6 Replies Latest reply on Jan 24, 2007 1:38 PM by JohnGree
    cfoutput group
    JohnGree Level 1
      Hi i have a webpage
      http://www.southerncooling.com/NEW.cfm
      the first model "505350 Tank Beige" should show EXH-130, 150, 170, 190, 210, EXD-150, 170, 210
      but i am get duplicates
      any ideas why this is?
        • 1. Re: cfoutput group
          Zanzibar96 Level 1
          Tried to look at page link but you have a "Could not connect to JRun server"
          • 2. Re: cfoutput group
            JohnGree Level 1
            hi should be ok now
            • 3. Re: cfoutput group
              Zanzibar96 Level 1
              Try taking all your outputting code out and add them all back one by one. I believe the multiple CFoutputs are causing the duplicates to show. You could also test SQL statement in DB to see what results are as inner joins can sometimes bring back multiple results.
              Start with SQL statement. If it doesn't bring back dupes then it's Cfoutput code.
              Hope this helps.
              • 4. Re: cfoutput group
                JohnGree Level 1
                ok many thanks
                if you look now at
                the first record should show
                505350 EXH-130, 150, 170, 190, 210 EXD-130, 150, 170, 190, 210
                but it only shows the first one EXH-130, 150, 170, 190, 210,
                as soon as put a cfoutput in i get a totlly wrong result, is my query ok?
                • 5. Re: cfoutput group
                  Zanzibar96 Level 1
                  I get an error when I go to the page. Try building query with just the first select and from part and then add one inner join to see if you get the correct result. I know a few times in my past I had inner joins that were pulling duplicate information. It could be so simple as exchanging what is being inner joined.
                  If you want to send me a copy of the db you can do so here: alfior73 at yahoo.com
                  • 6. Re: cfoutput group
                    JohnGree Level 1
                    ok thanks i will forward u a copy, should i just do a cfdump of the mysql database?
                    i have played around with the query this is want i have now but still only shows 1 result for each partno
                    <cfquery name="Products" datasource="#application.ds#">
                    SELECT *
                    FROM Products_Table PT
                    INNER JOIN Range_Model RM
                    ON RM.Product_ID64 = PT.Products_ID
                    INNER JOIN Range_table RT
                    ON RM.Range_ID64 = RT.Range_ID
                    INNER JOIN Model_Table MT
                    ON MT.Model_ID = RM.Model_ID64
                    ORDER BY Range_Name
                    </cfquery>
