7 Replies Latest reply on Jun 15, 2018 11:10 AM by marquiser83562770
    PE12 and CS6 Crash/Hang on Startup
    CarlosDanger
      A couple of months ago I started having problems with all of my Adobe programs, including Premiere Elements 12 and Photoshop, Illustrator, etc.  While they used to open up extremely quickly from my solid state drive, now they all will take forever to open or will usually just crash and not open at all.  I have not made any hardware or software changes that I am aware of; one day they all just decided not to work.  I have tried uninstalling and reinstalling all of them as well.  Below is a sample message I get when Elements crashes:
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: Adobe Premiere Elements.exe
        Application Version: 12.0.0.0
        Application Timestamp: 530bd24a
        Fault Module Name: dvamarshal.dll
        Fault Module Version: 11.0.0.0
        Fault Module Timestamp: 523cc62d
        Exception Code: c0000005
        Exception Offset: 0000000000034961
        OS Version: 6.1.7601.2.1.0.256.4
        Locale ID: 1033
        Additional Information 1: 5a5c
        Additional Information 2: 5a5c7f2099c49d46ef167594373b054c
        Additional Information 3: e2a1
        Additional Information 4: e2a18ccc946fae77ae70bd7ffb1dd642
      About my system:
      Intel Core i5-4430 3gHz
      Win7 Enterprise 64bit
      8GB RAM
      System Disk:  120GB Samsung EVO SSD
      Six other hard drives of varying sizes for storage
        • 1. Re: PE12 and CS6 Crash/Hang on Startup
          A.T. Romano Level 7
          CarlosDanger
          Have you posted your Premiere Elements CS6 issue in the Premiere Pro Forum and gotten any input there to resolve matters from the Premiere CS6 side?
          With regard to Premiere CS6, do you get the same "Faulty Module Name: dvamarshal.dll"?
          Premiere Elements 12 on Windows 7 64 bit
          a. Have you determined that the problem exists with and without the antivirus and firewall(s) disabled?
          b. Have you ever updated 12 to 12.1 using an opened project's Help Menu/Updates. If not, please do so.
          c. For the time being I am going to assume that the video card/graphic card has nothing to do with dvamarshal.dll...in the past that has not proven the answer..but we may go back to that.
          d. Is the SSD designated Local Disk C and did you install Premiere Elements 12 to the default location there?
          If you have not tried the following...please run through
          Local Disk C
          Users
          Owner
          AppData
          Roaming
          Adobe
          Premiere Elements
          13.0
          and in the 13.0 Folder is the Adobe Premiere Elements Prefs file. In this case, let us delete the whole 13.0 Folder in which the Adobe Premiere Elements Prefs file exists. Be sure to be working with Folder Option Show Hidden Files, Folders, and Drives enabled so that you can see the complete path given.
          Please review and consider and then we can decide what next.
          Thank you.
          ATR
          • 2. Re: PE12 and CS6 Crash/Hang on Startup
            CarlosDanger Level 1
            Thanks for your help!
            I haven't posted in the CS6 forums yet, but this is the readout when Premiere Pro CS6 crashes, so maybe there is a connection:
            Problem signature:
              Application Name: Adobe Premiere Pro.exe
              Application Version: 6.0.5.0
              Application Timestamp: 5211d7f5
              Fault Module Version: 6.0.5.1
              Fault Module Timestamp: 5211c4a9
              Exception Offset: 0000000000030ff1
              Locale ID: 1033
              Additional Information 1: bc8d
              Additional Information 2: bc8dea4e9dd9b75bfdb3ece306df51b9
              Additional Information 3: 30fb
              Additional Information 4: 30fb351fbc7092e1d1ef8fb3ee1199bc
            As to the other questions:
            a.  Yes, I have disabled firewall and antivirus, no difference.  I also tried booting in Safe Mode.
            b.  I can't get the program to open any further than the splash screen, but that screen does identify PE as version 12.1.
            c.  I don't suspect the graphics card either, since as far as I know no updates were made to its drivers/software.  I'm just using the onboard graphics on the i5 chip.
            d.  Yes and yes
            I tried deleting the prefs folder, but it still doesn't work.
            Again, thanks for your assistance!
            • 3. Re: PE12 and CS6 Crash/Hang on Startup
              A.T. Romano Level 7
              CarlosDanger
              Thanks for the reply.
              Since you have several Adobe products installed on the same computer and you have already explored a lot of variables, I am going to ask you to try the following
              Please do a free ccleaner run through (both regular cleaner and registry cleaner parts) - just use the free download
              CCleaner - PC Optimization and Cleaning - Free Download
              Restart the computer and determine if that computer optimization had any impact on the issue.
              There is an "Adobe CCleaner" (CC as in Creative Cloud is my understanding). It is not the same as the free ccleaner to which I am pointing you. It is my understanding that the Adobe CCleaner does not have the registry cleaning opportunity that the ccleaner has.
              In this approach, we are looking to clear leftover from incomplete uninstalls and reinstalls for Adobe as well as non Adobe products.
              Based on the results, we will think about this some more.
              Thank you.
              ATR
              • 4. Re: PE12 and CS6 Crash/Hang on Startup
                Just wanted to let you know that CCleaner seemed to do the trick!  Everything's loading now, and just as fast as it used to.  Thanks!
                • 5. Re: PE12 and CS6 Crash/Hang on Startup
                  A.T. Romano Level 7
                  CarlosDanger
                  Wonderful news of your progress and good program loading. Great job in sorting through the troubleshooting to gain your success.
                  Please never hesitate to ask if you have questions or need clarification on your Premiere Elements workflows.
                  Thanks for the follow up. Appreciated.
                  Best wishes
                  ATR
                  • 6. Re: PE12 and CS6 Crash/Hang on Startup
                    jorgusan
                    Hi:
                    I have a Windows 10 Surface Pro 4 16GB Ram and 256GB SSD. The graphic Card is Intel Iris 540.
                    Bought the combo como Adobe Elements 15, Premiere & Photoshop and Premiere will not start.  Will not even create a event viewer entry for me to analyze. Photoshop works great.
                    I have already uninstalled both and rebooted on each.  Uninstalled all Adobe products. Ran CC Cleaner and looked for conflicting apps.  Even turned off my Antivirus.
                    Any help would be great.  I bought them last week and need to edit some videos for an activity at the end of this week.
                    Best Regards,
                    Jorge
                    • 7. Re: PE12 and CS6 Crash/Hang on Startup
                      marquiser83562770
                      I have been using premiere elements 12 for quite some time now and I was editing a new video and to my suprose my computer froze. I restarted the computer and now I can't get the program to open at all? I double click the program to open and all it does is spin or load it never fully opens. Before it kept giving me a failed to perform the database operation as the organizer is busy. Please try again later and now it doesn't do anything? I have an HP laptop 6ram 500gb
