I am also having trouble installing flash on my mac. I uninstalled, deleted files form the library, and still not luck. what am I missing?
Hi char12345,
In order to provide help as quickly as possible, please put the following information into your post:
Thank you.
Maria
Thank you Maria,
Hi char12345,
Thanks for posting the screenshot. In order to troubleshoot I'll need to get some log files from your. From your screenshot, you're using the offline installer. Please see the FAQ Where do I find the Flash Player installation log on the Macintosh? and provide the install.log and FlashPlayerInstallManager.log files. The install.log file is a system file and contains a bunch of stuff that we don't need. The FAQ contains instructions on obtaining only the Flash Player related log data from the file.
The log files will be fairly large to post here in the forums, as such, please upload them using the instructions in the FAQ How to share a document and then post the link to the files here in the forums.
Thank you.
Maria
I am having the exact same issue. I have 10.10.3 OS X Yosemite. I have Safari web browser Version 8.0.6. This is the message I keep getting. I am not sure what version is the newest for the Flash. I tried to uninstall and do a clean install, but to no avail. I have also made sure that there the preferences are set correctly. It will install up until about 53% and then it fails every single time.
Hi twhite0309,
Thank you for posting the screenshot and providing your system information. I'll need to get log files from you to troubleshoot further. Please see the FAQ Where do I find the Flash Player installation log on the Macintosh? for instructions. Unlike the OP you're using the online installer and I'll need all four files mentioned in the FAQ: install.log, FlashPlayerInstallManager.log, Adobe_ADM.log, and Adobe_GDE.log.
Thank you.
Maria
Marker - May 11, 2015, 6:28:51 PM
Marker - May 11, 2015, 6:28:52 PM
May 11 18:31:05 Charless-MacBook-Air.local installer[778]: JS: Flash Player Install: Performing volume check for /
May 11 18:31:05 Charless-MacBook-Air.local installer[778]: JS: Flash Player Install: Volume check passed.
May 11 18:31:05 Charless-MacBook-Air.local installer[778]: JS: Flash Player Install: Performing volume check for /Volumes/Mini Drive
May 11 18:31:05 Charless-MacBook-Air.local installer[778]: JS: Flash Player Install: Error: Non-OS Volume detected.
May 11 18:31:05 Charless-MacBook-Air.local installer[778]: Product archive /Volumes/Flash Player/Install Adobe Flash Player.app/Contents/Resources/Adobe Flash Player.pkg trustLevel=3
Flash Manager Files:
2014-09-10 23:02:59 +0900 IM: ---------- log start ----------
2014-09-10 23:02:59 +0900 IM: All install checks pass
2014-09-10 23:02:59 +0900 IM: [install started]
2014-09-10 23:03:03 +0900 FIN: [finalizer started]
2014-09-10 23:03:03 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-09-10 23:03:03 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-09-10 23:03:04 +0900
installer: Package name is Adobe Flash Player
installer: Upgrading at base path /
installer: The upgrade was successful.
2014-09-10 23:03:06 +0900 IM: [install succeeded]
2014-09-10 23:03:06 +0900 IM: ---------- log end ----------
2014-10-26 18:24:46 +0900 IM: ---------- log start ----------
2014-10-26 18:24:46 +0900 IM: All install checks pass
2014-10-26 18:24:47 +0900
2014-10-26 18:24:47 +0900 IM: ---------- log end ----------
2014-10-26 18:24:53 +0900 IM: ---------- log start ----------
2014-10-26 18:24:53 +0900 IM: All install checks pass
2014-10-26 18:24:54 +0900 IM: User does not have any processes that need to be closed.
2014-10-26 18:24:54 +0900 IM: [install started]
2014-10-26 18:24:59 +0900 FIN: [finalizer started]
2014-10-26 18:24:59 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-10-26 18:24:59 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-10-26 18:25:01 +0900 FIN: [finalizer succeeded]
2014-10-26 18:25:06 +0900 IM: [install succeeded]
2014-10-26 18:25:06 +0900 IM: ---------- log end ----------
2014-11-12 21:17:12 +0900 FIN: [finalizer started]
2014-11-12 21:17:12 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-11-12 21:17:12 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-11-12 21:17:14 +0900 FIN: [finalizer succeeded]
2014-11-26 19:21:43 +0900 IM: ---------- log start ----------
2014-11-26 19:21:43 +0900 IM: All install checks pass
2014-11-26 19:21:43 +0900 IM: [install started]
2014-11-26 19:21:46 +0900 FIN: [finalizer started]
2014-11-26 19:21:46 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-11-26 19:21:46 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-11-26 19:21:48 +0900
2014-11-26 19:21:54 +0900 IM: [install succeeded]
2014-11-26 19:21:54 +0900 IM: ---------- log end ----------
2014-12-10 20:09:00 +0900 IM: ---------- log start ----------
2014-12-10 20:09:00 +0900 IM: All install checks pass
2014-12-10 20:09:00 +0900 IM: [install started]
2014-12-10 20:09:04 +0900 FIN: [finalizer started]
2014-12-10 20:09:04 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-12-10 20:09:04 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-12-10 20:09:06 +0900
2014-12-10 20:09:12 +0900 IM: [install succeeded]
2014-12-10 20:09:12 +0900 IM: ---------- log end ----------
2014-12-12 20:03:20 +0900 IM: ---------- log start ----------
2014-12-12 20:03:20 +0900 IM: All install checks pass
2014-12-12 20:03:21 +0900
2014-12-12 20:03:21 +0900 IM: ---------- log end ----------
2014-12-13 20:39:02 +0900 IM: ---------- log start ----------
2014-12-13 20:39:02 +0900 IM: All install checks pass
2014-12-13 20:39:02 +0900 IM: User does not have any processes that need to be closed.
