8 Replies Latest reply on May 17, 2015 4:02 PM by CarlosCanto
    Look for page items in one specific layer, not in whole document
    joshlac
      could you please help me to edit this script so it can only look for page items("Date", "Time", "Version", "Ops Component Code") in one specific layer named "Legend" insted of all layers?
      ADOBE SYSTEMS INCORPORATED
      Copyright 2005-2006 Adobe Systems Incorporated
      All Rights Reserved
      NOTICE:  Adobe permits you to use, modify, and
      distribute this file in accordance with the terms
      of the Adobe license agreement accompanying it.
      If you have received this file from a source
      other than Adobe, then your use, modification,
      or distribution of it requires the prior
      written permission of Adobe.
      /** Saves every document open in Illustrator
        as a PDF file in a user specified folder.
      // Main Code [Execution of script begins here]
      try {
        // uncomment to suppress Illustrator warning dialogs
        // app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
        if (app.documents.length > 0 )
        var options, i, sourceDoc, targetFile,;
        // Get the PDF options to be used
        options = this.getOptions();
        if (options != null)
        sourceDoc = app.activeDocument; // returns the document object
        var fullName = sourceDoc.fullName;
        fullName = fullName.toString();
        var destFolder = fullName.slice(0,fullName.lastIndexOf("/"))
        var dateFound = false;
        var versionFromName = fullName.slice(fullName.lastIndexOf("-")+1, fullName.lastIndexOf("_"));
        var opsFromName = fullName.slice(fullName.lastIndexOf("/")+1, fullName.lastIndexOf("-"));
        var theVersionNumber = null;
        var dateField = null;
        var timeField = null;
        var opsVersionCode = null;
        for(i=0; i<sourceDoc.pageItems.length;i++)
        if (sourceDoc.pageItems[i].note == "Date")
        dateField = sourceDoc.pageItems[i];
        if (sourceDoc.pageItems[i].note == "Time")
        timeField = sourceDoc.pageItems[i];
        if (sourceDoc.pageItems[i].note == "Version")
        theVersionNumber = sourceDoc.pageItems[i].contents;
        if (sourceDoc.pageItems[i].note == "Ops Component Code")
        opsVersionCode = sourceDoc.pageItems[i].contents;
        if (theVersionNumber == versionFromName)
        if (opsVersionCode == opsFromName)
        if (dateField == null)
        alert('No tagged date field found. Tag field and try again.')
        else
        dateField.contents = TodayDate()
        timeField.contents = TodayTime()
        OLtargetFile = this.getTargetFile(sourceDoc.name, '.pdf', destFolder);
        sourceDoc.saveAs( OLtargetFile, options)
        // alert( 'Documents saved as PDF' );
        else
        alert('Ops component code in boiler does not match file name or is not tagged. Please correct and try again.')
        else
        alert('Version number in boiler does not match file name or is not tagged. Please correct and try again.')
        else
        alert('User aborted')
        else
        throw new Error('There are no document open!');
      catch(e) {
        alert( e.message, "Script Alert", true);
      /** Returns the options to be used for the generated files.
        @return PDFSaveOptions object
      function getOptions()
        // Create the required options object
        var options = new PDFSaveOptions();
        // See PDFSaveOptions in the JavaScript Reference for available options
        options.pDFPreset = "AZ"
        // For example, uncomment to set the compatibility of the generated pdf to Acrobat 7 (PDF 1.6)
        // options.compatibility = PDFCompatibility.ACROBAT7;
        // For example, uncomment to view the pdfs in Acrobat after conversion
        // options.viewAfterSaving = true;
        return options;
      function abortFunction(){
        modUI = null;
        dlg.hide();
        return null;
      /** Returns the file to save or export the document into.
        @param docName the name of the document
        @param ext the extension the file extension to be applied
        @param destFolder the output folder
        @return File object
      function getTargetFile(docName, ext, destFolder) {
        var newName = "";
        // if name has no dot (and hence no extension),
        // just append the extension
        if (docName.indexOf('.') < 0) {
        newName = docName + ext;
        } else {
        var dot = docName.lastIndexOf('.');
        newName += docName.substring(0, dot);
        newName += ext;
        // Create the file object to save to
        var myFile = new File( destFolder + '/' + newName );
        // Preflight access rights
        if (myFile.open("w")) {
        myFile.close();
        else {
        throw new Error('Access is denied');
        return myFile;
      function TodayDate(){
        var Dateformat = "dd mm yyyy";
        nameMonths = true;
         var monthNames = ["January","February","March","April","May","June","July","August","September","October","November","December"];
         var Today = new Date();
         var Day = Today.getDate();
         if(nameMonths == true){
         var Month = monthNames[Today.getMonth()];
         } else {
         var Month = Today.getMonth() + 1;}
         var Year = Today.getYear();
         var PreMon = ((Month < 10) ? "0" : "");
         var PreDay = ((Day < 10) ? "0" : "");
         var Hour = Today.getHours();
         var Min = Today.getMinutes();
         var Sec = Today.getSeconds();
         if(Year < 999) Year += 1900;
         var theDate = Dateformat.replace(/dd/,PreDay+Day);
         theDate = theDate.replace(/mm/,PreMon+Month);
         theDate = theDate.replace(/d/,Day);
         //theDate = theDate.replace(/m/,Month);
         theDate = theDate.replace(/yyyy/,Year);
         theDate = theDate.replace(/yy/,Year.toString().substr(2,2));
         if(Hour==0){
        Hour = "12";
        theDate = theDate.replace(/XX/,"AM");
         }else if(Hour>12){
         Hour = (Hour-12);
         theDate = theDate.replace(/XX/,"PM");
         }else{
         var preSec = ((Sec < 10) ? "0" : "");
         var preHour = ((Hour < 10) ? "0" : "");
         var preMin = ((Min < 10) ? "0" : "");
         theDate = theDate.replace(/hr/,preHour+Hour);
         theDate = theDate.replace(/Mn/,preMin+Min);
         theDate = theDate.replace(/sc/,preSec+Sec);
         return theDate;
      function TodayTime(){
        var Dateformat = "hr:Mn";
        nameMonths = false;
         } else {
         var PreMon = "";//((Month < 10) ? "0" : "");
         if(Hour==0){
        Hour = "12";
        theDate = theDate.replace(/XX/);
         }else{
         return theDate;
