11 Replies Latest reply on Feb 19, 2007 2:35 PM by bobelmore
    transparent gif background
    noddy5000 Level 1
      hi all
      (sorry a newbie to fireworks)
      can any one help me, I have a text .gif I want to use with a transparent background so when put into web page you can see the background image of the page and not a block from the text.gif.
      problem is when I export and lay onto of background the font isn't clean, its all blocky.
      I'm not sute in fireworks the best optimization settings to use in terms of
      1. transparency: do I use index or alpha
      also:
      the type of gif, should it be web adaptive, web 256, 128
      heres my examplen to give you a better idea
      http://www.pmrltd.co.uk/text/example.html
      would some beable to advise me on the best setting for achieving the best result
      many thanks
        • 1. Re: transparent gif background
          Level 7
          Hi Noddy,
          Design on a canvas that matches the background image of your HTML page
          rather than on a transparent canvas. Export with Index transparency. I'd
          probably choose a black canvas for your project.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Re: transparent gif background
            noddy5000 Level 1
            hi there
            so do yu mean,
            1.open new documents
            2.import the background image or the section where the button is going to lay over...is this correct???
            3. select index transparency
            4.export
            will this not just export the little background that i imported???so the image will not be technically transparent??
            have I totally miss understood you??, doh!
            confuced
            • 3. Re: transparent gif background
              Level 7
              noddy man wrote:
              > hi there
              > so do yu mean,
              No. Open a new document and select a color for the canvas that matches
              or blends with the background color of the HTML page.
              • 4. Re: transparent gif background
                noddy5000 Level 1
                only problem when I do that you can see the box around it as the background is an image that is very graphic???
                any other suggwstions
                • 5. Re: transparent gif background
                  Level 7
                  There shouldn't be any box around it if you are exporting it as a
                  transparency. Is this an image you are creating in Fireworks, or one you
                  are importing from another graphics app?
                  • 6. Re: transparent gif background
                    noddy5000 Level 1
                    hey there
                    its an image I've created in fireworks...all it is a empty canvas, and I've used the text file in fireworks to create the text then rying toexport it??
                    do you have an example file I could possibly download?
                    cheers
                    • 7. Re: transparent gif background
                      Level 7
                      noddy man wrote:
                      > hey there
                      http://www.playingwithfire.com/export.png
                      Open it in Fireworks, choose Modify > Canvas > Fit Canvas, and then File
                      Export. Before exporting it, check the settings in the Optimize panel.
                      • 8. Re: transparent gif background
                        noddy5000 Level 1
                        hi there
                        yeah that works, cheers!!!! what was I doing wrong??
                        also one final question ,before I export whats the best optimisation settings to use for something like this. at present I used adaptive gif, index transparency, color 256 matte and no dither. is this ok??
                        once again thankd for you help
                        cheers
                        • 9. Re: transparent gif background
                          Level 7
                          noddy man wrote:
                          > hi there
                          You don't need to select a matte color if you are using index
                          transparency. The rest is OK.
                          • 10. Re: transparent gif background
                            noddy5000 Level 1
                            thanks for ya time and help!!!
                            received your message from projectseven.com, thank you, I didn't realise they were connected
                            kind regards
                            noddy
                            • 11. Re: transparent gif background
                              bobelmore Level 1
                              I'm not sure if my situation is the same as this or not. I want to use a transparent GIF in some elearning I am doing with Captivate 2. When I use it on a sold color background it works great. However, I also wan to display the graphic against a background of a web site, and this background has a texture. When I do this it causes dithering around the edges of the transparent GIF.
                              Can I use this background texture as the background for a transparent GIF, and if so how do I do it? In Modify>Canvas>Color I only see solid color options. Thanks.
