6 Replies Latest reply on May 14, 2015 12:08 AM by oleh.melnyk
    Placing an image on my page using a URL
    Roy Marshall Level 1
      Hi.
      I have no idea if this is possible, but would love to hear if anyone can point me in the right direction.
      Using an InDesign Javascript I can piece together a URL, that when pasted directly into a browser displays an image that I need to place into InDesign.
      Here is the URL
      http://XXXXXXXXXXX.co.nz/login/SearchService?SERVICE_REQUEST_TYPE=4&SERVICE_REQUEST_USERID =1650&SERVICE_REQUEST_ASSETID=84035&SERVICE_REQUEST_PASSKEY=xxxxxxxx
      You will have to believe me that putting in the proper data instead of the xxxx does show an image in my browser
      Is there a way I can grab the image, and place into InDesign using Javascript?
      I know I may have to download to a temporary location first which is fine.
      Maybe some way to encode to base64....
      I would like to keep this platform independent, but if I need to resort to injecting a bit of applescript, I can live with it.
      Hopefully this is enough for now to get some suggestions!
      Thanks in advance,
      Roy
        • 1. Re: Placing an image on my page using a URL
          Vamitul Level 4
          you can get the image using the Socket object. In the Javascript Tools Guide Pdf, ~page 190 you will find a working example that gets a html file, but it can easily be adapted to get a image.
          then here is also Rorohiko: July 2008
          • 2. Re: Placing an image on my page using a URL
            Hi
            Thanks for the reply.
            I do use sockets for other web page content that I need to access, but thats only to access text/data in the reply back from the connection read.
            What I am trying to do here is return back an image from this page (that is all the physical page contains) and use it in InDesign.
            I have tried different variations of the call, but the reply is always nothing. Even if it was to return something, all it would be would be a link to the image online wouldn't it? How would I use that?
            Anyway, here is the line of code I am using in full so you can see what I mean.
            http://redworksnz.co.nz/login/SearchService?SERVICE_REQUEST_TYPE=4&SERVICE_REQUEST_USERID= 1650&SERVICE_REQUEST_ASSETID=84035&SERVICE_REQUEST_PASSKEY=password
            There is nothing here that is really sensitive.
            I would appreciate any further comments.
            Thanks again
            Roy
            • 3. Re: Placing an image on my page using a URL
              Vamitul Level 4
              var s=new Socket();
              s.open('redworksnz.co.nz:80');
              s.write ('GET login/SearchService?SERVICE_REQUEST_TYPE=4&SERVICE_REQUEST_USERID=1650&SERVICE_REQUEST_ASSETID=84035&SERVICE_REQUEST_PASSKEY=password');
              var r= s.read();
              $.write(r);
              You get a CDATA block as a reply that should contain the image.
              • 4. Re: Placing an image on my page using a URL
                Hey.
                Thanks for that.
                After a quick test, I get
                <![CDATA[]]>Result: undefined
                doesnt look right...
                I did get Chris (Rorohiko) script to work, but just need analyse further.
                • 5. Re: Placing an image on my page using a URL
                  oleh.melnyk Level 3
                  Hi Roy,
                  I'm also interested how to download / upload files using ExtendScript.
                  I tried to make script, while it's not able get successfully download image, it do something close: read response from server and write png file to desktop - the problem is that "saved" file is too small, I haven't yet figured out why, but maybe you will be more successful with that. Will keep working on that later today. And if you find solution - let me know
                  var reply = "";
                  var conn = new Socket();
                  var site = "redworksnz.co.nz:80";
                  var path = "/login/SearchService?SERVICE_REQUEST_TYPE=4&SERVICE_REQUEST_USERID=1650&SERVICE_REQUEST_ASSETID=84035&SERVICE_REQUEST_PASSKEY=password";
                  if (conn.open(site))
                      // send a HTTP GET request
                      conn.write ("GET "+path+" HTTP/1.0\n\n");
                      // and read the server’s reply
                      reply = conn.read(999999999); //
                      conn.close();
                      alert(reply.toString(), "Response from server");
                  else
                      alert(conn.error);
                  if(reply){
                      ext = reply.split("\n\n")[0].match(/^Content-Type:\s\w+\/(\w+)/im)[1]; // extension: png
                      body = reply.split("\n\n")[1];
                      alert(body.length, "Response body length");
                      var f = File(Folder.desktop.fsName+"/SearchService."+ext);
                      if ( f.open('wb') )
                          f.write(body);
                          f.close();
                  • 6. Re: Placing an image on my page using a URL
                    oleh.melnyk Level 3
                    This version seems to download and write everything from server to file, but png file still corrupted - probably because I dont know how to write binary files properly
                    // something useful here http://www.ps-scripts.com/bb/viewtopic.php?t=2665
                    //conn.encoding = "UTF-8"; // encoding: "ASCII", "binary", or "UTF-8"
                    if (conn.open (site)) //, "BINARY"
                        $.writeln("Connected, wait!");
                        conn.timeout=6000;
                        conn.write("GET "+path+" HTTP/1.0\n\n");
                        reply = conn.read(399999999999);
                        conn.close();
                        $.writeln("Response length: " + reply.length);
                    else
                        $.writeln("Error: " + conn.error);
                    if(reply){
                        tmp = reply.split("\n\n");
                        tmp.shift();
                        body = tmp.join("\n\n");
                        var f = File(Folder.desktop.fsName+"/SearchService."+ext); //.txt
                        if ( f.open('w') )
                            //f.encoding = "binary";
                            f.write(body);
                            //f.rename(fileName);
                            f.close();
                        $.writeln("Done!");
