This content has been marked as final.
Show 4 replies
1. Re: I'm trying to remove paragraph rules from paragraphs in an InDesign document, but cannot because it (incorrectly) says they're already turned off
BobLevine May 13, 2015 2:27 PM (in response to BrokenEye3)You’re looking at rule above. There’s a dropdown there for rule below.
2. Re: I'm trying to remove paragraph rules from paragraphs in an InDesign document, but cannot because it (incorrectly) says they're already turned off
smoothsea May 13, 2015 2:28 PM (in response to BrokenEye3)Hi,
Have you checked that the paragraph rule is not "Rule Below"? Rule above is switched off, but Rule below may well be on. Select it in the popup shown in your screenshot.
Regards,
Malcolm
3. Re: I'm trying to remove paragraph rules from paragraphs in an InDesign document, but cannot because it (incorrectly) says they're already turned off
Peter Spier May 13, 2015 2:31 PM (in response to smoothsea)And the best place to do this is in the Paragraph Style definition dialog so you don't have to keep overriding the rule to turn it off...
4. Re: I'm trying to remove paragraph rules from paragraphs in an InDesign document, but cannot because it (incorrectly) says they're already turned off
BrokenEye3 May 13, 2015 2:38 PM (in response to BobLevine)Ah, perfect. Thank you for that.
