2 Replies Latest reply on May 16, 2015 3:31 AM by Eugene Tyson
    Imposing a 12 page spread using Print Booklet...
    ZarahSergison Level 1
      For some reason, when I save this PostScript file it is only 6 pages instead of 12. Ive checked the file before pressing print and it all looks fine. I don't know what I'm doing wrong. Any help will be so appreciated! Thanks!
        • 1. Re: Imposing a 12 page spread using Print Booklet...
          Eugene Tyson Adobe Community Professional & MVP
          If it's 12 pages and you make a booklet it will on be only 6 pages as it's in spreads.
          But for a 12 page booklet you need to print pages 1,12,2,11
          Those four pages will wrap around your 8 pages
          2-10
          Also for the Print Booklet feature - you need to tick Print Blank pages in two places
          1. In the File>print booklet and under Setup - tick Print Blank Spreads
          2. File>Print Booklet and go to the Print Settings at the bototm, in Print Settings under General tick Print Blank Pages
          Hope that helps
          • 2. Re: Imposing a 12 page spread using Print Booklet...
            Now for some home truths
            Imposing is not your job, it's the printers job - if your printer requires this then they are not a good printers as this is standard for printing companies.
            You really should use File>Export and choose PDF (print) and select your settings from there and then use the Print Booklet feature from Acrobat    Print booklets | Acrobat, Reader
            If this is for home printing, then it's fine - I'm not going to argue with your methods... But consider the option of Exporting to PDF and printing booklet from Acrobat as above.
            Printing to PDF loses a lot of information required for professional printers - as it's passed through postscript which means it loses lots of smartness.
            You lose transarencies, anything done in the fx panel, including blend modes.
            Colour management is lost
            Tagged PDF for accessiblity is lost
            And loads of other reasons why it's a bad idea to print to PDF.
