4 Replies Latest reply on May 29, 2015 12:16 AM by ThePictureCreator
    automatic page numbering with AS
    ThePictureCreator
      Hello All,
      I'm pretty new in Applescripting but i've written a script to design a page in InDesign CS5 but now i'm trying to set the pagenumber in the same script.
      I tried the following but didn't work out:
      set mypagenumber to text returned of (display dialog ¬
        "set pagenumber" with title "Paginanummer instellen" with icon 1 ¬
      default answer "1" buttons {"instellen"} default button 1)
      tell application "Adobe InDesign CS5"
        set start page number of active document to mypagenumber
      end tell
      i'll hope somebody can tell me what i'm doing wrong.
      Thanks in advance,
      Michael
        • 1. Re: automatic page numbering with AS
          AS Scripter Level 1
          -- Often, instead of setting a property directly, you must set it within a "tell [...] preferences" block, for example:
          tell application "Adobe InDesign CS6"
            tell document 1
            tell document preferences
            set start page number to 14
            end tell
            end tell
          end tell
          -- There are several different suites of preferences, so check the Applescript dictionary to see if a property is within a preferences suite.
          • 2. Re: automatic page numbering with AS
            ThePictureCreator Level 1
            I'm afraid to tell you it did'n solve the problem... but i think the error is in the first line of the script:
            set mypagenumber to text returned of (display dialog "set pagenumber" with title "set the pagenumber" with icon 1 default answer "1" buttons {"set"} default button 1)
            When i change 'mypagenumber' into e.g. 12 the script works... (set start page number to mypagenumber)
            • 3. Re: automatic page numbering with AS
              AS Scripter Level 1
              -- The start page number expects an integer, not a text string. Simply coerce to an integer like so:
                tell document 1
                set start page number to (mypagenumber as integer)
                end tell
                end tell
              end tell
              • 4. Re: automatic page numbering with AS
                Thank you AS Scripter,
                With your awnser i solved the problem. The script looks like below and works very well
                  set DocumentName to name of front document as string
                  set documentorspecial to characters 4 thru 4 of DocumentName as string
                  if documentorspecial is "_" then
                  set x to false
                  end if
                  if x is false then
                  display dialog "Gestopt, dit is een complete special" giving up after 2 --documentofspecial
                  error number -128
                  end if
                end tell
                display dialog "filename is " & DocumentName & " vierde karakter is " & documentorspecial
                display dialog "set pagenumber" with title "set the pagenumber" with icon 1 default answer 1 buttons {"set"} default button 1
                set mypagenumber to text returned of the result as number
                  set myDocument to document 1
                activate
                  tell document preferences of myDocument
                  set facing pages to true
                  set allow page shuffle to true
                  end tell -- document preference
                end tell --application InDesign
                --if is_odd(the mypagenumber) is false then display dialog "linker pagina"
                --if is_odd(the mypagenumber) is true then display dialog "rechter pagina"
                on is_odd(this_number)
                  if this_number mod 2 is not 0 then
                  return true
                  else
                  return false
                  end if
                end is_odd
                Thanks again for your help!
