4 Replies Latest reply on May 22, 2015 2:15 AM by martins82060393
    get.Field from 2 different text fields
    martins82060393 Level 1
      I have this script i'm trying to run.
      The purpose of the script is to get csv info from a text field.
      Now the text field is maxed out character wise, so i've created a new text field (KnownInstruments2).
      How do i make the script below to search in both: "KnownInstruments & KnownInstruments2? Anyone who can provide a quick answers, would be so much appreaciated
      function LookupInstrument()
        var ins=this.getField('Instrument').value;
        var knowninstruments=this.getField('KnownInstruments').value + ";" + this.getField(KnownInstruments2).value;
        var lines=knowninstruments.split('\r');
      Thanks!
        • 1. Re: get.Field from 2 different text fields
          Your description of what you want to achieve is not very clear... So you want to search for one string inside another, and then what?
          • 2. Re: get.Field from 2 different text fields
            tI will start search in "KnownInstruments" - but the text field can't have any more characters in it's "default values".
            Then i made one more text field called it "KnownInstruments2".
            I have a field, and if i trype: 671 - then it will find instrument 671 and it customers. But if it's not in "knowninstruments" i will go to KnownInstruments2 and search.
            Here is the whole script;
              var knowninstruments=this.getField('KnownInstruments').value;
              this.getField('Firm').value='';
              this.getField('ContactPerson1').value='';
              this.getField('Email1').value='';
              this.getField('Distributor1').value='';
              this.getField('DistributorEmail1').value='';
              for (var i=0; i<lines.length; i++) {
                var line=lines[i];
                var columns=line.split(';');
                // Check if found instrument.
                if (columns[0] == ins) {
                   this.getField('Firm').value=columns[1];
                   this.getField('ContactPerson1').value=columns[2];
                   this.getField('Email1').value=columns[3];
                   this.getField('Distributor1').value=columns[4];
                   this.getField('DistributorEmail1').value=columns[5];
                   break;
            • 3. Re: get.Field from 2 different text fields
              So you just want to know how to combine the values of two fields into a single string? You were on the right path, the only problem is you didn't put the second field name in quotes... So use this:
              var knowninstruments = this.getField("KnownInstruments").valueAsString + ";" + this.getField("KnownInstruments2").valueAsString;
              • 4. Re: get.Field from 2 different text fields
                Thanks a lot tyr67! Worked like a charm!
