2 Replies Latest reply on May 18, 2015 12:57 AM by koenraad.bats@ds-n.com
    Find/Change by List script in character style subfolders, InDesign CC
    koenraad.bats@ds-n.com Level 1
      I'm trying to replace a text from one Character Style into another Character Style (both in subfolders), using the Find/ChangebyList script in InDesign CC (9.3), but I can't make it work.
      After reading related discussions and after many trial+errors, I ended up with this :
      grep{findWhat:"(MRP-Rs.\\s*\\d+\\-)"}{appliedCharacterStyle:app.activeDocument.characterStyleGroups.item("Niet aankomen").characterStyles.item("IndiaDetails")}{changeTo:"$1"}{appliedCharacterStyle:app.activeDocument.characterStyleGroups.item("Extra").characterStyl es.item("MRP")}{includeLockedStoriesForFind:false, includeLockedLayersForFind:false, includeHiddenLayers:false, includeMasterPages:false, includeFootnotes:true, kanaSensitive:true, widthSensitive:true}//MRP bold 16pt
      But still, nothing happens. So now I got stuck.
      My GREP statement looks ok but I can't get the JavaScript to find Character Style "IndiaDetails" and replace it by "MRP".
      I'm new to JavaScript, can anyone help me with this?
        • 1. Re: Find/Change by List script in character style subfolders, InDesign CC
          S Hopkins Adobe Community Professional
          I can see that you are having difficulty. Let me steer you away from using the Find/Change by List script. This script is intended for instances where you have a number of find/changes to perform. Find/Change by List just makes the process more confusing if you only need a simple find/change. For your purpose you only need one find/change. So to simplify the process, script the find/change directly as shown below. Notice in the sample code following how the character styles are referenced as parts of the character style group. (If not part of a character style group, just remove the style group "dot" portion of the reference.) Notice that I named my styles a little different than yours simply because I never use spaces--it's just a personal preference. Hope this helps.
          //Find/Change Character Styles
          main();
          function main(){
          var myDocument = app.activeDocument;
          //Define the character styles
          var findCharacterStyle = myDocument.characterStyleGroups.item("Niet").characterStyles.item("IndiaDetails");
          var changeCharacterStyle = myDocument.characterStyleGroups.item("Niet").characterStyles.item("MRPBold_16pt");
          /*define text object that will be target of find/change; expects text selection*/
          var textRef = app.selection[0].texts.item(0);
          //define find change options
          var findChangeOptProps = {caseSensitive:false, wholeWord:false, includeFootnotes:true, includeHiddenLayers:false,
          includeLockedLayersForFind:false,includeLockedStoriesForFind:false, includeMasterPages:false};
          //define the attribute(s) that need to be found/changed
          var findAttrib = {appliedCharacterStyle:findCharacterStyle};
          var changeAttrib = {appliedCharacterStyle:changeCharacterStyle};
          //call the findChange_Attribute function
          var foundSet = findChange_Attribute (textRef,  findAttrib, changeAttrib, findChangeOptProps);
          alert ("" + foundSet.length  + " instances changed");
          function findChange_Attribute (textRef,  findAttrib, changeAttrib, findChangeOptProps){
            //initialize text preferences to nothing
              initPrefs();
              //set properties for find text preference
            app.findTextPreferences.properties = findAttrib;
            //set properties for change text preference
              app.changeTextPreferences.properties = changeAttrib;
              //set properties for find/change text options
            app.findChangeTextOptions.properties = findChangeOptProps;
              //perform the change
            var foundSet = textRef.changeText();
            initPrefs();
            return foundSet;
            function initPrefs () {
            app.findTextPreferences = NothingEnum.NOTHING;
            app.changeTextPreferences = NothingEnum.NOTHING;
          • 2. Re: Find/Change by List script in character style subfolders, InDesign CC
            Hi S Hopkins, many thanks for the effort!
            But I can't make it work :-(
            InDesign gives me following error :
            Off course, I changed the names of the desired Character Styles en Style groups on line 11 and 13.
            What did I do wrong?
            Actually, I do have a number of find/change instances; I just didn't add them because I expected to be able to fix them as well when this problem would be solved.
            Also, implementing all these instances in a JS would be great. But, as you might have noticed, my knowledge of JS is poor.
            About the use of spaces in styles : I'll change that, I think you're right about it.
            Further on, I am wondering if this JS will change only the desired part of the text (MRP-Rs.\s*\d+\-)?