2014-12-13 20:39:02 +0900 IM: [install started]
2014-12-13 20:39:08 +0900 FIN: [finalizer started]
2014-12-13 20:39:08 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-12-13 20:39:08 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-12-13 20:39:09 +0900 FIN: [finalizer succeeded]
2014-12-13 20:39:15 +0900 IM: [install succeeded]
2014-12-13 20:39:15 +0900 IM: ---------- log end ----------
2015-01-15 01:45:54 +0900 IM: ---------- log start ----------
2015-01-15 01:45:54 +0900 IM: All install checks pass
2015-01-15 01:45:54 +0900 IM: [install started]
2015-01-15 01:45:58 +0900 FIN: [finalizer started]
2015-01-15 01:45:58 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-01-15 01:45:58 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-01-15 01:46:00 +0900
2015-01-15 01:46:06 +0900 IM: [install succeeded]
2015-01-15 01:46:07 +0900 IM: ---------- log end ----------
2015-01-23 22:19:54 +0900 IM: ---------- log start ----------
2015-01-23 22:19:54 +0900 IM: All install checks pass
2015-01-23 22:19:54 +0900 IM: [install started]
2015-01-23 22:19:58 +0900 FIN: [finalizer started]
2015-01-23 22:19:58 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-01-23 22:19:58 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-01-23 22:20:00 +0900
2015-01-23 22:20:06 +0900 IM: [install succeeded]
2015-01-23 22:20:06 +0900 IM: ---------- log end ----------
2015-01-25 10:23:13 +0900 IM: ---------- log start ----------
2015-01-25 10:23:13 +0900 IM: All install checks pass
2015-01-25 10:23:13 +0900 IM: [install started]
2015-01-25 10:23:17 +0900 FIN: [finalizer started]
2015-01-25 10:23:17 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-01-25 10:23:17 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-01-25 10:23:18 +0900
2015-01-25 10:23:19 +0900
2015-01-25 10:23:25 +0900 IM: [install succeeded]
2015-01-25 10:23:25 +0900 IM: ---------- log end ----------
2015-02-06 00:30:52 +0900 IM: ---------- log start ----------
2015-02-06 00:30:52 +0900 IM: All install checks pass
2015-02-06 00:30:52 +0900 IM: [install started]
2015-02-06 00:30:57 +0900 FIN: [finalizer started]
2015-02-06 00:30:57 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-02-06 00:30:57 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-02-06 00:30:58 +0900
2015-02-06 00:31:05 +0900 IM: [install succeeded]
2015-02-06 00:31:05 +0900 IM: ---------- log end ----------
2015-03-15 21:48:50 +0900 IM: ---------- log start ----------
2015-03-15 21:48:50 +0900 IM: 1387
2015-03-15 21:48:53 +0900 IM: ---------- log end ----------
2015-03-15 21:49:42 +0900 IM: ---------- log start ----------
2015-03-15 21:49:42 +0900 IM: All install checks pass
2015-03-15 21:49:43 +0900
2015-03-15 21:49:43 +0900 IM: ---------- log end ----------
2015-03-15 22:28:15 +0900 IM: ---------- log start ----------
2015-03-15 22:28:15 +0900 IM: All install checks pass
2015-03-15 22:28:15 +0900 IM: User does not have any processes that need to be closed.
2015-03-15 22:28:15 +0900 IM: [install started]
2015-03-15 22:28:22 +0900 FIN: [finalizer started]
2015-03-15 22:28:22 +0900 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-03-15 22:28:22 +0900 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-03-15 22:28:25 +0900 FIN: [finalizer succeeded]
2015-03-15 22:28:29 +0900 IM: [install succeeded]
2015-03-15 22:28:29 +0900 IM: ---------- log end ----------
2015-04-15 16:16:30 -0400 IM: ---------- log start ----------
2015-04-15 16:16:30 -0400 IM: All install checks pass
2015-04-15 16:16:30 -0400 IM: [install started]
installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2015-04-15 16:16:32 -0400
2015-04-15 16:16:32 -0400 IM: ---------- log end ----------
2015-04-16 16:38:59 -0400 IM: ---------- log start ----------
2015-04-16 16:38:59 -0400 IM: All install checks pass
2015-04-16 16:38:59 -0400 IM: [install started]
2015-04-16 16:39:01 -0400
2015-04-16 16:39:01 -0400 IM: ---------- log end ----------
2015-04-16 16:39:02 -0400
2015-04-17 18:49:01 -0400 IM: ---------- log start ----------
2015-04-17 18:49:01 -0400 IM: All install checks pass
2015-04-17 18:49:01 -0400 IM: [install started]
2015-04-17 18:49:03 -0400
2015-04-17 18:49:03 -0400 IM: ---------- log end ----------
2015-04-17 18:49:04 -0400
2015-04-19 00:02:10 -0400 IM: ---------- log start ----------
2015-04-19 00:02:10 -0400 IM: All install checks pass
2015-04-19 00:02:10 -0400 IM: [install started]
2015-04-19 00:02:12 -0400
2015-04-19 00:02:12 -0400 IM: ---------- log end ----------
2015-04-20 07:41:25 -0400 IM: ---------- log start ----------
2015-04-20 07:41:25 -0400 IM: All install checks pass
2015-04-20 07:41:25 -0400 IM: [install started]
2015-04-20 07:41:27 -0400
2015-04-20 07:41:27 -0400 IM: ---------- log end ----------
2015-04-20 07:41:28 -0400
2015-04-20 20:07:37 -0400 IM: ---------- log start ----------
2015-04-20 20:07:38 -0400 IM: 1387
2015-04-20 20:08:16 -0400 IM: 15654593
2015-04-20 20:08:22 -0400 IM: ---------- log end ----------
2015-04-20 20:08:24 -0400 IM: ---------- log start ----------
2015-04-20 20:08:24 -0400 IM: All install checks pass
2015-04-20 20:08:37 -0400
2015-04-20 22:36:58 -0400 IM: [install started]
2015-04-20 22:37:04 -0400 IM: [install completed]
2015-04-20 22:37:06 -0400 IM: ---------- log end ----------
2015-04-21 08:03:19 -0400 IM: ---------- log start ----------
2015-04-21 08:03:19 -0400 IM: All install checks pass
2015-04-21 08:03:19 -0400 IM: [install started]
2015-04-21 08:03:21 -0400
2015-04-21 08:03:21 -0400 IM: ---------- log end ----------
2015-04-21 08:03:22 -0400
2015-04-22 09:17:01 -0400 IM: ---------- log start ----------
2015-04-22 09:17:01 -0400 IM: All install checks pass
2015-04-22 09:17:01 -0400 IM: [install started]
2015-04-22 09:17:03 -0400
2015-04-22 09:17:03 -0400 IM: ---------- log end ----------
2015-04-22 09:17:04 -0400
2015-04-22 10:44:42 -0400
2015-04-22 11:44:43 -0400
2015-04-22 12:44:44 -0400
2015-04-22 13:44:44 -0400
2015-04-22 14:44:45 -0400
2015-04-22 15:44:45 -0400
