Adobe Community Professional
          Hi there
          Did you try to delete als the preference files? If not, you could give this a try. I solved problems like you described this way.
          Double click the InDesign Icon in the programfolder while holding down CMD+OPTION+CRTL+SHIFT then you will be asked if you wish to delete the preference files.
          Before you do so I would advice you to backup the directory:
          ~/Library/Preferences/Adobe InDesign/Version [your version].
          since you have your shortcuts, your menu set, your grep searches, … in there. You can copy those important directories back after your started InDesign and the directory structure was newly build.
          (This is for the Mac)
          kind regards
          Daniel (from Switzerland)
          • 2. Re: Indesign CS6 won't reopen
            Do you get any error messages? Does ID start to launch?
            I suspect the problem could be corrupt recovery data from a crash before the reinstall. Make sure the InDesign Recovery folder is empty.
