2 Replies Latest reply on May 14, 2015 8:45 AM by smenegassi
    plane trajectoires files into After Effects
    smenegassi Level 1
      Hello,
      I have these airplane trajectoires (real ones) files I want to load into After and animate them.
      The files I have are mkz files. But they have no Collada files inside. Only a doc.kml
      I can transform them into pdf files. That is ok, but then I ll have to fake altitude and place them exactly on top of the real map so it fits OK.
      It is a manual work.
      I do have a GeoJSON file. There is my question. Can I import these GeoJSOn files into After and see them as paths ?
      thanks all
      s.
        • 1. Re: plane trajectoires files into After Effects
          You can write all sorts of parsing code with scripts or even expressions. would require some examples to advise specifically.
          Mylenium
          • 2. Re: plane trajectoires files into After Effects
            smenegassi Level 1
            OK. thanks.
            I have these file : FP-@TAY128M.json I obtained from a kmz file I transcoded using mygeodata
            "type": "FeatureCollection",
            "crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84" } },
            "features": [
            { "type": "Feature", "properties": { "Name": "FlightPath-@TAY128M", "description": null, "timestamp": null, "begin": null, "end": null, "altitudeMode": "absolute", "tessellate": 1, "extrude": 1, "visibility": -1, "drawOrder": null, "icon": null }, "geometry": { "type": "LineString", "coordinates": [ [ 2.726833, 49.030772, 1417.0 ], [ 2.734384, 49.031377, 1471.0 ], [ 2.741906, 49.031462, 1524.0 ], [ 2.749048, 49.031816, 1577.0 ], [ 2.75698, 49.03215, 1725.0 ], [ 2.764532, 49.032753, 1808.0 ], [ 2.773254, 49.033068, 1869.0 ], [ 2.780001, 49.033429, 1915.0 ], [ 2.787539, 49.033771, 1984.0 ], [ 2.795471, 49.034103, 2037.0 ], [ 2.802642, 49.034973, 2128.0 ], [ 2.81018, 49.035313, 2167.0 ], [ 2.818128, 49.035903, 2227.0 ], [ 2.826061, 49.036233, 2281.0 ], [ 2.833628, 49.037092, 2365.0 ], [ 2.841576, 49.03768, 2418.0 ], [ 2.849524, 49.038268, 2456.0 ], [ 2.857472, 49.038856, 2502.0 ], [ 2.865831, 49.039693, 2586.0 ], [ 2.874175, 49.04027, 2639.0 ], [ 2.881728, 49.040866, 2677.0 ], [ 2.889677, 49.041451, 2730.0 ], [ 2.898022, 49.042026, 2799.0 ], [ 2.906366, 49.042601, 2883.0 ], [ 2.914316, 49.043184, 2936.0 ], [ 2.922646, 49.043498, 2997.0 ], [ 2.930976, 49.043811, 3058.0 ], [ 2.940492, 49.044093, 3111.0 ], [ 2.947911, 49.042346, 3165.0 ], [ 2.95571, 49.040329, 3218.0 ], [ 2.963508, 49.038311, 3264.0 ], [ 2.97129, 49.036033, 3302.0 ], [ 2.978646, 49.033245, 3332.0 ], [ 2.985956, 49.029676, 3355.0 ], [ 2.992017, 49.025099, 3401.0 ], [ 2.997683, 49.020531, 3439.0 ], [ 3.002527, 49.015463, 3470.0 ], [ 3.006549, 49.009896, 3530.0 ], [ 3.010494, 49.003029, 3569.0 ], [ 3.012919, 48.997242, 3622.0 ], [ 3.014509, 48.990696, 3698.0 ], [ 3.014534, 48.98445, 3751.0 ], [ 3.013754, 48.977965, 3812.0 ], [ 3.012201, 48.971759, 3858.0 ], [ 3.009449, 48.965325, 3957.0 ], [ 3.006743, 48.959669, 4011.0 ], [ 3.001656, 48.953814, 4049.0 ], [ 2.99701, 48.948729, 4117.0 ], [ 2.992017, 48.944432, 4163.0 ], [ 2.98581, 48.939646, 4247.0 ], [ 2.980333, 48.9338, 4292.0 ], [ 2.974508, 48.928744, 4369.0 ], [ 2.968321, 48.924217, 4445.0 ], [ 2.962483, 48.9189, 4498.0 ], [ 2.956268, 48.913852, 4590.0 ], [ 2.950053, 48.908804, 4643.0 ], [ 2.944204, 48.903226, 4681.0 ], [ 2.938781, 48.898158, 4757.0 ], [ 2.933328, 48.892569, 4826.0 ], [ 2.927847, 48.886461, 4864.0 ], [ 2.922398, 48.880872, 4894.0 ], [ 2.916964, 48.875542, 4910.0 ], [ 2.911093, 48.869443, 4933.0 ], [ 2.906011, 48.863324, 4963.0 ], [ 2.900142, 48.857224, 5001.0 ], [ 2.894669, 48.851113, 5032.0 ], [ 2.888804, 48.845013, 5077.0 ], [ 2.883318, 48.838642, 5146.0 ], [ 2.877441, 48.832281, 5184.0 ], [ 2.87276, 48.82615, 5245.0 ], [ 2.866886, 48.819789, 5291.0 ], [ 2.861435, 48.813937, 5344.0 ], [ 2.855913, 48.806785, 5420.0 ], [ 2.850072, 48.800942, 5474.0 ], [ 2.84499, 48.79456, 5519.0 ], [ 2.839501, 48.787927, 5550.0 ], [ 2.834407, 48.781284, 5634.0 ], [ 2.828543, 48.774921, 5687.0 ], [ 2.823073, 48.768547, 5725.0 ], [ 2.817968, 48.761643, 5794.0 ], [ 2.812923, 48.755779, 5832.0 ], [ 2.807836, 48.749136, 5885.0 ], [ 2.801978, 48.74277, 5969.0 ], [ 2.796486, 48.735875, 5992.0 ], [ 2.791011, 48.72924, 6053.0 ], [ 2.785536, 48.722604, 6083.0 ], [ 2.780063, 48.715968, 6137.0 ], [ 2.774591, 48.709332, 6213.0 ] ] } }
            I read the tutorial from Lloyd Alvarez. I use as he suggested the json2.js file to parse my json file and I obtain what I called a trajectoire.jsx file.
            But I don’t really what to do next. When I run the script in After Effects nothing happens. I don’t know if what I am doing makes any sense.
            So it is possible to obtain a path like file to use as a trajectory in After Effects ?