2015-04-22 16:51:28 -0400
2015-04-22 17:51:29 -0400
2015-04-22 18:51:29 -0400
2015-04-22 19:51:29 -0400
2015-04-22 20:51:30 -0400
2015-04-22 21:51:30 -0400
2015-04-22 22:51:30 -0400
2015-04-23 07:40:05 -0400
2015-04-23 08:40:05 -0400
2015-04-23 13:17:28 -0400
2015-04-23 14:17:28 -0400
2015-04-23 15:17:28 -0400
2015-04-23 16:17:29 -0400
2015-04-23 17:17:29 -0400
2015-04-23 18:17:29 -0400
2015-04-23 19:17:30 -0400
2015-04-23 20:17:30 -0400
2015-04-23 21:17:31 -0400
2015-04-23 22:17:31 -0400
2015-04-23 23:17:32 -0400
2015-04-24 08:30:41 -0400
2015-04-24 09:30:42 -0400
2015-04-24 10:30:42 -0400
2015-04-24 11:30:42 -0400
2015-04-24 12:30:43 -0400
2015-04-24 13:30:43 -0400
2015-04-24 16:09:48 -0400
2015-04-24 18:03:59 -0400 IM: ---------- log start ----------
2015-04-24 18:03:59 -0400 IM: All install checks pass
2015-04-24 18:04:00 -0400
2015-04-24 18:04:00 -0400 IM: ---------- log end ----------
2015-04-24 18:04:35 -0400 IM: ---------- log start ----------
2015-04-24 18:04:35 -0400 IM: All install checks pass
2015-04-24 18:04:35 -0400 IM: ---------- log end ----------
2015-04-24 18:04:39 -0400 IM: ---------- log start ----------
2015-04-24 18:04:39 -0400 IM: All install checks pass
2015-04-24 18:04:39 -0400 IM: ---------- log end ----------
2015-04-24 18:04:47 -0400 IM: ---------- log start ----------
2015-04-24 18:04:47 -0400 IM: All install checks pass
2015-04-24 18:04:47 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 18:04:47 -0400 IM: [install started]
2015-04-24 18:04:51 -0400
2015-04-24 18:04:51 -0400 IM: ---------- log end ----------
2015-04-24 19:01:24 -0400
2015-04-24 19:30:32 -0400 IM: ---------- log start ----------
2015-04-24 19:30:32 -0400 IM: All install checks pass
2015-04-24 19:30:33 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 19:30:33 -0400 IM: [install started]
2015-04-24 19:30:34 -0400
2015-04-24 19:30:34 -0400 IM: ---------- log end ----------
2015-04-24 19:33:07 -0400 IM: ---------- log start ----------
2015-04-24 19:33:07 -0400 IM: All install checks pass
2015-04-24 19:33:08 -0400
2015-04-24 19:33:08 -0400 IM: ---------- log end ----------
2015-04-24 19:33:15 -0400 IM: ---------- log start ----------
2015-04-24 19:33:15 -0400 IM: All install checks pass
2015-04-24 19:33:15 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 19:33:15 -0400 IM: [install started]
2015-04-24 19:33:16 -0400
2015-04-24 19:33:16 -0400 IM: ---------- log end ----------
2015-04-24 19:35:19 -0400 IM: ---------- log start ----------
2015-04-24 19:35:19 -0400 IM: All install checks pass
2015-04-24 19:35:19 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 19:35:19 -0400 IM: [install started]
2015-04-24 19:35:20 -0400
2015-04-24 19:35:20 -0400 IM: ---------- log end ----------
2015-04-24 19:38:50 -0400 IM: ---------- log start ----------
2015-04-24 19:38:50 -0400 IM: All install checks pass
2015-04-24 19:38:56 -0400
2015-04-24 19:39:02 -0400 IM: [install started]
installer: Package name is Adobe Pepper Flash Player
2015-04-24 19:39:03 -0400 IM: [install completed]
2015-04-24 19:39:09 -0400 IM: ---------- log end ----------
2015-04-24 19:39:45 -0400 IM: ---------- log start ----------
2015-04-24 19:39:45 -0400 IM: All install checks pass
2015-04-24 19:39:46 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 19:39:46 -0400 IM: [install started]
2015-04-24 19:39:47 -0400
2015-04-24 19:39:47 -0400 IM: ---------- log end ----------
2015-04-24 19:44:32 -0400 IM: ---------- log start ----------
2015-04-24 19:44:32 -0400 IM: All install checks pass
2015-04-24 19:44:39 -0400
2015-04-24 19:44:51 -0400 IM: [install started]
2015-04-24 19:44:52 -0400 IM: [install completed]
2015-04-24 19:46:54 -0400 IM: ---------- log start ----------
2015-04-24 19:46:59 -0400
2015-04-24 19:47:05 -0400 IM: Uninstall Started
2015-04-24 19:47:05 -0400 IM: [uninstall start]
2015-04-24 19:47:05 -0400 IM: user authorized
2015-04-24 19:47:05 -0400 IM: [file removal start]
2015-04-24 19:47:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 19:47:06 -0400 IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2015-04-24 19:47:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 19:47:06 -0400 IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2015-04-24 19:47:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 19:47:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 19:47:06 -0400 IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2015-04-24 19:47:07 -0400 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2015-04-24 19:47:07 -0400 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml'
2015-04-24 19:47:07 -0400 IM: Did not find bundle receipt to remove.
2015-04-24 19:47:12 -0400 IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2015-04-24 19:47:12 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-04-24 19:47:12 -0400 IM: [file removal end]
2015-04-24 19:47:12 -0400 IM: [uninstall end]
2015-04-24 19:47:13 -0400 IM: Uninstall Ended
2015-04-24 19:47:13 -0400 IM: ---------- log end ----------
2015-04-24 19:47:23 -0400
2015-04-24 19:47:23 -0400 IM: ---------- log end ----------
2015-04-24 19:47:28 -0400 IM: ---------- log start ----------
2015-04-24 19:47:28 -0400 IM: All install checks pass
2015-04-24 19:47:34 -0400
2015-04-24 19:47:37 -0400 IM: ---------- log end ----------
2015-04-24 19:50:14 -0400 IM: ---------- log start ----------
2015-04-24 19:50:14 -0400 IM: All install checks pass
2015-04-24 19:50:20 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-04-24 19:50:20 -0400 IM: [install started]
2015-04-24 19:50:21 -0400 IM: [install completed]
2015-04-24 19:51:50 -0400 IM: ---------- log start ----------
2015-04-24 19:51:54 -0400
2015-04-24 19:52:06 -0400 IM: Uninstall Started
2015-04-24 19:52:06 -0400 IM: [uninstall start]
2015-04-24 19:52:06 -0400 IM: user authorized
2015-04-24 19:52:06 -0400 IM: [file removal start]
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-04-24 19:52:06 -0400 IM: Did not find bundle receipt to remove.
