3 Replies Latest reply on May 12, 2015 5:11 AM by try67
    ΜΑΤΗ.ΨΕΙΛ
    klothos Level 1
      Hello
      I have Text1=44.09
      Textfield1=Text1+10=54.09=55 math.ceil
      i want
      Textfield2=Text1+54.09=98.18=99 math.ceil
      Textfield3=Text1+98.18=142.27=143 math.ceil
      Textfield4=Text1+142.27=186.36=187 math.ceil
      Textfield5=Text1+186.36=230.45=231 math.ceil
      till Textfield250
        • 1. Re: ΜΑΤΗ.ΨΕΙΛ
          You already posted this question. And it's not clear at all what you're asking... Try to explain it a bit more clearly, please.
          • 2. Re: ΜΑΤΗ.ΨΕΙΛ
            klothos Level 1
            For example i want every time to add the value with two decimals from the previus Textfield and then i will use the math.ceil for the result
            • 3. Re: ΜΑΤΗ.ΨΕΙΛ
              You can create a doc-level function that takes two values, adds them, rounds up the result and then return it, and use that method in all of your fields.
              It can look something like this:
              function myRoundUp(a,b) {
                   return Math.ceil(a+b);
              You then call it like this, for example:
              event.value = myRoundUp(+this.getField("Text1").value, 54.09);
