1 Reply Latest reply on May 16, 2015 3:54 AM by Phildsb
    Sound won't play when exported using Phonegap
    elainesoares21@icloud.com
      HEllo, I have created an animation on Edge Animate which contains sound. when I test the project on my browsers (chrime, safari, etc), it works just fine. However, once I export it to the ipad using Phonegap, the animation will not have sound. The other elements work fine, except that the sound won't play.
      Am I missing some step or code line or plugin ?
      ALso, I am using the cloud version of Phonegap (Phonegap Build).
      IT is an app with a read along children's story for iOs to be played on ipads.
      i Am quite desperate at this point, i have had to switch from DPS to Phonegap in the middle of a project.
      ANy help is appreciated,
      thanks
        • 1. Re: Sound won't play when exported using Phonegap
          Phildsb Level 1
          Hi, is the audio set to autoplay, or is it initiated by some user event? I haven't used Phonegap, so I'm not sure what it does to your existing js but iOS won't allow autoplay of audio/video in mobile Safari so that could be the limitation you're coming across, e.g.
          sym.$("button").on('click',function(){sym.$("sound")[0].play()}));
          might work, although it might need to be sym.$("sound").play(0).
