7 Replies Latest reply on May 11, 2015 11:24 AM by rhin0ski
    Keyword Hierarchy Problem
    rhin0ski
      I just started using Keyword hierarchies.  After creating my first one, based on 'location', I find that trying to create a new one (like 'animals') places it under the 'Location' Keyword hierarchy.  So, how do I create a new hierarchy that stands alone?  To create the first hierarchy, I used the '+' symbol at the top of the keyword list.  When I use the '+' again, to create a new keyword, it automatically places it under the 'Location' hierarchy (even if I don't intend it to be a hierarchy).
        • 1. Re: Keyword Hierarchy Problem
          dj_paige Level 9
          You can drag and drop keywords after they have been created to the proper place in the hierarchy.
          To create new keywords that are not in some hierarcy, there are a number of options when the keyword is created. They are described here: Adobe Photoshop Lightroom Help | Keywords In particular, you don't want to check the box next to "Put Inside [keyword]"
          • 2. Re: Keyword Hierarchy Problem
            rhin0ski Level 1
            I have unchecked the "Put Inside 'Location'", but the keyword still gets created under 'Location'...arrrrgh! I am running LR 5.6 on Windows 7. Do I have to tag a photo first with the 'Animals' keyword?  I can't use the '+' key in the Keywords List.  It always puts the new keyword in the 'Location' hierarchy, even when "Put inside"  is unchecked.
            • 3. Re: Keyword Hierarchy Problem
              rhin0ski Level 1
              I just tried adding the 'animals' tag in the Keyword Tags field under the 'Keywording' tab.  It added the tag to the photo, but it also placed it in the 'Location' hierarchy.  So, it seems no matter what I do now, any new keywords appear under the 'Location' hierarchy.  Is only 1 hierarchy allowed, and once you choose to go that route, you have to stick with it?
              • 4. Re: Keyword Hierarchy Problem
                dj_paige Level 9
                I don't know what you're doing wrong, sometimes it helps to see a screen capture of all the steps you are following.
                Of course more than one hierarchy is allowed.
                • 5. Re: Keyword Hierarchy Problem
                  rhin0ski Level 1
                  Ok, here are the screen shots:
                  Here's the keyword list showing that 'animals' got created under the 'Location' hierarchy
                  Here I added animals in the 'Keyword Tags' field.  It still gets created under the 'Location' hierarchy.
                  Notice that I did not check the 'Put Inside' option, and it still created it under location...
                  I deleted the keyword each time under 'Location' as I tried these different options
                  • 6. Re: Keyword Hierarchy Problem
                    bhousto90 Level 4
                    Right click on the "Location" keyword
                    Then uncheck "Put New Keywords Inside this Keyword"
                    This default keyword location is noted by a plus sign/asterisk following the keyword name. (plus sign for regular keywords/asterisk for people keywords)
                    • 7. Re: Keyword Hierarchy Problem
                      rhin0ski Level 1
                      BINGO!  That did it!  Thanks so much for your help! It was driving me crazy...Now I can move on with my keywording!
