3 Replies Latest reply on May 15, 2015 12:57 AM by haxtbh
    cfprocparam is throwing  ILLEGAL SYMBOL =;
    jpmyob
      Upgraded from CF10 to CF11 update 5 ( with hotfix hf1100-3971083.jar )
      DB (DB2 v10.2)
      getting an error on code that calls a stored proc.
      Error Executing Database Query.
      [Macromedia][DB2 JDBC Driver][DB2]ILLEGAL SYMBOL =;
      The error occurred in ...: line 238
      236 :  <cfstoredproc datasource="#application.dsn#" procedure="LIVE.SP" >
      237 :     <cfprocparam type="In" cfsqltype="CF_SQL_BIGINT" dbvarname="STOPID" null="yes" />
      238 :     <cfprocparam type="In" cfsqltype="CF_SQL_INTEGER" dbvarname="POID" null="no" value="#val( qry.id )#" />
      239 :  </cfstoredproc>
      The actual code looks like this - and works fine in CF10....
      "qry" IS returning a value for "id"
      <cfloop query="qry" >
          </cfstoredproc>
      </cfloop>
      This happens IF or NOT the 'debugging' is turned on (per hotfix hf1100-3971083.jar)
      It seems there are others claiming cfprocparam issues - but the solutions to those issues are not fixing THIS issue.
      Any Ideas?
