1 Reply Latest reply on Jan 5, 2007 4:39 PM by ntsiii
    SWFLoader question
    m_hartnett Level 3
      I am trying to implement a slide show using a flash slide show component.
      I have downloade a couple of the free components available in the Adobe Component Exchange
      I have placed an swfloader tag in the application.
      <mx:SWFLoader source="slide_show.swf" width="450" height="310" autoLoad="true" id="homeShow"/>
      The images that will be displayed are controlled by an XML file.
      When I run the application the first image of the slide show will display but then no other images.
      I realize that this is an open ended question but is there anything I need to do to further enable this flash component.
      Could there be a compatibility error between the flash component and flashplayer 9.
      Can anyone point me to some examples of using SWFLoader or should I write something in flex that will do the same thing.
        • 1. Re: SWFLoader question
          ntsiii Level 3
          Understand that there are some issues with running a Flash 8 (AS2) within a Flex (AS3) app, because they will be runnin in different "virtual machines". If the loaded swf requires any communication with its parent, there is a problem. The only way they can communicate is via LocalConnection, which must be enabled on both ends.
          I am not a Flash guy so I can't be more specifically helpful.
          Tracy
