4 Replies Latest reply on May 15, 2015 7:53 AM by gkaiseril
    xfa.host.importData loop JavaScript
    hy9fesh
      Using JavaScript in Adobe Acrobat, I want to be able to import XML files from a specific folder into a form. I hope to achieve this by opening the PDF form and have the script loop through all the XML files in a folder, importing each file into the PDF file, and saving as a unique name based off the form field. For example, if I had 5 XML files in the folder, 5 PDF files will be created.
      Does the code below look like it's on the right track, or am I overlooking something?
      //Opens PDF file
      app.openDoc("[PDF file location]");
      // Selects Folder
      var processFolder = Folder('[folder]');
      // Get XML files
      var fileList = processFolder.getFiles(/\.(xml)$/i);
      // Loop through files
      for (var i = 0; i < fileList.length; i++) {
      // Process files
           if (fileList[i] instanceof File) {
          xfa.host.importData(fileList[i]);
      //Save PDF
          xfa.resolveNode("[node]");
          myTrustedSpecialTaskFunc(this, "[output folder location]" + [node].rawValue + ".pdf");
