7 Replies Latest reply on Nov 2, 2015 11:12 AM by dj_paige
    Lightroom won't sync all photos in folder
    imaccready Level 1
      Although I've owned Lightroom with my CC subscription for quite some time, I'm just trying it out now.
      I can't for the life of me figure out how to get Lightroom to import all of the photos in a folder. This should be simple (and I'm sure it is) but I must be missing something terrible obvious. I have almost 800 images in a folder. I can see them in Windows Explorer and in Adobe Bridge so I know they're there. In Lightroom I have a folder called "Photos" with two sub folders. One folder was there when I first initiated Lightroom but the other one was created in Bridge afterwards. I managed to get Lightroom to see the new folder and it sees 33 of the photos in it but it will not show me the other 754 photos in there. When I try to sync the folder, the Sync interface asks me if I want to import 754 photos - but when I agree Lightroom reports that there are no images to import.
      I've done everything from restarting Lightroom to refreshing the folder in Explorer (and many other functions in between) to no avail. Any suggestions?
        • 1. Re: Lightroom won't sync all photos in folder
          99jon Adobe Community Professional & MVP
          If you go to the Catalog tab and choose "All Photographs" can you see if the photos are already in the catalog?
          • 2. Re: Lightroom won't sync all photos in folder
            dj_paige Level 9
            Do not assume Lightroom is a file browser. It is not a file browser. It doesn't "see" photos in your folders.
            If your 754 photos cannot imported via synchronize, it is because they have previously been imported, and are not going to be imported via synchronize (or any other way) again. Furthermore, Lightroom thinks these 754 photos are in a different folder ... why? ... because when you imported them previously, you (perhaps accidentally) asked Lightroom to copy them to another folder.
            So, you need to go into the Library Module, and then follow all four of these steps in sequence
            1. In the Catalog section on the right, click on "All Photographs"
            2. Turn off all filters, Ctrl-L once or twice
            3. Expand all stacks ... use Photo->Stacking->Expand All Stacks
            4. Search for one of these 754 photos using the file name
            This will find that one photo (and presumably the other 753) and you can them make use of them as needed in Lightroom. If necessary you could also instruct Lightroom to make use of the copy in the desired folder.
            • 3. Re: Lightroom won't sync all photos in folder
              imaccready Level 1
              Thanks for the quick response, 99jon and dj_paige. I'll be back to it shortly and try as you suggest. "not a file browser" seems to be a key phrase for me to consider. I'll let you know how it goes.
              • 4. Re: Lightroom won't sync all photos in folder
                imaccready Level 1
                It still took me a bit to figure it out but I'm pretty sure what happened is that the files I couldn't see were named the same (and were the same) as ones that were already synced on Lightroom. I just had to give Lightroom permission to sync images that were duplicates.
                Thanks for your help. I'm getting closer to a full understanding of Lightroom.
                • 5. Re: Lightroom won't sync all photos in folder
                  dj_paige Level 9
                  The general idea of allowing duplicates solves some problems, but causes other problems. In particular, edits and metadata you apply to one of the duplicates will not appear on the other one of the duplicates, unless you take some manual action.
                  In the long run, you'd be better off not allowing duplicates.
                  • 6. Re: Lightroom won't sync all photos in folder
                    heronsong
                    I am having a similar problem. When I sync files, LR will no longer import photos in subfolders. It mentions them (e.g. Import new photos (1)) but it won't actually import unless I sync the subfolder.
                    • 7. Re: Lightroom won't sync all photos in folder
                      dj_paige Level 9
                      This has been explained earlier in this thread. Please try the solution suggested there.
