1 Reply Latest reply on May 11, 2015 2:03 PM by gkaiseril
    How  to convert amount with decimal points to words based on various currencies selected?
    Alex Doubts
      How  to convert amount with decimal points to words based on various currencies selected ?
      I am able to convert amount without decimal points  to words based on various currencies selected Please provide a solution at the earliest.
      My code is as follows:
      function number2text(value) {
          var fraction = Math.round(frac(value)*100);
          var f_text  = "";
          if(fraction > 0) {
              f_text = "AND "+Number(fraction);
          return Number(value)+" "+f_text;
      function frac(f) {
          return f % 1;
      function Number(number)
          if ((number < 0) || (number > 999999999))
              return "NUMBER OUT OF RANGE!";
          var Gn = Math.floor(number / 10000000);  /* Crore */
          number -= Gn * 10000000;
          var kn = Math.floor(number / 100000);     /* lakhs */
          number -= kn * 100000;
          var Hn = Math.floor(number / 1000);      /* thousand */
          number -= Hn * 1000;
          var Dn = Math.floor(number / 100);       /* Tens (deca) */
          number = number % 100;               /* Ones */
          var tn= Math.floor(number / 10);
          var one=Math.floor(number % 10);
          var res = "";
          if (Gn>0)
              res += (Number(Gn) + " CRORE");
          if (kn>0)
                  res += (((res=="") ? "" : " ") +
                  Number(kn) + " LAKH");
          if (Hn>0)
                  Number(Hn) + " THOUSAND");
          if (Dn)
                  Number(Dn) + " HUNDRED");
          var ones = Array("", "ONE", "TWO", "THREE", "FOUR", "FIVE", "SIX","SEVEN", "EIGHT", "NINE", "TEN", "ELEVEN", "TWELVE", "THIRTEEN","FOURTEEN", "FIFTEEN", "SIXTEEN", "SEVENTEEN", "EIGHTEEN","NINETEEN");
      var tens = Array("", "", "TWENTY", "THIRTY", "FOURTY", "FIFTY", "SIXTY","SEVENTY", "EIGHTY", "NINETY");
          if (tn>0 || one>0)
              if (!(res==""))
                  res += " AND ";
              if (tn < 2)
                  res += ones[tn * 10 + one];
              else
                  res += tens[tn];
                  if (one>0)
                      res += (" " + ones[one]);
          if (res=="")
              res = "ZERO";
          return res;
          var f_text  = "";
          if(fraction > 0) {
      function frac(f) {
          return f % 1;
          var res = "";
          if (Gn>0)
          if (kn>0)
          if (Hn>0)
          if (Dn)
          if (tn>0 || one>0)
              if (!(res==""))
                  res += " AND ";
              if (tn < 2)
              else
                  res += tens[tn];
                  if (one>0)
          //app.alert(res);
          return res;
      if (this.getField("rdoGpAmountType").value == "Debit")
      if(event.value!="")
      if(event.value=="0")
        this.getField("txtAmountInWords").value = "ZERO ONLY";
      else
      this.getField("txtAmountInWords").value = number2text(this.getField
      ("txtDebitAmount").value)+" "+"ONLY";
      else
      this.getField("txtAmountInWords").value="";
