3 Replies Latest reply on May 15, 2015 4:11 PM by Daniel Sterchi
    Scripts for clearing style overrides
    mikej3204
      I want to create a script in InDesign that clears my overrides on one specific paragraph style. Any ideas?
        • 1. Re: Scripts for clearing style overrides
          Daniel Sterchi Level 3
          Hi mikej3204
          I've put together a few lines.
          Try them and see if they work for you.
          kind regards
          Daniel (from Switzerland)
          main();
          exit();
          // needs some refinement to fit your needs
          function main() {
          //    try it with both functions
          //    doitWithSelection();
              doitWithAllParagraphs();
              alert("Information\nI've done my job, what about yours");
          // 1. Select a paragraph (click 4 times into text)
          // .2 start the program
          function doitWithSelection() {
              if (myDoc != null) {
                  var myParaSel = myDoc.selection[0];
                  if (myParaSel.constructor.name == "Paragraph") {
                      // you have to change the "Test" with your paragraphstyle where you want to clear all overrides
                      if (myParaSel.appliedParagraphStyle == myDoc.paragraphStyles.item("Test") ) {
                          myParaSel.clearOverrides();
                  else {
                      alert("Information\nNo paragraph selected");
          function doitWithAllParagraphs() {
                  var paras = myDoc.stories.everyItem().paragraphs.everyItem().getElements();
                  for (var i = 0; i < paras.length; i++) {
                      myParaSel = paras[i];
                  }   // for the for loop
          • 2. Re: Scripts for clearing style overrides
            mikej3204 Level 1
            Ok,
            I got it to work in a text box, but I want it to reformat within a table. I assume that changes a lot?
            Also, I will want it to do it to multiple styles, how would I go about adding styles to that script?
            Thank you very much!!!!
            -MK
            • 3. Re: Scripts for clearing style overrides
              For the multiple styles replace
              with
              switch (myParaSel.appliedParagraphStyle) {
                  case myDoc.paragraphStyles.item("Test"): ;
                  case myDoc.paragraphStyles.item("Test1"): ;
                  case myDoc.paragraphStyles.item("…"): ;
                  // and so on
              If you want to find paragraphs in an table try the following lines
              I only changed it for one function
                      // you have to test if there is any table
                      if (myDoc.stories.everyItem().tables.length > 0) {
                          var paras = myDoc.stories.everyItem().tables.everyItem().cells.everyItem().paragraphs.everyItem().getElements();
                      else  alert("Information\nNot Table found");