2015-04-24 19:52:07 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-04-24 19:52:07 -0400 IM: [file removal end]
2015-04-24 19:52:07 -0400 IM: [uninstall end]
2015-04-24 19:52:07 -0400 IM: Uninstall Ended
2015-04-24 19:52:08 -0400 IM: ---------- log end ----------
2015-04-24 19:55:59 -0400 IM: ---------- log end ----------
2015-04-24 19:58:17 -0400 IM: ---------- log start ----------
2015-04-24 19:58:17 -0400 IM: All install checks pass
2015-04-24 19:58:17 -0400 IM: ---------- log end ----------
2015-04-24 19:58:24 -0400 IM: ---------- log start ----------
2015-04-24 19:58:24 -0400 IM: All install checks pass
2015-04-24 19:58:24 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 19:58:24 -0400 IM: [install started]
2015-04-24 19:58:25 -0400
2015-04-24 19:58:25 -0400 IM: ---------- log end ----------
2015-04-24 19:59:37 -0400 IM: ---------- log start ----------
2015-04-24 19:59:41 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-04-24 19:59:41 -0400 IM: Uninstall Started
2015-04-24 19:59:41 -0400 IM: [uninstall start]
2015-04-24 19:59:41 -0400 IM: user authorized
2015-04-24 19:59:41 -0400 IM: [file removal start]
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-04-24 19:59:42 -0400 IM: Did not find bundle receipt to remove.
2015-04-24 19:59:42 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-04-24 19:59:42 -0400 IM: [file removal end]
2015-04-24 19:59:42 -0400 IM: [uninstall end]
2015-04-24 19:59:42 -0400 IM: Uninstall Ended
2015-04-24 19:59:43 -0400 IM: ---------- log end ----------
2015-04-24 19:59:59 -0400 IM: ---------- log start ----------
2015-04-24 19:59:59 -0400 IM: All install checks pass
2015-04-24 20:00:05 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-04-24 20:00:05 -0400 IM: [install started]
2015-04-24 20:00:06 -0400 IM: [install completed]
2015-04-24 20:00:11 -0400
2015-04-24 20:00:11 -0400 IM: ---------- log end ----------
2015-04-24 20:09:07 -0400 IM: ---------- log start ----------
2015-04-24 20:09:07 -0400 IM: All install checks pass
2015-04-24 20:09:13 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-04-24 20:09:13 -0400 IM: [install started]
2015-04-24 20:09:14 -0400 IM: [install completed]
2015-04-24 20:11:07 -0400 IM: ---------- log start ----------
2015-04-24 20:11:07 -0400 IM: All install checks pass
2015-04-24 20:11:12 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-04-24 20:11:12 -0400 IM: [install started]
2015-04-24 20:11:13 -0400 IM: [install completed]
2015-04-24 20:11:15 -0400
2015-04-24 20:11:15 -0400 IM: ---------- log end ----------
2015-04-24 20:11:30 -0400 IM: ---------- log start ----------
2015-04-24 20:11:35 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-04-24 20:11:35 -0400 IM: Uninstall Started
2015-04-24 20:11:35 -0400 IM: [uninstall start]
2015-04-24 20:11:35 -0400 IM: user authorized
2015-04-24 20:11:35 -0400 IM: [file removal start]
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-04-24 20:11:35 -0400 IM: Did not find bundle receipt to remove.
2015-04-24 20:11:35 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-04-24 20:11:35 -0400 IM: [file removal end]
2015-04-24 20:11:35 -0400 IM: [uninstall end]
2015-04-24 20:11:35 -0400 IM: Uninstall Ended
2015-04-24 20:11:36 -0400 IM: ---------- log end ----------
2015-04-24 20:13:34 -0400
2015-04-24 20:13:34 -0400 IM: ---------- log end ----------
2015-04-24 20:15:54 -0400 IM: ---------- log start ----------
2015-04-24 20:15:54 -0400 IM: All install checks pass
2015-04-24 20:15:54 -0400 IM: User does not have any processes that need to be closed.
2015-04-24 20:15:54 -0400 IM: [install started]
2015-04-24 20:15:55 -0400
2015-04-24 20:15:55 -0400 IM: ---------- log end ----------
2015-04-24 20:17:12 -0400 IM: ---------- log start ----------
2015-04-24 20:17:16 -0400
2015-04-24 20:17:21 -0400 IM: Uninstall Started
2015-04-24 20:17:21 -0400 IM: [uninstall start]
2015-04-24 20:17:21 -0400 IM: user authorized
2015-04-24 20:17:21 -0400 IM: [file removal start]
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-04-24 20:17:21 -0400 IM: Did not find bundle receipt to remove.
2015-04-24 20:17:22 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-04-24 20:17:22 -0400 IM: [file removal end]
2015-04-24 20:17:22 -0400 IM: [uninstall end]
2015-04-24 20:17:22 -0400 IM: Uninstall Ended
2015-04-24 20:17:22 -0400 IM: ---------- log end ----------
2015-04-24 20:24:43 -0400 FIN: [finalizer started]
2015-04-24 20:24:43 -0400 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-04-24 20:24:43 -0400 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-04-24 20:24:45 -0400 FIN: [finalizer succeeded]
2015-05-09 08:15:02 -0400 IM: ---------- log start ----------
2015-05-09 08:15:02 -0400 IM: All install checks pass
2015-05-09 08:15:03 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 08:15:03 -0400 IM: [install started]
2015-05-09 08:15:12 -0400
2015-05-09 08:15:12 -0400 IM: ---------- log end ----------
2015-05-09 08:17:15 -0400 IM: ---------- log start ----------
2015-05-09 08:17:15 -0400 IM: All install checks pass
2015-05-09 08:17:15 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 08:17:15 -0400 IM: [install started]
2015-05-09 08:17:16 -0400
2015-05-09 08:17:16 -0400 IM: ---------- log end ----------
2015-05-09 08:28:46 -0400 IM: ---------- log start ----------
2015-05-09 08:28:46 -0400 IM: All install checks pass
2015-05-09 08:28:51 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 08:28:51 -0400 IM: [install started]
2015-05-09 08:28:53 -0400 IM: [install completed]
2015-05-09 08:28:55 -0400 IM: ---------- log end ----------
2015-05-09 08:34:45 -0400 IM: ---------- log start ----------
2015-05-09 08:34:45 -0400 IM: All install checks pass
2015-05-09 08:34:50 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 08:34:50 -0400 IM: [install started]
2015-05-09 08:34:52 -0400 IM: [install completed]
2015-05-09 08:34:56 -0400 IM: ---------- log end ----------
2015-05-09 08:37:46 -0400 IM: ---------- log start ----------
2015-05-09 08:37:51 -0400
2015-05-09 08:37:59 -0400 IM: Uninstall Started
2015-05-09 08:37:59 -0400 IM: [uninstall start]
2015-05-09 08:37:59 -0400 IM: user authorized
2015-05-09 08:37:59 -0400 IM: [file removal start]
2015-05-09 08:38:00 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 08:38:00 -0400 IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2015-05-09 08:38:00 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 08:38:00 -0400 IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2015-05-09 08:38:00 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 08:38:00 -0400 IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2015-05-09 08:38:00 -0400 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2015-05-09 08:38:00 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-09 08:38:00 -0400 IM: Did not find bundle receipt to remove.
