1 Reply Latest reply on May 10, 2015 5:34 AM by eossipov
    Extension Manager Opens but is not visible on screen.
    eossipov Level 1
      Photoshop CC (latest version)
      Extension Manager Same.
      PC, i5,
      2monitors, 1 HDTV, 1 Generic ( both 1920x1080)
      Once again, this happens... the extension manager opens, the application resides in the system tray, yet, the extension manager is not visible on screen.
      I have tried everything, including changing resolutions,
      Last time this happened it seemed to be an issue of Reading Which Monitor was 1 and which was 2, and the extension manager was "off the left hand side" of the monitor I have designated as 1 on the left side, therefore monitor 2 is to the right hand side.
      The extension manager, assumed (I guess) monitor 2 would be on the left, and put the extension managers default position 'off screen' even using 'control tab' the extension manager is visible with a white screen' (should be dark with writing on it)
      Cascading the windows does nothing.
      However, - IF I change my monitors and put the primary monitor as my HDTV
      THEN the Extension Manager will show on Monitor 2.
      Question:
      Is the extension manager not able to handle the HDTV Settings?
      OR
      Is the extension manager not able to update as monitor positions update after initial installation?
      imho, I believe this is a programming error, due to the following:
      As the program manager is launched, I believe the monitor positions are static from installation, therefore:
      I believe the extension manager is not able to update as monitors as changed from position 1 (desktopdefault) to position 2 (extended desktop)
      imho.
      ~elaine.
