2 Replies Latest reply on May 21, 2015 3:32 AM by uboss84
    Shuffle a set of  elements with jQuery
    uboss84 Level 1
      how i can use this function in adobe edge....someone can help me please
      Shuffle a set of HTML elements with jQuery - JSFiddle
        • 1. Re: Shuffle a set of  elements with jQuery
          seano2o7 Level 3
          They use the random function here:
          var randomNumber = Math.floor (Math.random () * 2);
          Replace the 2 with how many numbers you want it to generate between. For example this code will generate a random number between 0 and 2. If you changed it to 10 it would generate a random number between 0 and 10.
          So if I was going to build that page, and had 10 squares I would use:
          if(randomNumber == 0) {
          sym.$("square1").html("1");
          sym.$("square1").html("2");
          sym.$("square1").html("3");
          sym.$("square1").html("4");
          sym.$("square1").html("5");
          if(randomNumber == 1) {
          if(randomNumber == 2) {
          I know this isn't a shuffle method like them. But this would be the way I would do it.The more random numbers you have the more possibilities it will be random. I'm sure there is a better alternative to this method though. Easier way I could think of for edge though.
          • 2. Re: Shuffle a set of  elements with jQuery
            uboss84 Level 1
            it's not a good solution, i work with over 100 element