2015-05-09 08:38:06 -0400 IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2015-05-09 08:38:07 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-09 08:38:07 -0400 IM: [file removal end]
2015-05-09 08:38:07 -0400 IM: [uninstall end]
2015-05-09 08:38:07 -0400 IM: Uninstall Ended
2015-05-09 08:38:08 -0400 IM: ---------- log end ----------
2015-05-09 08:38:21 -0400 IM: ---------- log start ----------
2015-05-09 08:38:21 -0400 IM: All install checks pass
2015-05-09 08:38:26 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 08:38:26 -0400 IM: [install started]
2015-05-09 08:38:27 -0400 IM: [install completed]
2015-05-09 08:38:30 -0400
2015-05-09 08:38:30 -0400 IM: ---------- log end ----------
2015-05-09 08:44:43 -0400 IM: ---------- log start ----------
2015-05-09 08:44:43 -0400 IM: All install checks pass
2015-05-09 08:44:49 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 08:44:49 -0400 IM: [install started]
2015-05-09 08:44:50 -0400 IM: [install completed]
2015-05-09 08:45:01 -0400 IM: ---------- log end ----------
2015-05-09 08:49:31 -0400 IM: ---------- log start ----------
2015-05-09 08:49:31 -0400 IM: All install checks pass
2015-05-09 08:49:40 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 08:49:40 -0400 IM: [install started]
2015-05-09 08:49:42 -0400 IM: [install completed]
2015-05-09 08:49:53 -0400
2015-05-09 08:49:53 -0400 IM: ---------- log end ----------
2015-05-09 08:50:03 -0400 IM: ---------- log start ----------
2015-05-09 08:50:07 -0400
2015-05-09 08:50:10 -0400 IM: ---------- log end ----------
2015-05-09 08:50:13 -0400 IM: ---------- log start ----------
2015-05-09 08:50:17 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-05-09 08:50:17 -0400 IM: Uninstall Started
2015-05-09 08:50:17 -0400 IM: [uninstall start]
2015-05-09 08:50:17 -0400 IM: user authorized
2015-05-09 08:50:17 -0400 IM: [file removal start]
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-09 08:50:18 -0400 IM: Did not find bundle receipt to remove.
2015-05-09 08:50:18 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-09 08:50:18 -0400 IM: [file removal end]
2015-05-09 08:50:18 -0400 IM: [uninstall end]
2015-05-09 08:50:18 -0400 IM: Uninstall Ended
2015-05-09 08:50:19 -0400 IM: ---------- log end ----------
2015-05-09 08:51:55 -0400 IM: ---------- log start ----------
2015-05-09 08:51:55 -0400 IM: All install checks pass
2015-05-09 08:52:00 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 08:52:00 -0400 IM: [install started]
2015-05-09 08:52:04 -0400 IM: [install completed]
2015-05-09 08:52:08 -0400
2015-05-09 08:52:08 -0400 IM: ---------- log end ----------
2015-05-09 09:02:38 -0400 IM: ---------- log start ----------
2015-05-09 09:02:38 -0400 IM: All install checks pass
2015-05-09 09:02:43 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:02:43 -0400 IM: [install started]
2015-05-09 09:02:47 -0400 IM: [install completed]
2015-05-09 09:02:48 -0400
2015-05-09 09:02:48 -0400 IM: ---------- log end ----------
2015-05-09 09:25:46 -0400 IM: ---------- log start ----------
2015-05-09 09:25:46 -0400 IM: All install checks pass
2015-05-09 09:25:53 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:25:53 -0400 IM: [install started]
2015-05-09 09:25:57 -0400 IM: [install completed]
2015-05-09 09:25:59 -0400
2015-05-09 09:25:59 -0400 IM: ---------- log end ----------
2015-05-09 09:26:12 -0400 IM: ---------- log start ----------
2015-05-09 09:26:16 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-05-09 09:26:16 -0400 IM: Uninstall Started
2015-05-09 09:26:16 -0400 IM: [uninstall start]
2015-05-09 09:26:16 -0400 IM: user authorized
2015-05-09 09:26:16 -0400 IM: [file removal start]
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-09 09:26:17 -0400 IM: Did not find bundle receipt to remove.
2015-05-09 09:26:17 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-09 09:26:17 -0400 IM: [file removal end]
2015-05-09 09:26:17 -0400 IM: [uninstall end]
2015-05-09 09:26:17 -0400 IM: Uninstall Ended
2015-05-09 09:26:18 -0400 IM: ---------- log end ----------
2015-05-09 09:26:27 -0400 IM: ---------- log start ----------
2015-05-09 09:26:31 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-05-09 09:26:31 -0400 IM: Uninstall Started
2015-05-09 09:26:31 -0400 IM: [uninstall start]
2015-05-09 09:26:31 -0400 IM: user authorized
2015-05-09 09:26:31 -0400 IM: [file removal start]
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-09 09:26:31 -0400 IM: Did not find bundle receipt to remove.
2015-05-09 09:26:31 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-09 09:26:31 -0400 IM: [file removal end]
2015-05-09 09:26:31 -0400 IM: [uninstall end]
2015-05-09 09:26:31 -0400 IM: Uninstall Ended
2015-05-09 09:26:33 -0400 IM: ---------- log end ----------
2015-05-09 09:26:57 -0400 IM: ---------- log start ----------
2015-05-09 09:26:57 -0400 IM: All install checks pass
2015-05-09 09:27:02 -0400
2015-05-09 09:27:07 -0400 IM: ---------- log end ----------
2015-05-09 09:27:20 -0400 IM: ---------- log start ----------
2015-05-09 09:27:20 -0400 IM: All install checks pass
2015-05-09 09:27:30 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:27:30 -0400 IM: [install started]
2015-05-09 09:27:32 -0400 IM: [install completed]
2015-05-09 09:27:33 -0400
2015-05-09 09:27:33 -0400 IM: ---------- log end ----------
2015-05-09 09:38:06 -0400 IM: ---------- log start ----------
2015-05-09 09:38:06 -0400 IM: All install checks pass
2015-05-09 09:38:12 -0400
2015-05-09 09:38:13 -0400 IM: ---------- log end ----------
2015-05-09 09:38:16 -0400 IM: ---------- log start ----------
2015-05-09 09:38:16 -0400 IM: All install checks pass
2015-05-09 09:38:21 -0400
2015-05-09 09:38:23 -0400 IM: ---------- log end ----------
2015-05-09 09:38:38 -0400 IM: ---------- log start ----------
2015-05-09 09:38:38 -0400 IM: All install checks pass
2015-05-09 09:38:42 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:38:43 -0400 IM: [install started]
2015-05-09 09:38:46 -0400 IM: [install completed]
2015-05-09 09:38:48 -0400
2015-05-09 09:38:48 -0400 IM: ---------- log end ----------
2015-05-09 09:40:45 -0400 IM: ---------- log start ----------
2015-05-09 09:40:45 -0400 IM: All install checks pass
2015-05-09 09:40:50 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:40:51 -0400 IM: [install started]
2015-05-09 09:40:52 -0400 IM: [install completed]
2015-05-09 09:40:54 -0400
2015-05-09 09:40:54 -0400 IM: ---------- log end ----------
2015-05-09 09:43:37 -0400 IM: ---------- log start ----------
2015-05-09 09:43:37 -0400 IM: All install checks pass
2015-05-09 09:43:37 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 09:43:37 -0400 IM: [install started]
2015-05-09 09:43:38 -0400
2015-05-09 09:43:38 -0400 IM: ---------- log end ----------
2015-05-09 09:43:54 -0400 IM: ---------- log start ----------
2015-05-09 09:43:58 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-05-09 09:43:58 -0400 IM: Uninstall Started
2015-05-09 09:43:58 -0400 IM: [uninstall start]
2015-05-09 09:43:58 -0400 IM: user authorized
2015-05-09 09:43:58 -0400 IM: [file removal start]
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-09 09:43:59 -0400 IM: Did not find bundle receipt to remove.
