16 Replies Latest reply on May 14, 2015 6:34 AM by Steve Grisetti
    Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
    stryker4909
      After making several highlight videos for recruiting purposes, Adobe Elements Editor 12 suddenly became too slow to work.  Using a MacBook, I get the pinwheel of death no matter what I ask it to do, and attempting to do anything with video assets other than play them at normal speed causes the video to freeze in place.  Does anyone have any idea what could have changed so rapidly?
        • 2. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
          Is this problem on a brand new project, with no media added to it, or is it on a work in progress? It makes a difference.
          If the program overall is bogging down, first try going to the preferences and clearing the Media Cache. If that doesn't work, try starting the program while holding down the Cmd+Shift+Option keys on the left side of your keyboard to clear the preference file.
          But if this problem is only happening with a project in progress and not with a brand new project, it could be related to your project assets.
          • 3. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
            stryker4909 Level 1
            The problem is with the first clip I dragged to the work area out of a number of clips which I already imported into my project assets area.  These same type of clips from the same videographer have always worked fine before.  Thanks for trying to help.
            • 4. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
              Have you tried doing what I suggested?
              Also, if you open one of your video clips in G Spot or Media Info, what is the resolution, frame rate and audio and video codecs listed? It's the specs of your video that's clearly causing you problems.
              • 5. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                stryker4909 Level 1
                Yes. I tried your suggestions.  Nothing helped, although it seemed to at first.  The properties I could find are as follows:
                Type: MPEG Movie
                File Size: 1.2G
                Image Size:  1440 x 1080
                Frame Rate:  29.97
                Source Audio Format:  48000 Hz-16 bit stereo
                Project Audio Format:  48000 Hz-32 bit floating point stereo
                Pixel Aspect Ratio 1.333
                The application is just acting all around weird.  Even the clips I successfully add will only render to certain points, then stop and refuse to finish.  I am a novice with Premier 12, but actually worked with digital editing software back in the late 1990's when I had one of the first digital film companies focusing on youth sports.  In those days, $20,000 investments in equipment as startup were about standard.  These days I am quite lost so far.
                • 6. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                  I still don't see any information on your audio and video codecs, William. Formats and codecs are very different.
                  BTW, when you're working in Expert view in Premiere Elements, is there a yellow-orange line along the top of the timeline when you add new clips? This is an indication of a mismatch between your video and project specs and could well account for your slowdowns.
                  • 7. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                    stryker4909 Level 1
                    There is a yellow line through the middle of both the audio and video of both the clips that work well and the clips giving me problems, but no line on the top except the usual grey one.  Here is everything from Media Info:
                    Complete name : /Volumes/Seagate Backup Plus Drive 3/Final Cut Events/11 14 14/Original Media/2014-11-12 20_15_56 (id).mov
                    Format : MPEG-4
                    Format profile : QuickTime
                    Codec ID : qt
                    File size : 1.05 GiB
                    Duration : 15mn 22s
                    Overall bit rate mode : Variable
                    Overall bit rate : 9 770 Kbps
                    Encoded date : UTC 2014-11-13 04:39:49
                    Tagged date : UTC 2014-11-13 04:40:35
                    Writing library : Apple QuickTime
                    com.apple.proapps.reel : CANON_HDD
                    com.apple.proapps.isGood : 0
                    com.apple.proapps.dataSize : Unknown kind of value!
                    com.apple.proapps.displayFormat : 1080i60
                    com.apple.proapps.shootingRate : Unknown kind of value!
                    com.apple.proapps.videoBitrate : 0
                    com.apple.proapps.originalFormat : AVCHD 1080i60
                    com.apple.proapps.pulldown : 1
                    com.apple.proapps.mediaRate : Unknown kind of value!
                    com.apple.proapps.timecodeFormat : 1
                    com.apple.proapps.numberOfAudioChannels : 2
                    com.apple.proapps.sampleRate : 48000
                    com.apple.proapps.bitsPerSample : 16
                    com.apple.quicktime.creationdate : 2014-11-12T19:15:56-0600
                    com.apple.proapps.manufacturer : Canon
                    com.apple.proapps.clipFileName : Clip #6
                    com.apple.proapps.clipID : 000000003d3d7000398218348f97db32f36ff2f78754ee0b92039d0feea8f7f32a41c9a1d2bd201cd1dacdcfa 6b1760c1711304715cc782f17d50e6572d857f05299d40ffcc2a61ad53d2550ef275f0b9451d784fc883594
                    com.apple.proapps.RADSDKVersion : 3.1
                    com.apple.proapps.cameraName : CANON_HDD
                    com.apple.proapps.ingestDate.description : 2014-11-12 23:39:49 -0500
                    com.apple.quicktime.make : Apple
                    com.apple.quicktime.model : iMac11,2
                    com.apple.quicktime.software : Mac OS X 10.6.8 (10K549)
                    Video
                    Format : AVC
                    Format/Info : Advanced Video Codec
                    Format profile : High@L4
                    Format settings, CABAC : Yes
                    Format settings, ReFrames : 2 frames
                    Format settings, GOP : M=3, N=15
                    Codec ID : avc1
                    Codec ID/Info : Advanced Video Coding
                    Duration : 15mn 22s
                    Bit rate mode : Variable
                    Bit rate : 8 187 Kbps
                    Maximum bit rate : 16.0 Mbps
                    Width : 1 440 pixels
                    Height : 1 080 pixels
                    Display aspect ratio : 16:9
                    Frame rate mode : Constant
                    Frame rate : 29.970 fps
                    Color space : YUV
                    Chroma subsampling : 4:2:0
                    Bit depth : 8 bits
                    Scan type : Interlaced
                    Scan type, store method : Interleaved fields
                    Scan order : Top Field First
                    Bits/(Pixel*Frame) : 0.176
                    Stream size : 900 MiB (84%)
                    Title : Core Media Video
                    Color primaries : BT.709
                    Transfer characteristics : BT.709
                    Matrix coefficients : BT.709
                    Audio
                    Format : PCM
                    Format settings, Endianness : Little
                    Format settings, Sign : Signed
                    Codec ID : sowt
                    Duration : 15mn 22s
                    Source duration : 15mn 22s
                    Bit rate mode : Constant
                    Bit rate : 1 536 Kbps
                    Channel(s) : 2 channels
                    Channel positions : Front: L R
                    Sampling rate : 48.0 KHz
                    Bit depth : 16 bits
                    Stream size : 169 MiB (16%)
                    Source stream size : 169 MiB (16%)
                    Title : Core Media Audio
                    Other
                    Type : Time code
                    Format : QuickTime TC
                    Duration : 15mn 22s
                    Time code of first frame : 00:00:00;00
                    Time code, striped : Yes
                    Title : Core Media Time Code
                    • 8. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                      If you're not seeing a yellow-orange line along the top of your timeline and you're in Expert view, then your project is set up to match your video and it is performing as efficiently as possible. There must be something else at work.
