0 Replies Latest reply on May 14, 2015 5:59 AM by N4nd0
    Error drag and drop
    N4nd0
      Good morning, I'm trying to make drag and drop in eclipse to connect to the bank by blazeds an image inside a canvas that would be a board and is presenting the following error:
      RangeError:Error#2006:The supplied index is out of bounds.
      at flash.display:DisplayObjectContainer/addChildAt()
      at mx.core:Container/addChildAt()[E:\dev\3.0x\frameworks\projects\framework\src\mx\core\Cont ainer.as:2206]
      at mx.core:Container/addChild()[E:\dev\3.0x\frameworks\projects\framework\src\mx\core\Contai ner.as:2140]
      at tabuleiro/handleDragDrop()[D:\Programação\Eclipse\workspace\tabuleiro\flex_src\scripts\dr agDrop.as:156]
      at tabuleiro/__tabuleiro_DragDrop()[D:\Programação\Eclipse\workspace\tabuleiro\flex_src\tabu leiro.mxml:6]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.cre::UiComponent/dispatchEvent()[E:\dev\3.0x\frameworks\projects\framework\src\mx\core \UIComponent.as:9051]
      at mx.managers.dragClasses::DragProxy/mouseUpHandler()[E:\dev\3.0x\frameworks\projects\frame work\src\mx\managers\dragClasses\DragProxy.as:500]
      Note: in FlexBuilder 3 works perfectly.
      My calls in mxml file:
      [code]
      <mx:Canvas id="canvasTabuleiro" width="628" height="702" backgroundColor="#FFFFFF" borderStyle="solid"
      borderColor="#000000" dragDrop="{handleDragDrop(event)}" dragEnter="{handleDragEnter(event)}">
      <mx:Image id="tabuleiro"
        source="@Embed(source='assets/tabuleiro.jpg')" width="626" height="391"/>
      <mx:Image id="imagem1" x="10" y="399" source="@Embed(source='assets/peca.jpg')" mouseDown="handleMouseDown(event)"/>
      [/code]
      My dragDrop.as file:
      [code]
      import flash.events.MouseEvent;
      import mx.controls.Image;
      import mx.core.DragSource;
      import mx.core.IUIComponent;
      import mx.core.UIComponent;
      import mx.events.DragEvent;
      import mx.managers.DragManager;
              private function handleMouseDown( event:MouseEvent ):void
                  if ( event.currentTarget is IUIComponent )
                      var dragChild:UIComponent = UIComponent( event.currentTarget );
                      var dragSource:DragSource = new DragSource();
                      dragSource.addData( dragChild.parent, 'dragParent' );
                      dragSource.addData( dragChild, 'dragChild' );
                      var proxy:UIComponent = UIComponent( event.currentTarget );
                      var bitmapData:BitmapData = new BitmapData( proxy.width, proxy.height );
                      bitmapData.draw( proxy );
                      var bitmap:Bitmap = new Bitmap( bitmapData );
                      var image:Image = new Image();
                      image.source = bitmap;
                      DragManager.doDrag( dragChild, dragSource, event, image );
              private function handleDragEnter( event:DragEvent ):void
                  if ( event.dragSource.hasFormat('dragChild') && event.dragSource.hasFormat('dragParent') )
                      if ( event.currentTarget is UIComponent )
                          var dropTarget:UIComponent = UIComponent( event.currentTarget );
                          var dragSource:UIComponent = event.dragSource.dataForFormat( 'dragParent' ) as UIComponent;
                              DragManager.acceptDragDrop( dropTarget );
                              DragManager.showFeedback( DragManager.COPY );
              private function handleDragDrop( event:DragEvent ):void
                          var child:UIComponent = event.dragSource.dataForFormat( 'dragChild' ) as UIComponent;
                          Image(event.dragInitiator).x = Canvas(event.currentTarget).mouseX;
                          Image(event.dragInitiator).y = Canvas(event.currentTarget).mouseY;
                          //dragSource.removeChild( child );
                          dropTarget.addChild( child );
      [/code]
      Well, as it worked in FlexBuilder not imagine what to do to correct the Eclipse. Thanks in advance.
