11 Replies Latest reply on May 11, 2015 10:42 AM by jasonz82977625
    auto fill not working correctly
    jasonz82977625 Level 1
      I setup two drop downs and set the up to auto fill some text fields they all have unique name
      i have 7 text fields for each drop down to fill
      Like Data_Field_1 or Field_Data_2
      Box one is set to fill Data_Field_1
      Box 2 is set to fill Field_Data_2
      when i pick something from box one it fill Field_Data_2
      when i pick something from box 2 it fills Data_Field_1
      if select something from the drop down 3-4 times it will fill in the correct data
      this is what i have set to the drop down box and then changed Data_Field to  Field_Data_2 for the other one and did fill as Teat 1
      set as a Keystroke
      if( event.willCommit ) {
          if(event.value == "") this.resetForm(
          ["Data_Field_1", "Data_Field_2", "Data_Field_3", "Data_Field_4", "Data_Field_5", "Data_Field_6", "Data_Field_7" ]); else SetFieldValues(event.value);
      and i have this set as a run custom validation script
      var FillData = {
      "Select 1 " :{Data_Field_1: "Option 1", Data_Field_2: "Option 2", Data_Field_3: "Option 3", Data_Field_4: "Option 4", Data_Field_5: "Option 5", Data_Field_6: "Option 6", Data_Field_7: "Option 7"   },
      " Select 2" :{Data_Field_1: "Option 7", Data_Field_2: "Option 6", Data_Field_3: "Option 5", Data_Field_4: "Option 4", Data_Field_5: "Option 3", Data_Field_6: "Option 2", Data_Field_7: "Option 1"   }
      function SetFieldValues(cFillData) {
          this.getField("Data_Field_1").value = FillData[cFillData].Data_Field_1;
          this.getField("Data_Field_2").value = FillData[cFillData].Data_Field_2;
          this.getField("Data_Field_3").value = FillData[cFillData].Data_Field_3;
          this.getField("Data_Field_4").value = FillData[cFillData].Data_Field_4;
          this.getField("Data_Field_5").value = FillData[cFillData].Data_Field_5;
          this.getField("Data_Field_6").value = FillData[cFillData].Data_Field_6;
          this.getField("Data_Field_7").value = FillData[cFillData].Data_Field_7;