                      I assume you've got a relatively new, fast computer. What processor do you have?
                      Do you have more than one hard drive? Where on your computer are your video clips located?
                      • 9. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                        stryker4909 Level 1
                        I wish!!! Here are the stats on my MacBook:
                        Model Name: MacBook Pro
                          Model Identifier: MacBookPro6,2
                          Processor Name: Intel Core i7
                          Processor Speed: 2.66 GHz
                          Number of Processors: 1
                          Total Number of Cores: 2
                          L2 Cache (per Core): 256 KB
                          L3 Cache: 4 MB
                          Memory: 4 GB
                          Processor Interconnect Speed: 4.8 GT/s
                          Boot ROM Version: MBP61.0057.B0F
                          SMC Version (system): 1.58f17
                          Serial Number (system): W8012928AGW
                          Hardware UUID: CE8D987D-C1AA-5D64-A8CD-9039F24561FA
                          Sudden Motion Sensor:
                          State: Enabled
                        The clips are kept on Seagate Backup Plus 3T external hard drives, but I presumed they were imported for the editing work, then exported back out when saved.  The problem is I have no difficulty with this videographer's other clips--hundreds of them--just these few critical ones I need for a kid's high school highlight video to show college coaches where he wants to apply for athletic  scholarships .  His best work is on these 5 or 6 clips. Although I was given other clips I can use and which work fine on my Mac, I hate to leave these best ones out.  Thanks again for your help Steve.
                        • 10. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                          Your hardware should be able to edit this video, William. So I'd say the bottleneck is your external connection to the files. (Even if you import them into a project, the media files themselves remain on your external hard drive.)
                          Try creating a new project and copying your files to your computer's main hard drive. When you import THOSE media files into your project, they should work perfectly!
                          • 11. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                            stryker4909 Level 1
                            I tried that with some benefit.  The audio worked normally, and the video was normal until I fast forwarded and stopped where I wanted to work on the clip.  At that point, once again, the video froze up and that was that.  I did notice, and this may mean nothing, that all of his other clips end in "mov." , whereas the problem clips end in "(id).mov.".  I have no idea why this would be so, but it may have some significance of which I am unaware.  If not, I just can't see what is wrong.
                            • 12. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                              Yes, that could be an indication that the clips are not all the same format/codec, which could account for the slowdown.
                              But as I said, if you're not seeing a yellow-orange above the clips along the top of the timeline in Expert view, that's not the case.
                              • 13. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                                A.T. Romano Level 7
                                stryker4909
                                I am strictly an Elements Windows user. All that being said, your problem files description ...(id).mov caught my attention.
                                What is the complete file name for one of these problem files. I found one online name .....(id).mov-HD.mp4. Do you have anything in your file name beyond (id).mov?
                                What happens if you rename the file
                                a. if you now see (id).mov, then just remove the (id)
                                b. if you have now (id),mov-HD.mp4, then just remove the (id).mov-HD, leaving just a .mp4 file.
                                I took "a" and "b" into Premiere Elements 12/12.1 on Windows 7 64 bit, and it did not make a difference...both imported into the program without issue.
                                I am not sure why Mac would be renaming some of your files, but could it be the renaming process that is slowing things down. Are there file storage/saving locations that need to be explored? Does the file name to the left of the (id).mov change also when the (id).mov appears?
                                Just some thoughts.
                                ATR
                                • 14. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                                  stryker4909 Level 1
                                  Thanks.  Just changing the file name didn't work, but running the video through photoshop and changing the filename there, then exporting the video back to my hard drive with the new name made the video completely normal.  Since I have a number of video files like this, and they have held me up for days now, the help I received on this forum was invaluable.  Thanks so much to Steve and A. T..
                                  • 15. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                                    A.T. Romano Level 7
                                    stryker
                                    Thank you for the great news on an interesting question and result. Great job.
                                    The information that you reported will be appreciated by all who find themselves in the same situation that you faced and are looking for answers.
                                    Best wishes moving forward in your Premiere Elements Mac projects.
                                    ATR
                                    • 16. Re: Adobe Elements Editor 12 suddenly too slow to work after working perfectly for weeks
                                      Great news, William! Please be sure to mark this question as answered!
