5 Replies Latest reply on May 21, 2015 2:31 AM by 4500 Times
    Colour gradient mask
    4500 Times
      Hi.
      I have an animation composited in After Effects that contains several sets of EXR files rendered from 3DS Max.
      One layer shows a yellowish liquid pouring into a rectangular vessel.  This lands in the centre and spreads to the edges of the rectangle over several thousand frames.
      I have an existing rectangular mask (see image below) that hides the top part of the object.  This has a feather at the bottom of the mask to blend the effect with another layer.
      There are two existing effects added to the layer (see image below).
      In addition, I would now like to add some sort of colour correction/colour gradient to the layer that results in the liquid at the centre keeping its existing colour and gradually changing to a redder colour at the ends of the rectangle (see image below).  Ideally this would be a radial gradient (starting just below the "Original color" arrow in the image).
      I have searched for tutorials and tried adding effects such as Ramp (along with Calculations) but these all seem to deal with adding affects to just the overall layer.  What I want to do is add the effects just using a new mask in addition to/separate to the existing mask.
      Could anyone please give me some pointers or advise of any tutorials that show me the solution to this.
      Many thanks,
      T
        • 1. Re: Colour gradient mask
          Simply add it on another layer/ pre-composition and then use blending modes or effects like Channel Combiner to reference those layers and compose it on top. Pre-CC versions do not allow to constrain effects to specific masks.
          Mylenium
          • 2. Re: Colour gradient mask
            I would pre-compose your yellow liquid layer then add a shape layer with a gradient fill above. Make the edges red and the center transparent. Then change the blend mode to Multiply and then turn on Preserve Underlying Transparency.Screen Shot 2015-05-20 at 6.57.38 AM.png
            • 3. Re: Colour gradient mask
              4500 Times Level 1
              Thanks both.
              Rick, I tried to follow your method and am getting something similar to what you have.  Just leaving the office now but may have another question tomorrow.
              Thanks again.
              Terry
              • 4. Re: Colour gradient mask
                4500 Times Level 1
                Hi Rick.
                I have managed to create something based on your method above.
                The animation that I am creating is in six A.E. files.  I am creating AVI files from each and compiling these in Premiere Pro to output a movie as MP4.  I therefore need to copy the exact settings (mask shape/position, gradient etc.) from the Shape layer that I added to the Pre-comp in the first file across to all other A.E. files.
                Would it please be possible to advise how I copy the Shape layer from one A.E. file to the others.  I have googled how to do this and the general consensus is to import the whole A.E. project and delete the unrequired layers.  I have a lot of layers all of which have the same name in all my six A.E. files.  This could get very messy.  Is there a way to bring in just the layer that I require?
                Many thanks,
                Terry
                • 5. Re: Colour gradient mask
                  4500 Times Level 1
                  Hi Rick.
                  I did this thanks.  I used an intermediate file and deleted the unwanted in there.  Simple enough.
                  Many thanks for your help.
                  Terry