2015-05-09 09:43:59 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-09 09:43:59 -0400 IM: [file removal end]
2015-05-09 09:43:59 -0400 IM: [uninstall end]
2015-05-09 09:43:59 -0400 IM: Uninstall Ended
2015-05-09 09:44:00 -0400 IM: ---------- log end ----------
2015-05-09 09:44:38 -0400 IM: ---------- log start ----------
2015-05-09 09:44:38 -0400 IM: All install checks pass
2015-05-09 09:44:44 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:44:44 -0400 IM: [install started]
2015-05-09 09:44:46 -0400 IM: [install completed]
2015-05-09 09:44:47 -0400
2015-05-09 09:44:47 -0400 IM: ---------- log end ----------
2015-05-09 09:46:48 -0400 IM: ---------- log start ----------
2015-05-09 09:46:48 -0400 IM: All install checks pass
2015-05-09 09:46:48 -0400 IM: ---------- log end ----------
2015-05-09 09:46:54 -0400 IM: ---------- log start ----------
2015-05-09 09:46:54 -0400 IM: All install checks pass
2015-05-09 09:46:54 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 09:46:54 -0400 IM: [install started]
2015-05-09 09:46:55 -0400
2015-05-09 09:46:55 -0400 IM: ---------- log end ----------
2015-05-09 09:47:49 -0400 IM: ---------- log start ----------
2015-05-09 09:47:49 -0400 IM: All install checks pass
2015-05-09 09:47:49 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 09:47:49 -0400 IM: [install started]
2015-05-09 09:47:50 -0400
2015-05-09 09:47:50 -0400 IM: ---------- log end ----------
2015-05-09 09:49:33 -0400 IM: ---------- log start ----------
2015-05-09 09:49:33 -0400 IM: All install checks pass
2015-05-09 09:49:33 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 09:49:33 -0400 IM: [install started]
2015-05-09 09:49:34 -0400
2015-05-09 09:49:34 -0400 IM: ---------- log end ----------
2015-05-09 09:49:56 -0400 IM: ---------- log start ----------
2015-05-09 09:49:56 -0400 IM: All install checks pass
2015-05-09 09:50:02 -0400
2015-05-09 09:50:07 -0400 IM: [install started]
2015-05-09 09:50:08 -0400 IM: [install completed]
2015-05-09 09:50:09 -0400
2015-05-09 09:50:09 -0400 IM: ---------- log end ----------
2015-05-09 09:50:11 -0400 IM: ---------- log start ----------
2015-05-09 09:50:11 -0400 IM: All install checks pass
2015-05-09 09:50:17 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:50:18 -0400 IM: [install started]
2015-05-09 09:50:19 -0400 IM: [install completed]
2015-05-09 09:52:57 -0400
2015-05-09 09:52:57 -0400 IM: ---------- log end ----------
2015-05-09 09:55:38 -0400 IM: ---------- log start ----------
2015-05-09 09:55:38 -0400 IM: All install checks pass
2015-05-09 09:55:38 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 09:55:38 -0400 IM: [install started]
2015-05-09 09:55:39 -0400
2015-05-09 09:55:39 -0400 IM: ---------- log end ----------
2015-05-09 09:59:05 -0400 IM: ---------- log start ----------
2015-05-09 09:59:05 -0400 IM: All install checks pass
2015-05-09 09:59:05 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 09:59:05 -0400 IM: [install started]
2015-05-09 09:59:06 -0400
2015-05-09 09:59:06 -0400 IM: ---------- log end ----------
2015-05-09 09:59:39 -0400 IM: ---------- log start ----------
2015-05-09 09:59:39 -0400 IM: All install checks pass
2015-05-09 09:59:44 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 09:59:44 -0400 IM: [install started]
2015-05-09 09:59:45 -0400 IM: [install completed]
2015-05-09 09:59:47 -0400
2015-05-09 09:59:47 -0400 IM: ---------- log end ----------
2015-05-09 10:01:23 -0400 IM: ---------- log start ----------
2015-05-09 10:01:23 -0400 IM: All install checks pass
2015-05-09 10:01:29 -0400
2015-05-09 10:01:34 -0400 IM: [install started]
2015-05-09 10:01:35 -0400 IM: [install completed]
2015-05-09 10:01:36 -0400
2015-05-09 10:01:36 -0400 IM: ---------- log end ----------
2015-05-09 10:01:46 -0400 IM: ---------- log start ----------
2015-05-09 10:01:49 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-05-09 10:01:49 -0400 IM: Uninstall Started
2015-05-09 10:01:49 -0400 IM: [uninstall start]
2015-05-09 10:01:49 -0400 IM: user authorized
2015-05-09 10:01:49 -0400 IM: [file removal start]
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-09 10:01:50 -0400 IM: Did not find bundle receipt to remove.
