8 Replies Latest reply on May 18, 2015 1:11 PM by frazierdesignlq
    Composition not scaling in parent div
    frazierdesignlq
      Composition scaling not working and does not scale to parent div but to browser window...HELP!
        • 1. Re: Composition not scaling in parent div
          seano2o7 Level 3
          Hi can you show a demo or post the project on here so I can have a look please
          • 2. Re: Composition not scaling in parent div
            frazierdesignlq Level 1
            This is how it looks...will not be contained...
            • 3. Re: Composition not scaling in parent div
              seano2o7 Level 3
              Theres this responsive scaling code, which works well from Sarah Justine.  Put in compositionReady
              sym.$(“#Stage”).css({ // Set the transform origin so we always scale to the top left corner of the stage
              “transform-origin”:”0 0″,
              “-ms-transform-origin”:”0 0″,
              “-webkit-transform-origin”:”0 0″,
              “-moz-transform-origin”:”0 0″,
              “-o-transform-origin”:”0 0″
              function scaleStage() {
              var stage = sym.$(‘Stage’); // Set a reusable variable to reference the stage
              var parent = sym.$(‘Stage’).parent(); // Set a reusable variable to reference the parent container of the stage
              var parentWidth = stage.parent().width(); // Get the parent of the stage width
              var parentHeight = $(window).height(); // Get the browser window height
              var stageWidth = stage.width(); // Get the stage width
              var stageHeight = stage.height(); // Get the stage height
              var desiredWidth = Math.round(parentWidth * 1); // Set the new width of the stage as it scales
              var desiredHeight = Math.round(parentHeight * 1); // Set the new height of the stage as it scales
              var rescaleWidth = (desiredWidth / stageWidth); // Set a variable to calculate the new width of the stage as it scales
              var rescaleHeight = (desiredHeight / stageHeight); // Set a variable to calculate the new height of the stage as it scales
              var rescale = rescaleWidth;
              if (stageHeight * rescale > desiredHeight) // Do not scale larger than the height of the browser window
              rescale = rescaleHeight;
              // Rescale the stage!
              stage.css(‘transform’, ‘scale(‘ + rescale + ‘)’);
              stage.css( ‘-o-transform’, ‘scale(‘ + rescale + ‘)’);
              stage.css(‘-ms-transform’, ‘scale(‘ + rescale + ‘)’);
              stage.css(‘-webkit-transform’, ‘scale(‘ + rescale + ‘)’);
              stage.css(‘-moz-transform’, ‘scale(‘ + rescale + ‘)’);
              stage.css(‘-o-transform’, ‘scale(‘ + rescale + ‘)’);
              parent.height(stageHeight * rescale); // Reset the height of the parent container so the objects below it will reflow as the height adjusts
              // Make it happen when the browser resizes
              $(window).on(‘resize’, function(){
              scaleStage();
              // Make it happen when the page first loads
              $(document).ready(function(){
              scaleStage();
              You might need to edit the parent in the code if that doesn't work.
              • 4. Re: Composition not scaling in parent div
                Can you tell me where 'compositionReady Is? Or do I need to add in coding window?
                • 5. Re: Composition not scaling in parent div
                  seano2o7 Level 3
                  Click to Add a Trigger Event on Stage and it's there
                  • 6. Re: Composition not scaling in parent div
                    This does not work...when EA first came out I was able to just set 100% width and it would scale in parent...this is very frustrating.
                    • 7. Re: Composition not scaling in parent div
                      seano2o7 Level 3
                      Sorry there was errors in that code. Try this
                      sym.$("#Stage").css({
                         "transform-origin":"0 0",
                         "-ms-transform-origin":"0 0",
                         "-webkit-transform-origin":"0 0",
                         "-moz-transform-origin":"0 0",
                         "-o-transform-origin":"0 0"
                         var stage = sym.$("Stage"); // Set a reusable variable to reference the stage
                         var parent = sym.$("Stage").parent(); // Set a reusable variable to reference the parent container of the stage
                         stage.css("transform", "scale(" + rescale + ")");
                         stage.css( "-o-transform", "scale(" + rescale + ")");
                         stage.css("-ms-transform", "scale(" + rescale + ")");
                         stage.css("-webkit-transform", "scale(" + rescale + ")");
                         stage.css("-moz-transform", "scale(" + rescale + ")");
                         stage.css("-o-transform", "scale(" + rescale + ")");
                         $(window).on("resize", function(){
                         scaleStage();
                         scaleStage();
                      • 8. Re: Composition not scaling in parent div
                        No this still does not work...
