1 Reply Latest reply on May 14, 2015 7:00 AM by Rick Gerard
    is there a way to copy certain bezier points from a keyframe, and past onto another keyframe but not all of the points, just some
    djmattyz Level 1
      sometimes when im animating a mask,  i realise that part of the mask needs to be in a different place, but if i do not realise this from the very beginning, then i find myself having to go over the animation frame by frame and correct it, the problem is ill correct it slightly differently in each frame,  then when i play back you can see movement there,  and the mask is thus destroyed, and i need to start again.
      is there a way to take,  say,   2 of the bezier points in a mask, and copy them across every frame in the animation so that they stay in a fixed position  ?