2015-05-09 10:01:50 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-09 10:01:50 -0400 IM: [file removal end]
2015-05-09 10:01:50 -0400 IM: [uninstall end]
2015-05-09 10:01:50 -0400 IM: Uninstall Ended
2015-05-09 10:01:51 -0400 IM: ---------- log end ----------
2015-05-09 10:01:56 -0400 IM: ---------- log start ----------
2015-05-09 10:01:56 -0400 IM: All install checks pass
2015-05-09 10:02:01 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 10:02:02 -0400 IM: [install started]
2015-05-09 10:02:03 -0400 IM: [install completed]
2015-05-09 10:02:05 -0400
2015-05-09 10:02:05 -0400 IM: ---------- log end ----------
2015-05-09 10:06:45 -0400 IM: ---------- log start ----------
2015-05-09 10:06:45 -0400 IM: All install checks pass
2015-05-09 10:06:51 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 10:06:51 -0400 IM: [install started]
2015-05-09 10:06:52 -0400 IM: [install completed]
2015-05-09 10:06:53 -0400
2015-05-09 10:06:53 -0400 IM: ---------- log end ----------
2015-05-09 10:10:19 -0400 IM: ---------- log start ----------
2015-05-09 10:10:19 -0400 IM: All install checks pass
2015-05-09 10:10:21 -0400 IM: ---------- log end ----------
2015-05-09 10:10:28 -0400 IM: ---------- log start ----------
2015-05-09 10:10:28 -0400 IM: All install checks pass
2015-05-09 10:10:34 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-09 10:10:34 -0400 IM: [install started]
2015-05-09 10:10:35 -0400 IM: [install completed]
2015-05-09 10:10:36 -0400 IM: ---------- log end ----------
2015-05-09 10:14:36 -0400 IM: ---------- log start ----------
2015-05-09 10:14:36 -0400 IM: All install checks pass
2015-05-09 10:14:41 -0400
2015-05-09 10:14:46 -0400 IM: [install started]
2015-05-09 10:14:47 -0400 IM: [install completed]
2015-05-09 10:14:49 -0400 IM: ---------- log end ----------
2015-05-09 10:18:31 -0400 IM: ---------- log start ----------
2015-05-09 10:18:31 -0400 IM: All install checks pass
2015-05-09 10:18:36 -0400
2015-05-09 10:18:47 -0400 IM: [install started]
2015-05-09 10:18:48 -0400 IM: [install completed]
2015-05-09 10:18:49 -0400 IM: ---------- log end ----------
2015-05-09 10:21:23 -0400 IM: ---------- log start ----------
2015-05-09 10:21:23 -0400 IM: All install checks pass
2015-05-09 10:21:23 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 10:21:23 -0400 IM: [install started]
2015-05-09 10:21:25 -0400
2015-05-09 10:21:25 -0400 IM: ---------- log end ----------
2015-05-09 10:22:39 -0400 IM: ---------- log start ----------
2015-05-09 10:22:39 -0400 IM: All install checks pass
2015-05-09 10:22:39 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 10:22:39 -0400 IM: [install started]
2015-05-09 10:22:40 -0400
2015-05-09 10:22:40 -0400 IM: ---------- log end ----------
2015-05-09 10:23:35 -0400 IM: ---------- log start ----------
2015-05-09 10:23:35 -0400 IM: All install checks pass
2015-05-09 10:23:35 -0400 IM: User does not have any processes that need to be closed.
2015-05-09 10:23:35 -0400 IM: [install started]
2015-05-09 10:23:36 -0400
2015-05-09 10:23:36 -0400 IM: ---------- log end ----------
2015-05-10 21:08:26 -0400 IM: ---------- log start ----------
2015-05-10 21:08:26 -0400 IM: All install checks pass
2015-05-10 21:08:26 -0400 IM: User does not have any processes that need to be closed.
2015-05-10 21:08:26 -0400 IM: [install started]
2015-05-10 21:08:30 -0400
2015-05-10 21:08:30 -0400 IM: ---------- log end ----------
2015-05-10 21:08:58 -0400 IM: ---------- log start ----------
2015-05-10 21:08:58 -0400 IM: All install checks pass
2015-05-10 21:09:04 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 21:09:04 -0400 IM: [install started]
2015-05-10 21:09:05 -0400 IM: [install completed]
2015-05-10 21:09:08 -0400
2015-05-10 21:09:08 -0400 IM: ---------- log end ----------
2015-05-10 21:09:19 -0400 IM: ---------- log start ----------
2015-05-10 21:09:24 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-05-10 21:09:24 -0400 IM: Uninstall Started
2015-05-10 21:09:24 -0400 IM: [uninstall start]
2015-05-10 21:09:24 -0400 IM: user authorized
2015-05-10 21:09:24 -0400 IM: [file removal start]
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-10 21:09:25 -0400 IM: Did not find bundle receipt to remove.
2015-05-10 21:09:25 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-10 21:09:25 -0400 IM: [file removal end]
2015-05-10 21:09:25 -0400 IM: [uninstall end]
2015-05-10 21:09:25 -0400 IM: Uninstall Ended
2015-05-10 21:09:38 -0400 IM: ---------- log end ----------
2015-05-10 21:10:02 -0400 IM: ---------- log start ----------
2015-05-10 21:10:02 -0400 IM: All install checks pass
2015-05-10 21:10:07 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 21:10:07 -0400 IM: [install started]
installer: Package name is Adobe Flash Player
2015-05-10 21:10:08 -0400 IM: [install completed]
2015-05-10 21:10:09 -0400
2015-05-10 21:10:09 -0400 IM: ---------- log end ----------
2015-05-10 21:21:56 -0400 IM: ---------- log start ----------
2015-05-10 21:21:56 -0400 IM: All install checks pass
2015-05-10 21:22:04 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 21:22:04 -0400 IM: [install started]
2015-05-10 21:22:06 -0400 IM: [install completed]
2015-05-10 21:22:13 -0400
2015-05-10 21:22:13 -0400 IM: ---------- log end ----------
2015-05-10 21:39:49 -0400 IM: ---------- log start ----------
2015-05-10 21:39:49 -0400 IM: All install checks pass
2015-05-10 21:39:55 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 21:39:55 -0400 IM: [install started]
2015-05-10 21:39:56 -0400 IM: [install completed]
2015-05-10 21:40:00 -0400
2015-05-10 21:40:00 -0400 IM: ---------- log end ----------
2015-05-10 21:49:06 -0400 IM: ---------- log start ----------
2015-05-10 21:49:06 -0400 IM: All install checks pass
2015-05-10 21:49:18 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 21:49:18 -0400 IM: [install started]
2015-05-10 21:49:27 -0400 IM: [install completed]
2015-05-10 21:49:36 -0400
2015-05-10 21:49:36 -0400 IM: ---------- log end ----------
2015-05-10 21:49:46 -0400 IM: ---------- log start ----------
2015-05-10 21:49:46 -0400 IM: All install checks pass
2015-05-10 21:49:51 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 21:49:51 -0400 IM: [install started]
2015-05-10 21:49:52 -0400 IM: [install completed]
2015-05-10 21:49:54 -0400
2015-05-10 21:49:54 -0400 IM: ---------- log end ----------
2015-05-10 22:08:57 -0400 IM: ---------- log start ----------
2015-05-10 22:08:57 -0400 IM: All install checks pass
2015-05-10 22:09:02 -0400
2015-05-10 22:09:08 -0400 IM: [install started]
2015-05-10 22:09:16 -0400 IM: [install completed]
2015-05-10 22:09:27 -0400 IM: ---------- log end ----------
2015-05-10 22:13:01 -0400 IM: ---------- log start ----------
2015-05-10 22:13:06 -0400
2015-05-10 22:13:11 -0400 IM: Uninstall Started
2015-05-10 22:13:11 -0400 IM: [uninstall start]
2015-05-10 22:13:11 -0400 IM: user authorized
2015-05-10 22:13:11 -0400 IM: [file removal start]
2015-05-10 22:13:11 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Users/CharlesMac-Air/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2015-05-10 22:13:12 -0400 IM: Did not find bundle receipt to remove.
