5 Replies Latest reply on May 20, 2015 10:12 PM by BEGINNER_X
    Alert Missing Fonts
    BEGINNER_X Level 3
      Hi All,
      FYI., new to Illustrator & Illustrator scripting.
      Request:
      Need alert, if the illustrator document having missing fonts.
      In Indesign, we should use the below code:
      Missing_Font();
      function Missing_Font()
          var myUsedFonts = app.activeDocument.fonts;
          for (var i = 0; i < myUsedFonts.length; i++) {
          if (myUsedFonts[i].status != "1718831470")
              alert("Please Fix Missing Font")
              exit(0);
      Thanks in advance
      Siraj
        • 1. Re: Alert Missing Fonts
          Ten A Adobe Community Professional
          Here is a verify document<->system fonts sample code.
          function getSysFonts(){
            var f = app.textFonts;
            var fontLst = [];
            for (var i=0;i<f.length;i++){
            fontLst.push(app.textFonts[i].name);
            return fontLst.join(";");
          function getFntsLst (doc){
               var xmlString = new XML(doc.XMPString);
               var fntFace = xmlString.descendants("stFnt:fontName");
               var lst = [];
               for (var i=0; i<fntFace.length(); i++)
            lst.push(fntFace[i]);
               return lst;
          var st="";
          var ft = getFntsLst (app.activeDocument);
          var sysFt = getSysFonts();
          for (var i=0;i<ft.length;i++) {
            if (sysFt.indexOf(ft[i])>-1) st += ft[i] + " : found in system.\n";
            else  st += ft[i] + " : not found in system.\n";
          alert (st);
          Documents font information in XMP string and System fonts list in textFonts property under the application.
          Ten
          • 2. Re: Alert Missing Fonts
            BEGINNER_X Level 3
            Hi Ten,
            Thanks for your quick response...
            My request is,
            if the document having any missing fonts, then the script should alert("Document having missing fonts. Please check")
            I tried your script, it will list out all the used fonts only. Not shows missing font.
            Script Output Screenshot:
            Please look at Document Find Font Screenshot:
            • 3. Re: Alert Missing Fonts
              mmmm....
              Sorry, I think textFonts property not contain missings, But I its wrong.
              There seems to not in useful properties in AI.
              I'll search another way to detect it...
              Ten
              • 4. Re: Alert Missing Fonts
                Here is a reference thread:
                https://forums.adobe.com/thread/1075283
                However, We can predefine and save  textFonts. When you need to check fonts, Read it and compare Documents font list.
                Ten
                • 5. Re: Alert Missing Fonts
                  BEGINNER_X Level 3
                  Hi Ten,
                  Thanks a lot!!!!
                  No words to say, you did a excellent job for me.
                  Tested in single file, Works like a charm.
                  Even though, I need to check with all live jobs.
                  Again Thanks
                  Siraj
