1. Re: Vertical Swipe - Wishlist Item
seano2o7 May 15, 2015 5:50 AM (in response to PEPPERFACE)You can add the functions to the Stages compositionReady. Read this
How to get swipe up and swipe down event in jQuery Mobile? - Stack Overflow
You can use a function like this to do it.
var supportTouch = $.support.touch,
scrollEvent = "touchmove scroll",
touchStartEvent = supportTouch ? "touchstart" : "mousedown",
touchStopEvent = supportTouch ? "touchend" : "mouseup",
touchMoveEvent = supportTouch ? "touchmove" : "mousemove";
$.event.special.swipeupdown = {
setup: function() {
var thisObject = this;
var $this = $(thisObject);
$this.bind(touchStartEvent, function(event) {
var data = event.originalEvent.touches ?
event.originalEvent.touches[ 0 ] :
event,
start = {
time: (new Date).getTime(),
coords: [ data.pageX, data.pageY ],
origin: $(event.target)
stop;
function moveHandler(event) {
if (!start) {
return;
event;
stop = {
// prevent scrolling
if (Math.abs(start.coords[1] - stop.coords[1]) > 10) {
event.preventDefault();
$this
.bind(touchMoveEvent, moveHandler)
.one(touchStopEvent, function(event) {
$this.unbind(touchMoveEvent, moveHandler);
if (start && stop) {
if (stop.time - start.time < 1000 &&
Math.abs(start.coords[1] - stop.coords[1]) > 30 &&
Math.abs(start.coords[0] - stop.coords[0]) < 75) {
start.origin
.trigger("swipeupdown")
.trigger(start.coords[1] > stop.coords[1] ? "swipeup" : "swipedown");
start = stop = undefined;
$.each({
swipedown: "swipeupdown",
swipeup: "swipeupdown"
}, function(event, sourceEvent){
$.event.special[event] = {
setup: function(){
$(this).bind(sourceEvent, $.noop);
sym.$('element').on('swipedown',function(){alert("swipedown..");} );
sym.$('element').on('swipeup',function(){alert("swipeup..");} );
So when you swipe up on a rectangle or whatever you have on the stage called "element" it will alert "swipeup" and same with swipe down.
I've tested it and it works for me.
I hope this helps.
2. Re: Vertical Swipe - Wishlist Item
PEPPERFACE May 15, 2015 9:07 AM (in response to seano2o7)Thank you so much for the response sean0207, it really is greatly appreciated but unfortunately I can't get it to work at this end.
Nothing happens. Which obviously means I've set something up incorrectly, but that was kind of why I posted in the first place. What I'm hoping for from the good folk at Adobe is swipeup (which can be employed to make the timeline play) and swipedown (which can be employed to make the timeline playReverse) provided as a built-in facility; so that folk like me can easily utilise it
Many thanks again, though, for your time.
3. Re: Vertical Swipe - Wishlist Item
mlprouty Aug 25, 2015 8:12 AM (in response to PEPPERFACE)this works!! Don't give up.
Instructions:
1) Add the latest jquery.js to your Sctipts https://jquery.com/download/
2) Create an element on the stage such as a large rectangle. Name it "element"
3) Copy and paste the code in seano2o7's post above to Stages - compositionReady
Honest it works!! thanks seano2o7, I've been looking all over for this!!
Mark
4. Re: Vertical Swipe - Wishlist Item
PEPPERFACE Aug 26, 2015 4:34 AM (in response to mlprouty)Mark, you STAR!!! It DOES work! A million thanks for pointing me in the right direction... and seano2o7 for the original code. I'm eternally grateful to you both
If anyone else is hunting for this solution I've created a very simple working example based on the above but with the result being that a timeline plays, as opposed to a 'swipe up/swipe down alert' being displayed.
You can grab the zipped Edge Animate file from here.
Cheeeeeeeers!