2015-05-10 22:13:12 -0400 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-10 22:13:12 -0400 IM: [file removal end]
2015-05-10 22:13:12 -0400 IM: [uninstall end]
2015-05-10 22:13:12 -0400 IM: Uninstall Ended
2015-05-10 22:13:13 -0400 IM: ---------- log end ----------
2015-05-10 22:13:28 -0400 IM: ---------- log start ----------
2015-05-10 22:13:28 -0400 IM: All install checks pass
2015-05-10 22:13:33 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 22:13:33 -0400 IM: [install started]
installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2015-05-10 22:13:34 -0400 IM: [install completed]
2015-05-10 22:13:36 -0400
2015-05-10 22:13:36 -0400 IM: ---------- log end ----------
2015-05-10 22:34:40 -0400 IM: ---------- log start ----------
2015-05-10 22:34:40 -0400 IM: All install checks pass
2015-05-10 22:34:52 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 22:34:52 -0400 IM: [install started]
2015-05-10 22:34:53 -0400 IM: [install completed]
2015-05-10 22:34:54 -0400
2015-05-10 22:34:54 -0400 IM: ---------- log end ----------
2015-05-10 22:36:00 -0400 IM: ---------- log start ----------
2015-05-10 22:36:00 -0400 IM: All install checks pass
2015-05-10 22:36:06 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 22:36:06 -0400 IM: [install started]
2015-05-10 22:36:12 -0400 IM: [install completed]
2015-05-10 22:36:14 -0400
2015-05-10 22:36:14 -0400 IM: ---------- log end ----------
2015-05-10 22:49:15 -0400 IM: ---------- log start ----------
2015-05-10 22:49:15 -0400 IM: All install checks pass
2015-05-10 22:49:19 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 22:49:20 -0400 IM: [install started]
2015-05-10 22:49:22 -0400 IM: [install completed]
2015-05-10 22:49:24 -0400
2015-05-10 22:49:24 -0400 IM: ---------- log end ----------
2015-05-10 22:50:53 -0400 IM: ---------- log start ----------
2015-05-10 22:50:53 -0400 IM: All install checks pass
2015-05-10 22:50:59 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-10 22:50:59 -0400 IM: [install started]
2015-05-10 22:51:06 -0400 IM: [install completed]
2015-05-11 06:05:32 -0400
2015-05-11 06:05:32 -0400 IM: ---------- log end ----------
2015-05-11 06:05:35 -0400 IM: ---------- log start ----------
2015-05-11 06:05:35 -0400 IM: All install checks pass
2015-05-11 06:05:41 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-11 06:05:41 -0400 IM: [install started]
2015-05-11 06:05:47 -0400 IM: [install completed]
2015-05-11 06:18:17 -0400 IM: ---------- log start ----------
2015-05-11 06:18:17 -0400 IM: All install checks pass
2015-05-11 06:18:17 -0400 IM: User does not have any processes that need to be closed.
2015-05-11 06:18:17 -0400 IM: [install started]
2015-05-11 06:18:19 -0400
2015-05-11 06:18:19 -0400 IM: ---------- log end ----------
2015-05-11 06:18:35 -0400
2015-05-11 06:18:35 -0400 IM: ---------- log end ----------
2015-05-11 06:19:33 -0400 IM: ---------- log start ----------
2015-05-11 06:19:33 -0400 IM: All install checks pass
2015-05-11 06:19:33 -0400 IM: ---------- log end ----------
2015-05-11 06:19:47 -0400 IM: ---------- log start ----------
2015-05-11 06:19:47 -0400 IM: All install checks pass
2015-05-11 06:19:47 -0400 IM: User does not have any processes that need to be closed.
2015-05-11 06:19:47 -0400 IM: [install started]
2015-05-11 06:19:48 -0400
2015-05-11 06:19:48 -0400 IM: ---------- log end ----------
2015-05-11 18:08:22 -0400 IM: ---------- log start ----------
2015-05-11 18:08:22 -0400 IM: All install checks pass
2015-05-11 18:08:34 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-11 18:08:34 -0400 IM: [install started]
2015-05-11 18:08:40 -0400 IM: [install completed]
2015-05-11 18:12:04 -0400 IM: ---------- log end ----------
2015-05-11 18:13:56 -0400 IM: ---------- log start ----------
2015-05-11 18:13:56 -0400 IM: All install checks pass
2015-05-11 18:14:00 -0400 IM: ---------- log end ----------
2015-05-11 18:14:01 -0400 IM: ---------- log start ----------
2015-05-11 18:14:01 -0400 IM: All install checks pass
2015-05-11 18:14:08 -0400 IM: ---------- log end ----------
2015-05-11 18:14:33 -0400 IM: ---------- log start ----------
2015-05-11 18:14:33 -0400 IM: All install checks pass
2015-05-11 18:14:39 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-11 18:14:39 -0400 IM: [install started]
2015-05-11 18:14:40 -0400 IM: [install completed]
2015-05-11 18:26:12 -0400 IM: ---------- log end ----------
2015-05-11 18:30:59 -0400 IM: ---------- log start ----------
2015-05-11 18:30:59 -0400 IM: All install checks pass
2015-05-11 18:31:04 -0400 IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2015-05-11 18:31:04 -0400 IM: [install started]
2015-05-11 18:31:05 -0400 IM: [install completed]
2015-05-11 18:31:09 -0400
2015-05-11 18:31:09 -0400 IM: ---------- log end ----------
Maria -- I had the same issue during the April update...it failed several times, but I don't remember what I did to correct the issue. You can see several attempts in April in the logs above where the install failed.
Hi char12345,
Thank you for providing the log files. I'll need a bit of time to review them and will respond tomorrow.
Maria
Ok...Maria...here is the link....I just figured out how to build it.
Hi char12345,
It appears your system is indicating that the certificate used to sign package is not trusted, however, the certificate is valid. The specific error is:
I found a thread on this forum with the same issue. Please take a look at Certificate not trusted... Flash won't install OS X 10.10?? specifically post 12 at the bottom of the thread.
Another option is a missing Apple Root Cert. Please check that the Apple Root CA is in the Keychain. If not, you can install it from here, http://www.apple.com/certificateauthority/.
Please post back here if one of these solutions there worked for you or not.
Maria
Maria,
Here are my files. I tried the solution you posted for Char12345 and my certificates were set to what they needed to be. Thanks!
