1 Reply Latest reply on May 10, 2006 4:11 PM by jthereliable
    LoadVars
    rochribre1 Level 1
      How I do to load a var with action script and to use, if this var to be a array in the php.
      teste[0] - is a Array the PHP and teste5.text is a Dynamic Text the flash
      this retorn = undefined and if I put only teste return = Array.
      var arquivo1:LoadVars = new LoadVars();
      arquivo1.load("info.php");
      arquivo1.onLoad = function(){
      teste5.text=arquivo1.teste[0];
      Thanks.
        • 1. Re: LoadVars
          jthereliable Level 1
          ok... so, lemme get this straight... you want to load an array... right? I'm not totally sure if there's an easier way, but here's the way I'll use
          on PHP, do this:
          echo "&teste=";
          $teste=Array();
          $teste[]="hi";
          $teste[]="hi, again";
          for($i=0;$i<count($teste);$i++)
          if($i!=0)
          echo "||||";
          echo $teste[$i];
          echo "&";
          and for inside the arquivo1.onLoad = function(), I'll do this:
          testearray=arquivo1.teste.split("||||");
          teste5.text=testearray[0]; //and if you want, you can do testearray[1]
          if you do that, teste5 will say "hi" and if you used 1, it'll say "hi, again"
          I'm not POSITIVE that it will work, because I didn't check and debug it for errors, but I hope you get the idea.
          (and I hope this was what you were looking for)
